View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Selling Machined Aluminum and Bronze Parts
For V-one RRR
- Aluminum Rear Shock Stay P1600
- Aluminum Front Shock Stay P500
- Lightened bronze alloy 1st spur gear 0.8m/61T P3000
- Lightened bronze alloy 1st spur gear 0.8m/60T P3000
For Team Losi XXX-4
- Aluminum Rear shock tower - P1600
- Aluminum Front shock tower - P1600
- Aluminum Front Pivot/Pin Mount 7.5deg - P1200
- Aluminum Rear Pivot/Pin Mount 7.5deg - P1200
All prices are still negotiable.... prices may vary if ordered in volume..
I can also offer other machined parts for V-one R, AE TC3, aside from V-oneRRR and XXX-4. just PM me or call/text at 09178571816
PS: Items can also be Chromed beautifully for an additional P400
For V-one RRR
For Team Losi XXX-4
Looking for radio:
3pk, m8 or helios
to trade with
PS2 SLim 2nd release Bnew
1xdualshock2 controller
online startup disc
av cable
power cable and adaptor
box and manual
For sale:
TL01 Stadium Raider
Full ball bearings
Adjustable Tie Rods
Lightweight Kingpins x 3
aluminum Hex hubs
Speed Tuned Gears
Wheels and tires
body
spares (bumper, tie rod, stock gearing system, arms)
will include BYD 1300mah Battery Stick Pack
Mabuchi Stock motor
Mechanical Speed Control, needs rewiring
2pcs Universal Drive shafts
3.5k
TG10 MK1
Subaru Body WRC 99
Wheels and tires
Fuel Tank
Exhaust system
box and manual
2 speed tranny
VR15S engine
5k if you opt to buy the car only, no engine that would be 2k or give be your best offer.
TGX Mk1 TS
1.8th scale
VR15S engine
few scratches on the chassis
2 speed tranny
with body (good as new Toyota Supra Tamiya brand)
wheels and tires
exhaust system
engine mount
box and manual
5k
Selling for a friend:
RC18MT RTR 7k neg Good as new just opened box and tested the vehicle inside the house and back to the box.
Refer to pic
Hobao GPX4 Pro Front One Way Fresh! pm me an offer.
3pk, m8 or helios
to trade with
online startup disc
av cable
box and manual
For sale:
TL01 Stadium Raider
Full ball bearings
Adjustable Tie Rods
aluminum Hex hubs
Speed Tuned Gears
Wheels and tires
body
Mabuchi Stock motor
3.5k
TG10 MK1
Subaru Body WRC 99
Wheels and tires
Fuel Tank
Exhaust system
box and manual
2 speed tranny
VR15S engine
TGX Mk1 TS
1.8th scale
VR15S engine
2 speed tranny
wheels and tires
exhaust system
engine mount
box and manual
5k
Refer to pic
NEW ARRIVALS
DC Motorsports NEW ARRIVALS!!!
- Extreme Voltage Intellect Batteries 4200, 6-Cell Pack, 35 Amp 1.120v+ Matched & Zapped Cells
- Battery Bars
- New Z-Zone Evo-27 (New generation rebuildable Stock motor)
Features:
· 27 Turn 22 gauge wire
· 24 degree fixed timing
· Low Friction Bushings
· 3 surface mount capacitors built-in with blue LED indicator
· 6 large venturi cooling vents
· Extensive use of copper material on endbell to keep operating temperature low
· Extended armature shaft for easy tech inspection
· Low armature mass for quicker spool up
· Use normal laydown springs and standard laydown brushes
· Easy to tune
· Meets all ROAR & NORRCA mechanical specification.
The Evo-27 stock motors are hand tuned and tweaked for maximum performance. Here’s a list of what every spec motor receives…
-Magnets Zapped
-Armature Balanced
-Diamond trued commutator
-Armature shaft polished
-Bushings reamed and polished
-Armature centered in magnetic field
-Brush hoods aligned to provide proper brush/comm commutation
-Spring tension optimized for maximum performance.
-Commutator timing inspection; insure overall motor timing is not less than 24*
-Each motor is dyno tuned & tested using CE Turbo 45 dyno.
-Dyno sheet included
DC CHECKPOINT with UL ARMS WILL BE ARRIVING SOON TOO
VISIT THE SHOP TO SEE
- Battery Bars
Features:
· Easy to tune
-Magnets Zapped
-Armature Balanced
NEW ARRIVALS
PONTIAC 190mm
STRATUS 3.0 and 3.1 -- STILL THE #1 BODY FOR RACING
BACK IN STOCK
MOAB XL
CRIME FIGHTER FOR MT'S
and lots of bodies for all your Monster Trucks!!!
for the Revo, Tmaxx, LST2, Mayhem ST, Monster GT, Emaxx, Stampede, etc...
