View Poll Results: JPRaceway : On-road or Off-road?
On-Road
![](https://www.rctech.net/forum/images/polls/bar2-l.gif)
![](https://www.rctech.net/forum/images/polls/bar2.gif)
![](https://www.rctech.net/forum/images/polls/bar2-r.gif)
![](https://www.rctech.net/forum/clear.gif)
60
69.77%
Off-Road
![](https://www.rctech.net/forum/images/polls/bar3-l.gif)
![](https://www.rctech.net/forum/images/polls/bar3.gif)
![](https://www.rctech.net/forum/images/polls/bar3-r.gif)
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
![Red face](https://www.rctech.net/forum/images/icons/icon11.gif)
Vic, it stop with your last post. We have tickle friends to post and reply. Kumusta yung Frontier 20 mo? Lumipad na ba? I have 4 fuselages here of that plane and the foam cores. We assembled one wing. Am finishing a fully sym wing,no dihedral, from a plane called The Mystique. had this orig years ago but has since crashed it. I kept the plan. Fantastic flier. It's an intermediate, fully sym and fmakes no difference flying inverted. I am going to try it on an Edge 540 fuse, 40 RC ngine BB.
Been reviewing a great book by Model Airplane News. Lots of fundamentals on airfoils, planforms, stabs, fins etc and on flying like take off and landing with a crosswind. I will be glad to discuss with any modeler who wants to be serious on these topics. lots of linggo like pitching moment, stall angle, AoA, etc. Nung nagumpisa kame, basta binili namin ang kit, lumipat, ok na. pero habang tumatanda, nakaka interest naman sa fundamentals. Might skip tomorrow too sa Niog. We will probably take off an orig mosquito here inside BF for a test flite. Hope it will be dry tomorrow.
BravoKilo
BravoKilo
![BravoKilo is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
For Sale Brand New Yokomo Cgm Parts
MR-4TC SD
-Arms For Front or Rear SD-008
Php 280.00
-Front Gears For 1way SD-503
Php 200.00
-Rear Diff Gears SD-643
Php 200.00
-Carbide Ball Diffs. ZD-505T Can Be used for MR-4,RC-10TC3 Size 3/32
Php 580.00
-2 Hub Carriers SD-415
Php 325.00 Each
Get It All For 1.8K only Fix
Txt Or Call 0906 3608404
Looking For :
-1 Pc. or 2 pcs. Loose Single Cell 3300 Mah Ni-Mh , With Good #s Pls.
MR-4TC SD
Php 280.00
Php 200.00
Php 200.00
Php 580.00
Php 325.00 Each
Looking For :
![Minimi is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
XRAY FK05 KIT COMPLETE WID BOX AND MANUAL (FRESH)
7500 PESOS ONLY
SANWA VR HIGH SPEED SERVO (FRESH)
3000 PESOS ONLY
PLS CONTACT ME AT 0917 8589589
7500 PESOS ONLY
3000 PESOS ONLY
![dtn324 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
![curious mind is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
MR-4TC SD
Php 280.00
Php 200.00
Php 200.00
Php 580.00
Php 325.00 Each
Looking For :
MR-4TC SD
Php 280.00
Php 200.00
Php 200.00
Php 580.00
Php 325.00 Each
Looking For :
Competition Electronics Pitbull X3 (alagang-alaga very very good condition)
Competition grade charger for all NiCd or NiMh cells.
-Multiple rate charge mode to customize your charge profile and get maximum performance from your packs.
-5 setups that you can name to charge all kinds of NiMh & NiCd battery packs.
-Backlit display monitors Mah, volts and amps.
-Preprogrammed for use with common battery types
Dimensions 5" x 4" x 2.5"
12 to 15 volt DC supply required
Specifications:
Peak detection linear charging from .15 to 7 amps and 4 to 7 cell packs.
Backlit 32 character displays a built in volt meter ammeter and Mah.
Shows cell data including time and milliwatt hour values.
Over 20 selectable sounds.
Selectable long lockout for 10 minutes of charge without peak detection.
Selectable trickle after charge.
Settable peak detect range .012 volts to .192 volts.
FEATURES INCLUDE:
5 charge setups that you can name with up to 8 characters each for charging all 4-8 cell NiCd and NiMh packs.
Multiple rate charge mode to customize your charge profile by setting up to 3 different amp rates at selected points during a charge. Trickle charge at the beginning to stabilize the voltage if you dead short your packs. Lower the rate for the last part of the charge for a cooler final temp. or raise the rate for the last part of the charge for higher voltage and initial punch.
