Mini-96 World Challenge
#3557
Class- Box Stock
Date- 3-21-26
Location-Omaha, NE
Race Time- 4:19.490 or 259.490
Fastest Lap- 3.156
Chassis- MR04
Body- Mclaren 720S
Wheelbase- 98MM
Tires- Front PN KSM Medium +1 offset Rear Marka V1RR15 +3 offset (worn to slick)
Motor- Stock
Batteries- Gens Ace
Front Springs- Stock
T-Plate- Kyosho FRP 6M
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- 15k/30K Kyosho
Gearing- 7T
Notes- Tried for a while to improve but couldn't. Hard to find a slower rhythm when I was switching between faster cars. Try not to mess with this car, it is always consistent for me.
Date- 3-21-26
Location-Omaha, NE
Fastest Lap- 3.156
Chassis- MR04
Body- Mclaren 720S
Wheelbase- 98MM
Motor- Stock
Batteries- Gens Ace
Motor Mount- MM
Gearing- 7T
#3558
Class- Stock
Date- 3-24-26
Location-Omaha, NE
Race Time- 4:03.895 or 243.895
Fastest Lap- 2.998
Chassis- PN2.5 (MR04 front end)
Body- Jomurema with lexan roof
Wheelbase- 98MM
Tires- Front: PN KSK 40 offset +1 Rear: Marka V1R15 +3
Motor- PN V4 3500kv
Batteries- Kyosho Speed House
Front Springs- Green
T-Plate- Kyosho Carbon Soft
Motor Mount- PN V4
Dampener (If applicable)- PN disc (both springs green), no top shock
Dampener Fluid (If applicable)- Kyosho 5k
Gearing- 14/53 Nexx lightweight ball diff
Notes- Messed with tires and gearing, settled back on a 14t for my fast run. Switched to taller rears and finally got a consistent run and a sub 3.0 lap. Also tried some different wings, not sure I noticed a difference, but had some faster runs with the pink one so there you have it.
Date- 3-24-26
Location-Omaha, NE
Fastest Lap- 2.998
Wheelbase- 98MM
Motor- PN V4 3500kv
Motor Mount- PN V4
#3559
Class- Pro Stock
Date- 3-21-26
Location- Omaha, NE
Race Time- 4:14.256 or 254.256
Fastest Lap- 3.019
Chassis- PN2.5
Body- Jomurema
Wheelbase- 98
Tires- PN KS Medium front Marka V1R15 rear +1/+3 offsets
Motor- XSpeed
Motor Mount- MR04 MM
Dampener (If applicable)- PN Disc (Green bottom Blue top springs)
Dampener Fluid (If applicable)- Mostly dry (Kyosho 5k)
Gearing- 8T
Notes - Sometimes start with this car as my practice car, and had some consistent runs (for this month). Seemed to like the paper thin KS fronts and the full hard body. Normally swap a lexan roof body but didn't seem to work as well for me.
Date- 3-21-26
Location- Omaha, NE
Fastest Lap- 3.019
Chassis- PN2.5
Body- Jomurema
Wheelbase- 98
Motor- XSpeed
Gearing- 8T
#3560
Class- Open
Date- 3-31-26
Location- Omaha, NE
Race Time- 3:51.948 or 231.948
Fastest Lap- 2.829
Chassis- RX28D Gen 3
Wheelbase- 98
Tires- PN KSM Medium front Marka V1RR15 rear 0/+3 offsets
Motor- NHX 2500
Batteries- Reflex 400
Front Springs- Gold
T-Plate- NA (built to manual specs, no different parts yet)
Motor Mount- Stock
Dampener Fluid (If applicable)- Kyosho 30K all around
Gearing- 14/53
Notes - This car is so fun to push hard and rewards you with some really fast laps. Messed with tires, wings, servo location and rear droop settings. Think I got it dialed and got a really consistent fast run to end the month after I turned the throttle dual rate down to 85% and turned the drag brake off on the ESC (I think it was only 5% but made a difference). Fresh KSM fronts really seemed to work for me, had plenty of grip. Got some different springs etc. to try just yesterday but not sure I'm going to mess with it yet.
Date- 3-31-26
Location- Omaha, NE
Fastest Lap- 2.829
Wheelbase- 98
Motor- NHX 2500
Front Springs- Gold
Motor Mount- Stock
Gearing- 14/53
#3561
Class- Porsche
Date- 2-28-26
Location- Omaha, NE
Race Time- 5:07.536 or 307.536
Fastest Lap- 3.575
Chassis- MR03
Body- 911 GT3RS
Wheelbase- 90
Tires- PN KSK 40 front Marka V1R10 0/0 offsets
Motor- Kyosho white cap
Front Springs- Purple
T-Plate- Kyosho FRP hard
Motor Mount- RML
Dampener (If applicable)- Kyosho RM disc
Gearing- 7T
Notes - Red headed step child this month, almost wasn't even going to post/run this car after the first try or two. Dealt with steering issues for a while but I think I got it sorted on this chassis so switched back to it from my Evo. Just couldn't get the handling dialed in, steering went from lazy to picking up an inside tire and steering right into the wall with not much inbetween. Maybe next month I can figure it out.