23mm hex now back in stock!
PONTIAC 190mm
BACK IN STOCK
MOAB XL
ESCs...
Looking for cheap ESCs...
PM me. Thanks!
PM me. Thanks!
sanwa reciever
looking for a sanwa 40.735 mhz AM tx reciever. maybe you have one and don't need it. benta nyo nalang sa akin. para naman tatakbo itong old r/c ko. so i can give it to my cousin kaysa sa basura. sayang naman. or maybe u have a complete set of radio with reciever and two servos yung cheap lang like the futaba attack.
pm or txt me. 09215695994
TAC racers, pls post here what class you wanna join. and please include your frequency ng radio ninyo so we can sort it out agad...
GT2 Class
1. Jygs Tiangco (40.710)
2.
3.
4.
5.
Mini Cooper Class (M03)
2. Rey Parco (40.610)
3.
4.
5.
Buggy Class
2. Raymund Aguilar (27.145 AM)
3. Dax Dacayan (40.630)
4.
5.
Stock Touring Class
1.Emerson Reyes (75.80 FM)
2.Inigo Bilbao (27.095)
3.Daniel Roque(75.410 AM)
4Chito Detabali(27.045)
5.Rey Parco (40.610 FM)
GT 1 Class
1. Raymund Aguilar (27.145 AM)
2.
3.
GT2 Class
2.
3.
4.
5.
3.
4.
5.
Buggy Class
4.
5.
Stock Touring Class
GT 1 Class
2.
3.
Yokomo GT4 parts
Originally Posted by pitshop
NEW ARRIVALS
PONTIAC 190mm
BACK IN STOCK
MOAB XL
PONTIAC 190mm
BACK IN STOCK
MOAB XL
I called about two weeks ago...and heard you still had some Yokomo GT4 parts... Could you PM me what parts you have?
Vic [aka Neoraacer]
For sale
Selling my Kyosho Landmax II 1/8 scale (MP 7.5 chasis) All stock. 7k
Engine: GS21-R (disfunctional recoil starter)
Body: Subaru Impreza WRC (Blue)
No Electronics.
No Electronics.
looking for
Im looking for any 3ch FM rx with 41mhz freq, futaba, sanwa, jr, ko etc.
PM me....
PM me....
STILL LOOKING FOR THE FF.:
Originally Posted by MOTO
Looking For:
4 pcs High speed High Torque Servos
1 High End Gyro
1 8 channel Reciever
PM me. Must be in good working order. Will pay Cash!
1 High End Gyro
sale swap
4 mini alloy shox 500
asstd mo1 mo2 plastic parts 400
27mhz am rx 300
4 pcs minizilla compatible tires wala katulad 500 set
75 mhz square transmitter futaba 2f brand 1k
sms 09155593590 rhanks for looking
27mhz am rx 300
edited
QCRCCC & PITSHOP CAFE'
Present The First Annual:
"In The DIRT"
Off-Road Series!!!
RACE DATE: SUNDAY Morning, MARCH 12, 2006.
REGISTRATION STARTS AT: 9:00 A.M.
RACE START: 9:30 A.M.
VENUE: Q.C. CIRCLE!
RACE CLASSES:
EP - 2WD
EP - 4WD
EP - RALLY
EP - STADIUM TRUCK
NITRO - TRUGGY
NITRO - MONSTER TRUCK
For New Members who want to join and sign-up with the Club, the annual membership fee is P800.00. This entitles members to practice on the track for FREE - 7 days a week! Members also receive discounts on QCRCCC racing fees and are eligible to win Raffle Prizes during QCRCCC Big Races! Please look for any QCRCCC Officer at the Track and join us!
THIS IS "IT" BOYZ!!! A TWO SERIES OFF-ROAD RACE BY QCRCCC & PITSHOP CAFE'!!! TONS OF PRIZES TO BE EARNED & WON! COME JOIN US THIS SUNDAY MORNING TO KICK-OFF THE START OF THE FIRST "In The DIRT" ANNUAL OFF-ROAD SERIES RACE!!! THE ACTION IS SURE TO BE EXTRA HOT THIS WEEKEND!!! PLEASE TRY TO MAKE IT TO CIRCLE EARLY THAT WAY WE CAN ALL START ON TIME! TWO ROUNDS OF QUALIFYING WILL BE INTRODUCED FOR GRID POSITIONS IN EVERY CLASS! TWO ROUNDS OF ACTUAL INSANE OFF-ROAD RACING WILL THEN SOON FOLLOW! SEE YOU ALL THIS SUNDAY MORNING FOR THE BATTLE...."In The DIRT"!!!
AGAIN, LET'S DO OUR BEST TO START ON TIME!