Display shows mah output to battery pack as it’s charging.
includes:
box and manual
1 extra 10amp fuse
i am from cabanatuan city, nueva ecija, the buyer will handle the shipping. (shipping costs only 200-300 pesos)
reason for selling upgrading radio system
6k 0927-919-9496
Specifications:
FEATURES INCLUDE:
includes:
box and manual
1 extra 10amp fuse
6k 0927-919-9496
![nikkiesteban is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
a slighly used Team Associated TC4 RC
item is ready to race and complete
description of items included:
2 complete Team Associated TC4 chassis:
1 fully upgraded and hopped up (aluminum parts, titanium screws, one-way, ball bearing etc.) and another complete Team Associates TC4 rolling chassis (also upgraded)
futuba 3 PJ transmitter (3 channel FM transmitter) 75 mhz
futuba servo (s 9402)
futuba reciever (pcm 1024)
Keyence digital ESC (no limit) (reserved)
stock motor
4 sets of matched 3300 mAh batteries
1 set of batteries for the transmitter
hobicco power supply (reserved)
swallow digital discharger / charger (sold)
duratrax car stand
mitsubishi eclipse body
complete set of tools so you can modify the car and
lots of spares so you won't have to buy spares once you accidentally crash the car
you can see the car at banawe area, just text me the night before.
car and all accessories are in very good condition.
reason for selling, don't have time anymore to play.
you can text me at 0919-8222288 for any queries and offers.
many thanks!
stock motor
duratrax car stand
many thanks!
![yellowcivic is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
edited
![|JayFlores| is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Vic, it's Sunday., nagpost ako kagabi. nawala. There was something I did wrong..perhaps. Yung last post sa yo. I would like to contribute and tickle discussions..Just reviewed theories on wing airfoils,semi ,fully sym, flat bottoms,MAC, stabs and fins, pitching moments etc..Taking off and landing during crosswinds by Dave Patrick.
I just glued the LE sa wing ng Frontier 20, half round wood , medyo blunt pero maganda daw ito, hindi masyado malikut and wing. may spars up and down and wood TE too. dilute white glue at pahiran and manila paper to cover, mag sag sa una, tapos babatag yan. ulitin. Nawawala and pores ng foam. Ayun, next choose Solarfilm, vynil, colored tape. Mas ok kung may white latex primer. Litw ang kulay. Yung isa ay fully sem wing 56 inch WS galing sa plano mg "mystique" orig kit I bought years ago. The orig flew very nicely, fat wing to, 2" thick and that is 20% of chord. Ganda recovery, similar speeds sa climb at dive. No dihedral. Ang cutter namin 60 inches so we can cut one piece. Thick spars for strength. Malkasand centrifugal weight vs the wings g pang aerobatics. Pang 40 ito. Ang fuse ay look alike ng edge 540, na dilaw. baka i-test flite next Sunday na.
Ok, nandito pa itong orig J340, full WS at isang fully built P51, parejo for sale. See to appreciate...May Happy 20 orig dto ni MK (Japan). Super light.
Have a nice day, everyone....
Bravo Kilo
Bravo Kilo
FOR sale or swap:
Futaba Digital 2PL AM with Box and Manual bought last march sa Lils
Super kinis, may plaster pa sa Screen, 10 Model Memory
will include:
* 1 Hi Torque servo (ears cut top left and bottom right)
* 1 Reciever
* Xtals
* 1 sports tuned motor
* 1 mabuchi motor
kung mas maganda pa sa 3pj...ill add:
* Tamiya 3300 Racing Pack with box (good condition)
* ST Knights of the Old Replublic Orig PC game with box
swap with
Futaba 3PJ TX, RX, Xtals or any FM TX and RX na pwede sa Futaba S9402
Servos ko...must be in good condition.
PM or Text your offers 09279757129
will include:
* 1 Reciever
* Xtals
* 1 mabuchi motor
swap with
![movingparts is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
For sale:
Powerline Ball Differential Set for Mini-Z - P500
(good as new, just opened the pack but didn't get to use it. di kasi kasya sa IW02)
Looking for...
MR-4TC SD LCG Team Suzuki Rear hub carrier
0920.9245081
found! thanks!
Power Supply - decent 2nd hand
Sanwa M8 dry battery tray - sana dumating
Sanwa M8 battery port cover - sana dumating
MR-4TC SD LCG Front Rear suspension mount (pref aluminum)[/QUOTE]
Looking for...
0920.9245081
found! thanks!
![VooDooPH is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
HPI R40 For Sale!!!
HPI R40 kit
will include:
- MEGA .12 zx12 outlaw engine and pipe (never raced, good condition)
- one flat pack battery (speed mind)
- one standard starter box (I used a motorcycle batt., will include it as well)
- all necessary oils (after run, shock, etc.)