Date- 2-28-26
Location- Omaha, NE
Fastest Lap- 3.575
Chassis- MR03
Body- 911 GT3RS
Wheelbase- 90
Motor Mount- RML
Gearing- 7T
#3563
Class- BOX STOCK
Date- 3/23/2026
Location- Lake Forest, CA
Race Time- 4:22:69 / 262.69
Fastest Lap- 3.27
Chassis- Kyosho MR03 Rwd
Body- Corvette C8
Wheelbase- 98mm
Tires- Reflex 40 / Marka 15 worn down slicks
Wheels- Nexx 20mm/ Discs +1/ AMA Racing Interlock +3
Motor- Stock Silver Can
Batteries- PN 900
Front Springs- Kyosho Red
T-Plate- PN #4 Carbon
Motor Mount- MM2
Dampener (If applicable)- No
Dampener Fluid (If applicable)- Tamiya AW grease on upper shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Date- 3/23/2026
Fastest Lap- 3.27
Body- Corvette C8
Wheelbase- 98mm
Batteries- PN 900
Motor Mount- MM2
#3564
Class- Stock AAA
Date- 3/29/2026
Race Time- 4:07:52 / 247.52
Fastest Lap- 3.06
Chassis- PN2.5 MR03 RWD
Body- Jomu- missing back windows
Wheelbase- 98mm
Tires- Reflex35 / RR Marka 10 slicks
Wheels- Nexx disc 20mm +1/ AMA Racing Interlocks+3
Motor- PN 3500 kV
Batteries- PN 900
Front Springs- PN Red
T-Plate- PN Carbon #4
Motor Mount- Nexx LCG
Dampener (If applicable)- Nexx damper and dual spring shock (Kyosho Red 5k grease)
Dampener Fluid (If applicable)- Kyosho yellow 10k grease
Gearing- Spur 44T Pinion 14t
Note: Only change was front Reflex tires. Car was very smooth on Turn #5 with the Carbon #4 T plate. Gearing was 14t but could have squeezed more speed out with a 16t pinion.
Date- 3/29/2026
Fastest Lap- 3.06
Wheelbase- 98mm
Motor- PN 3500 kV
Batteries- PN 900
#3565
Class- Open Mod
Date- 3/31/2026
Race Time- 4:03:24 / 243.24
Fastest Lap- 2.78
Chassis- Team Associated RC28R/ Nexx upgrades Top deck and front DAA
Body- RadBody Mako
Wheelbase- 98mm
Tires- FR Reflex 35 / RR Marka 5 slicks
Wheels- Nexx / disc 20mm +1/ AMA Racing Interlock +3
Motor- Team powers 6000 kV (throttle DR 75%)
Batteries- Reedy 400 mah
Front Springs- Nexx DAA -Green
Motor Mount- Stock- Middle Roll Center
Dampener (If applicable)- NA
Dampener Fluid (If applicable)- Top Shock Kyosho Red 30k grease, Front Shocks Kyosho Yellow 15k grease
Gearing- 12T
Note: 2 x 7+ second mistakes on lap 23 and 70 kept me from a 3:50 pace. Car was very fast but took a long time to test the Reflex tires and adjusting the setup. Changed to Reedy ESC and still figuring out optimal settings for M96. Biggest change was reducing droop and changing top shock spring to a softer white. This allowed a smoother entry into turn #5 before the straight. Also turned DR down to 60% to get more consistency.
Date- 3/31/2026
Fastest Lap- 2.78
Body- RadBody Mako
Wheelbase- 98mm
Gearing- 12T
#3567
Class- PRO STOCK
Date- 07/03/2026
Location- Sicily, Italy
Race Time- 4.47 m
Fastest Lap- 3.503 s
Chassis- MR04
Body- Jomurema (with lexan roof)
Wheelbase- 98mm
Tires- front: marka v5f30 LP rear : marka v1rr10
Wheels- front nexx racing (with flanges) +2 rear nexx racing +3
Motor- xspeed black cap
Batteries- amazon basic 800mah
Front Springs- MR04 purple
Rear spring- kyosho yellow (harder one)
T-Plate- 4 marka fiber glass
Motor Mount- MM
Dampener Fluid (If applicable)- a little bit diff grease in rear shock piston and front knuckle
Gearing- 7t
Notes-
Date- 07/03/2026
Race Time- 4.47 m
Chassis- MR04
Wheelbase- 98mm
Motor Mount- MM
Gearing- 7t
Notes-
#3568
March 2026 Results
Well another month flew by, and we had some good racing across the board, and WELCOME to the new racers (Smokey84, Chad Davis, and George.fs)!!!!
