Go Back  R/C Tech Forums > International Forums > Manila Racers
The Big Locked Thread >
View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
Like Tree1Likes
Old 03-19-2014, 05:36 AM
  #88426
legimlugero's Avatar
BUY THE LOT FOR P 4,000.00
SHELLS:
Unpainted Shells:
Frewer Acura Integra (cut, film still intact) with unused decals P 1,600.00 down to P 1,450.00
NIP Tamiya Castrol Civic EG complete decals P 2,500.00
Tamiya Interior and driver with accessories P 800.00
OR Civic EG shell and driver interior bundle P 2,650
ESC:
Speed Passion Exige Sport Tuned motor BL system:
working but glitching (cogging) contact Bravokilo of RCtech to have it checked. P 1,000.00
Others:
Used Tamiya Super Stock RZ motor P 400.00 Sold thanks buyer!
Tamiya RC Pack Discharger P 300.00
All items must go!
Contact no: 0918-579-6580 PM and text lang po for inquiries. Di po lagi on-line. Tawad tawad lang, kung reasonable naman, madali akong kausap. Every Sunday lang po ako pwede, under 1.5K purchase, will schedule with other buyers, layo po kasi ako, talo pamasahe. />
NOTE: Pls. include your name and handle here in RCtech or PRCD.
No name or handle SMS will not be entertained. Thanks
Thanks sa mga Buyers!
Thanks RCTECH!
legimlugero is offline
Old 03-19-2014, 08:50 AM
  #88427
Smile For Sale: Brand New Lipo Batteries
All Batteries are good quality and freshly made in Singpore: Includes JST XH balance connector and 4MM discharge sockets ( Please choose if you need deans, xt150 or xt60 discharge plug.
TURBOCHARGE 4200mAh 2S 25C LiPO Rounded Case 1,500
- Size: 24.5mm thick x 47mm W x 139mm L, Weight: 215 grams, Ratings: 25C. Cont. 50C
TURBOCHARGE 7700mAh 2S 40C LiPO HARDCASE 2,600
- Size: 25mm thick x 47mm W x 139mm L, Weight: 335 grams, Ratings: 40C. Cont. 80C Burst. 5C Charge Rate
TURBOCHARGE 4000mAh 2S 50C LiPO HARDCASE 1,600
- Size: 25mm thick x 47mm W x 139mm L, Weight: 216 grams, Ratings: 50C. Cont. 90C Burst. 3C Charge Rate
TURBOCHARGE 3700mAh 2S 60C LiPO HARDCASE 1,600
- Size: 25mm thick x 47mm W x 139mm L, Weight: 250 grams, Ratings: 60C. Cont. 120C Burst. 6C Charge Rate
TURBOCHARGE 6600mAh 3S 40C LiPO Pluspack 3,300
- Size: 36.6mm thick x 47mm W x 139mm L, Weight: 484 grams, Ratings: 40C. Cont. 80C
Shipping may cost you around 150-250 depending on your location.
Getting Pre-orders (Depends on stock availability) Pls PM if interested. Batteries will arrive nextweek.
Attached Thumbnails The Big Locked Thread-tc3500.big.jpg   The Big Locked Thread-tc6000.big.jpg
japong is offline
Old 03-19-2014, 09:36 AM
  #88428
cocojam's Avatar
Trader Rating: 47 (100%+)
Default FOR SALE
- Tamiya Formula Tuned Motor (3x used) - 900
- Tamiya F104 Rear Rubber Tires (New, #51400) - 250
- Tamiya F103 Rear Foam HBR Tires mounted (3x used) - 450
- Muchmore Motor Master (like new, Rheinhard edition) - 4500
- Muchmore Tire Warmer (slightly used, Blue, TC) - 2000
- Hitec Focus 4 channel FM TX with 8 ch RX (used) - 1500
- Turnigy A-6-10 200W Balance Charger (10 amps) & Discharger (5 amps) very slightly used - 2200
Please pm or text at 09178134161 if your interested. I can send pics upon request. Prices are negotiable as long as offer is reasonable. Meet-up Ortigas area.