- three bodies (one for bashing)
- has a few hop ups
- extra parts
- fuel (about half a gallon)
*no electronics
All for P15000!!! (negotiable)
*Engine only - P8500
*HPI R40 kit only - P4500
* 09177000289 *JUST WANT TO GO OFF ROAD!!!*
*Trade for used hellfire or savage
HPI R40 kit
will include:
- has a few hop ups
- extra parts
*no electronics
![istib is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Yokomo BD- Brandnew - P15,000.00
Text t 0917-884-44-24
![DRIV3R is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
9th TAC - The Philippine Qualifying Championships
Round 6/June 4, 2006/JP Raceway
Stock Touring Class
1st Rey Parco
2nd Michael Robertson
M-Chassis Class
1st Jonathan Jao
2nd Jygs Tiangco
3rd Tutoy Aldaba
Buggy Class
1st Jygs Tiangco
2nd Norman Cruz
3rd Dax Dacayan
GT-1 Stock Class
1st Joseph Salcedo
2nd Noel Aldaba
GT-2 Modified Class
1st Joseph Salcedo
2nd Jonathan Jao
3rd Tutoy Aldaba
XB Class
1st Anton Ramos
2nd Raymond Aves
3rd Daniel Roque
4th Patrick Crespo
5th Alexander Robertson
6th Anakim Colico
7th Jomil Dela Cruz
8th Christian Aves
Round 7 on June 18, 2006 @ JP Raceway
Stock Touring Class
1st Rey Parco
M-Chassis Class
1st Jonathan Jao
2nd Jygs Tiangco
3rd Tutoy Aldaba
Buggy Class
1st Jygs Tiangco
2nd Norman Cruz
3rd Dax Dacayan
GT-1 Stock Class
1st Joseph Salcedo
2nd Noel Aldaba
GT-2 Modified Class
1st Joseph Salcedo
2nd Jonathan Jao
3rd Tutoy Aldaba
XB Class
1st Anton Ramos
2nd Raymond Aves
3rd Daniel Roque
4th Patrick Crespo
6th Anakim Colico
7th Jomil Dela Cruz
8th Christian Aves
![Rnold is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Points Standing as of Round 6
Stock Touring Class
Inigo Bilbao 107
Rey Parco 92
Allan Colico 87
Michael Robertson 18
Lexter Sy 15
Jason Yu 14
M-Chassis Class
Jygs Tiangco 109
Jonathan Jao 107
Tutoy Aldaba 98
Joel Mangilit 50
Norman Cruz 44
Allan Colico 30
Alan Reyes 26
Martin Marquez 23
Joseph Salcedo 14
DJ Mangahas 12
Buggy Class
Jygs Tiangco 123
Dax Dacayan 108
Norman Cruz 87
Tutoy Aldaba 46
Pete Guererro 44
GT-1 Stock Class
Noel Aldaba 117
Joseph Salcedo 105
Raymund Aguilar 66
Chito Detabali 16
Benedict Ty 15
Julius Sabularse 15
GT-2 Modified Class
Joseph Salcedo 123
Jonathan Jao 97
Benjamin R. Yalung Jr. 33
Jason Rodriguez 16
XB Class
Raymond Aves 89
Daniel Roque 83
Patrick Crespo 81
Anton Ramos 81
Alexander Robertson 65
Anakim Colico 62
Jomil Dela Cruz 50
Christian Aves 46
Homer Colico 43
Stock Touring Class
Inigo Bilbao 107
Rey Parco 92
Allan Colico 87
Lexter Sy 15
Jason Yu 14
M-Chassis Class
Jygs Tiangco 109
Jonathan Jao 107
Tutoy Aldaba 98
Joel Mangilit 50
Norman Cruz 44
Allan Colico 30
Alan Reyes 26
Martin Marquez 23
Joseph Salcedo 14
DJ Mangahas 12
Buggy Class
Jygs Tiangco 123
Dax Dacayan 108
Norman Cruz 87
Tutoy Aldaba 46
Pete Guererro 44
GT-1 Stock Class
Noel Aldaba 117
Joseph Salcedo 105
Raymund Aguilar 66
Chito Detabali 16
Benedict Ty 15
Julius Sabularse 15
GT-2 Modified Class
Joseph Salcedo 123
Jonathan Jao 97
Jason Rodriguez 16
XB Class
Raymond Aves 89
Daniel Roque 83
Patrick Crespo 81
Anton Ramos 81
Anakim Colico 62
Jomil Dela Cruz 50
Christian Aves 46
Homer Colico 43