This layout is very unforgiving, so these fast times are incredible to see! Joel had the FASTEST 75 Lap Run of 231.948, and Eric had the FASTEST Single Lap of 2.780!!!! SMOKIN to say the least!!!!
To the new drivers, please post your times, whatever they are! It's fun for us all to watch your times melt away as you learn this challenging 1/28th scale racing! We have a GREAT bunch of guys, and we are growing, so holler with anything as someone can usually get you fixed up quickly!
BOX STOCK
1) joelisenat----------- 259.490 / 3.156
2) ekim628------------- 262.690 / 3.270
3) Traveler2----------- 265.910 / 3.282
4) AM03GT------------ 275.002 / 3.528
5) CoryCliff------------ 275.672 / 3.319
6) chjosi---------------- 298.289 / 3.525
7) Smokey84--------- 344.855 / 3.927*
8 ) ChadDavis-------- 408.541 / 4.389*
STOCK
1) joelisenat---------- 243.895 / 2.998
2) Traveler2---------- 245.724 / 3.080
3) ekim628----------- 247.520 / 3.060
4) AM03GT----------- 267.765 / 3.305
PRO STOCK
1) joelisenat-------------- 254.256 / 3.019
2) CuriousDolphin------ 287.012 / 3.503
NARROW
1) Traveler2----------- 289.030 / 3.561
PORSCHE
1) Traveler2---------- 261.877 / 3.234
2) joelisenat---------- 307.536 / 3.575
UNOFFICIAL OPEN MX-5
1) BoxxerBoyDrew------- 274.534 / 3.401
2) Traveler2---------------- 289.030 / 3.561
OPEN 2WD
1) joelisenat---------- 231.948 / 2.829
2) Traveler2----------- 240.726 / 2.922
3) ekim628------------- 243.240 / 2.780
4) JarenStevens------ 256.863 / 3.035
5) CoryCliff------------- 269.932 / 2.837
6) BoxxerBoyDrew--- 287.053 / 3.311
7) George.fs----------- 316.059 / 3.632*
I included a few runs that didn't have the Mini96 "form" included with the time post, or were early runs, (me included this month, sorry!). It makes it very tough to know/find what is going on (especially on FaceBook). So if we could PLEASE completely fill out the Form (Class, Chassis, tires, etc..) it will help me out to make sure to get everyone included with the correct times and info!! To make it easy, I have a file for every class in the Notebook on my laptop, and just cut and paste each month and change the few things I change month to month on the car, and it is quick and you also wind up creating a notebook you can look back on quickly for running similar or the same layouts later on!
Again, THANKYOU to all who ran and posted them up!!! We only get stronger with more drivers and you with the more laps you turn. CCW is a little bit easier on this layout, IIRC, so hopefully the clean runs will come more often!
I'm trying to figure out some things that will help me drive more, with my radio, so I hope to come back strong this month!!
Take Care and Drive Fast Yall!!!!
BOX STOCK
STOCK
PRO STOCK
NARROW
PORSCHE
OPEN 2WD
I'm trying to figure out some things that will help me drive more, with my radio, so I hope to come back strong this month!! Take Care and Drive Fast Yall!!!!
#3569
How's yall runs going so far this month?
Mine , just ok! I've been working on my Stock and Open cars so far, and most my runs have been in the 4:30 range with my fast lap of 3.20x seconds.
I can't get a clean run. The highest consistency I've been able to hit is 85%, when I can usually get in the low 90%s.
I'm going to keep at it, and probably try to slow down a click or 2 and try to get the cleanest run possible.
Good Luck Yall!
Good Luck Yall!
#3570
Made some progress the last two nights. Need to be a lot cleaner to match last months times, the cars are all driving better than the results so far. Kind of the norm though for me in the challenge just getting the rhythm down and then chipping away at times. I'm a second behind in box stock but my best run so far was kind of a weird one, felt like the batteries just kind of went flat a third of the way in. Might have been me just trying to stay extra clean and running a slower line but it was very consistent (but slower) so I just kind of finished the run and then was happy with the overall time.
Stock car seems fast but I'm stuck with multiple (sloppy) runs near the same time.
Got the diff rebuilt in my RX28 after dealing with corner exit issues. Just way to squirrely getting back on the power and I didn't get rid of it till I took the diff apart. The coating on the axle is worn off where the inside plate of the thrust bearing sat (the 3 piece kind, not sure how to explain), so I'm not what went wrong (my grease job or the thrust bearing itself. I swapped it out for a normal ball bearing just to try (since that is how my other ball diffs are) and it seemed fixed/back to driving well. Down to a 4:06 so still behind last month but improving. Haven't matched some of the fast laps I had going the other direction but the car might be a touch easier to drive at this point.
3036Likes
