Questions
I dont own a xxx4 and my xxxs is comming in the mail on monday but my gues is that the only thing thats interchangable is the actual chassie. because the arms, shocks, and shock towers are different. outherwise they preaty much the same i think.
R/C Tech Founder
I would assume the battery strap stuff is the same, the rest I am not so sure on. You could compare part numbers on Losi's website perhaps.
I'll have a XXX-S at the track this Sunday if someone has a XXX-4 we could always compare.
prodirt, The short answer is a motor with a single wind will have more torque and slightly less rpm than a motor with 2 or 4 winds, given the same number of turns. The more winds the more rpm but it will take longer to "spool" up and not have the pull off the cornners. This is all relative to proper gearing.
I don't know of any production motor below a 6 turn. A 6 turn pulls alot of amps, so much that many sport speedo's can't handle the current.
Originally posted by prodirt19
how do you paint bodies chrome?
Set your compressor to about 12psi, shoot it from the bottle, no thinning. Do about 2-3 light coats, hold it up to a light to check for thin spots. Fill them in, and back it with either black ( deep chrome, but shows thin spots ) or with silver ( hides thin spots, not the "deep chrome" though.. )
I also suggest backing everything with white afterwards, just to put some extra protection over the chrome areas
R/C Tech Founder
The Monster Pro is a dyno-tuned version of the monster that has been produced by Trinity. The Team 1 motor is also a dyno-tuned version of the monster, but produced and "re-labeled" by Team 1. Both versions are the same motor, just tuned by different people.
So, whichever one works. I usually would buy the Team 1 since they are more of a local company.
