Micro RS4 Thread
#316
Is this the axle?
http://www.liquidrc.com/index.php?ma...oducts_id=3276
Check the whole category, they have plenty of parts.
Should have steps in it like this... now where to find it????
http://www.gpmparts.com/shop/hpi-mic...-90008216.html
#318
First two parts are rear ball diffs complete with 4mm Ti axle. All I'm really looking for is the 4mm Titanium axle. Other parts are foam bumpers for the GTR and Viper. There is someone who has the bumpers on eBay... but he doesn't want to sell them?? Has blocks in place.. had 12 people try to buy from him and can't.. Contacted him.. says he has no blocks??
the ti axles are softer than stock and bend the FIRST hit they take..
The BEST axles and ball diffs are the HPI ones..
The front drives by HPI have seen about 3000 miles on my MRS4 and still are good same with the frt one way.
aluminum or aftermarket parts for MRS4's were 90% crap use genuine hpi stuff if u can get it.
it lasts longer but you gotta search pretty hard to find some of it...
#319
I'm looking to get my Micro RS4 back up and running. I want make it a drifter. Is there anything special I need to do other than a set of tires? I want to use this at my local carpet track. Its not ozite but looks pretty darn close to it. It's some type of office type carpeting and it about 4 months old if that helps.
Thanks in advance.
Thanks in advance.
#320
You can buy the drift gear set which has a solid rear spur with NO diff and a solid plug to go in the front with NO diff that and the drift tires and ur away to the races...
not sure of part ##'s but should be googleable
#321
I really can't tell by the picture.. the blow-up is smaller then the add LOL.. and no mention of 4mm bearings.
#322
I've never been able to bend or break anything Ti. Been running the same GPM MHTS Ti axle for about 5 years now... while everybody else is bending stock ones.
I'd really like to find that setup. Know any shops that have it??
#323
dont touch the titanium axles they are crap.. and the balll diff that goes with it only fits it nothing else...
I had the same issue. I have a boat load of HPI parts along w 4 chassis.
Stock,Penguin, and Megatech versions. Anybody interested PM about what I have.
Berm
#324
Hey everyone, I just bought a mRS4 second hand. My car came with a stock chassis and a carbon one, does anyone know what chassis set this is? Also, do they make metal diff shafts to go with the upgraded universals?
#325
#327
That's an old IPD chassis. They were made by a company out of Canada. Not in business anymore as far as I know...Hope this helps!
#328
Just ordered a bunch of other stuff to get this thing running, most of it unnecessary, ball diff, purple hubs, ae rc18t front shocks. I did order a Castle sidewinder 5400kv BL setup and the steel universals. How do the plastic diff cups hold up? Does anyone make metal ones or do you just have to keep replacing the stock ones?
If anyone has a clear pic on the dual tie rod setup I'd appreciate seeing how that goes together, thanks.
#329
Most of my stuff is in, tore down the old car and am starting the re build.
Anybody know where to find tires for this car that are NOT drift? Looking for rubber touring tires. Found AsiaTees website but not sure what they mean about 40/30 degree tires?
#330
If anyone has a clear pic of the dual tie rod setup I'd appreciate seeing how that goes together, thanks.
9Likes
