hyperion duo
Old 11-22-2009 | 03:10 PM
  #16
Suspended
Originally Posted by JAM MaxAmps
Ok let s keep on track with out making rude comments to those trying to help you. If you simply insist on being rude we can simply end this here and now.
Now as for the charger another thing you can try doing is cleaning all the electrical contacts. Charge leads, balance plugs the works. As for the durability of the hyperion chargers I still to this day use an original DUO with out any issues. They have a great track record.
-J
so how long odes it take you to charge a 4800 mah battery or whwatever battery u use? And where do i get firmware to download or install in this thing? Where can i get the usb wire or what not. I love my duo but it seems it is not working proper
PsycoB4 is offline
Old 11-22-2009 | 04:10 PM
  #17
oldsprintfan's Avatar
http://www.rcdude.com/servlet/the-91...ter-for/Detail
http://www.allerc.com/product_info.p...oducts_id=3091
http://media.hyperion.hk/dn/eos/
oldsprintfan is offline
Old 11-23-2009 | 03:21 PM
  #18
JAM MaxAmps's Avatar
Hyperion Updates: http://media.hyperion.hk/dn/pc/eosfw.htm and READ VERY CAREFULLY.
A 4800 Li-Po at 4.8 amps will balance charge in 80 to 90 minutes.
Jason
JAM MaxAmps is offline
Old 11-23-2009 | 04:29 PM
  #19
where can you get the usb adapter harness needed to download updates?
va.racer is offline
Old 11-23-2009 | 04:41 PM
  #20
http://www.maxamps.com/HYP-USB-COMBO.htm
Jason
Old 11-23-2009 | 04:55 PM
  #21
I just need to update the 610i duo.
I thought I only needed one adapter along with usb cable?
va.racer is offline
Old 11-23-2009 | 05:40 PM
  #22
If you have the original DUO or DUOII you need the kit I linked to. If you have the DUOIII it comes with the USB cord and plug for it built into the charger.
Jason
Old 11-24-2009 | 11:29 AM
  #23
Suspended
Allerc is cheaper. FYI. So I have the Firmware I guess I need off the site. Now I just get this Connectivity kit, and Then Update the charger. It should take away the problems?? I was reading that It also updates the chargers C rate at which the charger chargers?? Did I read that correct? Thank you for the help again Jason. Been very helpful so far.
PsycoB4 is offline
Old 11-24-2009 | 12:03 PM
  #24
FYI register as a member with us and you can get it cheaper than that place. As far as the updates solving your issue I can't say whether it will or not. The update will allow you to do a 2C rate for charging up to 10 amps.
Jason
Old 11-24-2009 | 12:08 PM
  #25
Suspended
Jason
Sweet thank you. When you register, How do you get your level up? And yeah I was readin up on that. I am a PC specialist And A electronic Freak.. So pretty much am smart with this kind of stuff.
Now if we Charge at 2c How much damage can or are you doing to the batter?? I know it cuts down my charging in half, but what are we really doing to the batteries?
PsycoB4 is offline
Old 11-24-2009 | 01:00 PM
  #26
...the way you post, I will bet a million dollars you are the annoying ahole that screams and yells nonstop up on the drivers stand
everyjuangohome is offline
Old 11-24-2009 | 01:33 PM
  #27
Suspended
yeah thats me in the corner, yelling screamming ohhh yeah holla
PsycoB4 is offline
Old 11-24-2009 | 02:32 PM
  #28
Right of the website:
NO STRINGS ATTACHED!
"Basic" 5% off (Every customer starts with a 5% discount)
"Bronze" 10% off (When total previous purchases are over $100)
"Silver" 15% off (When total previous purchases are over $500)
"Gold" 20% off (When total previous purchases are over $2500)
What else do I get?
Get invited to member only events such as sales, contests, free products, and more!
What does it cost me?
Nothing! The membership is completely FREE!
As far as charging packs at a 2C rate it doesn't cut the charge time in half. you might shave 10 to 15 minutes off but that's about it. And only do a 2C charge rate if your packs can handle it. Check the packs specs. Ours can handle 5C with no issues at all.
Jason
Old 11-24-2009 | 03:44 PM
  #29
Suspended
Does it put more strain on the battery? Does it cut its life in 1/2 ??? Does it hurt the battery? Please let me know thank you.
PsycoB4 is offline
Old 11-24-2009 | 04:24 PM
  #30
With our batteries, no. With other brands I can't answer that.
Jason