RFS: Excess stuff
Thanks RCTech
cocojam is offline
Old 03-19-2014, 07:05 PM
  #88429
Default brushless combo for 1/8 and 1/10
Team orion r8 130amp up to 4s lipo
Specs:
IGHLY CUSTOMIZABLE SOFTWARE
EASY TO USE
130A HIGH PERFORMANCE ESC FOR 1/8 OFF-ROAD
FOR SENSORLESS 2 AND 4 POLE MOTORS
COMPACT AND LIGHTWEIGHT (1/10 ESC SIZE)
CARBON LOOK
FOR 2S-4S BATTERIES
INTEGRATED COOLING FAN AND CAPACITORS
ADJUSTABLE FORWARD/REVERSE OR FORWARD/BRAKE FUNCTION
MANY ADJUSTABLE PARAMETERS
LATEST BRUSHLESS TECHNOLOGY WITH IMPROVED FUNCTION AND EFFICIENCY
HIGH POWER
GREAT THROTTLE/BRAKE FEELING AND CONTROL
EASY SETUP USING THE SWITCH SETUP BUTTON
SOFTWARE WITH MANY ADJUSTABLE PARAMETERS FOR FINE TUNING
LED AND AUDIO TONE FOR STATUS CONTROL
HIGH GRADE COMPONENTS WITH LOW RESISTANCE
AUTOMATIC BATTERY CUT-OFF SYSTEM
COMPACT SIZE CARBON LOOK ABS CASE
R10PRO VERSION WITH CUSTOM ALUMINUM CASE FOR IMPROVED COOLING AND EFFICIENCY
HIGH POWER CONNECTORS
Turnigy trackstar 3190vk brushless motor 4 pole
Specs.
# of poles: 4
Max Amps: 110A
Max Volt: 11.1V
Max Watts: 1220W
Rpm/V: 3190kv
Resistance: 0.0060 ohms
No-load Current: 5.0A
Dimension: 36.0mm x 65.0mm
Mounting hole depth: 45mm
Length of extend Shaft: 185mm
Shaft diameter: 5mm
Weight: 262g
For only 5.5k txt me @ 09335520500
Attached Thumbnails The Big Locked Thread-ori65104.jpg   The Big Locked Thread-17715.jpg
aljulie is offline
Old 03-19-2014, 11:16 PM
  #88430
jmc12's Avatar
Trader Rating: 69 (100%+)
selling
1. bnew savox sc1251mg
0.09 speed
sealed
*free shipping
price 3000
2. Tamiya brat
Chrome edition
Rolling chassis only
Ran 1-2x only
Price 4500
3. Hpi e10
Rolling chassis
Full ball bearing
Touring set up
Sports tuned motor NOT included
Slick touring tires included
Fresh in and out (like-new)
Price 2000
4. Active hobby cs gears for tt01
Cs rates 76% and 100%
price 1900/set
other items listed here
https://www.facebook.com/pages/MTech...=photos_albums
price indicated per picture
09328618338
Attached Thumbnails The Big Locked Thread-1900004_1474297906116922_1519319518_n.jpg   The Big Locked Thread-1941374_1479340868945959_1052393541_o.jpg   The Big Locked Thread-1271123_1418387521707961_1595904583_o.jpg   The Big Locked Thread-1902786_1481013182112061_308352913_n.jpg
jmc12 is offline
Old 03-20-2014, 01:56 AM
  #88431
LF: wheel hex adapter/converter 12mm to 14mm/17mm...
09178060487
honerbunch is offline
Old 03-20-2014, 02:18 AM
  #88432
bentoy101's Avatar
Trader Rating: 74 (99%+)
Default For Sale
FOR SALE or SWAP!!![COLOR="Lime"][B]
SELLING SOME ITEMS FOR CHEAP FOR DONATION!!!!
1) HONGNOR 4x4 SCRT10 FULLY Upgraded short course truck 11,000 php Only!
Too many to mention upgrades. check the pics. What you see is what you get except for the mamba monster esc!
Hong Nor Scrt10 Kit version
Speed Passion Sensored 3.5 brushless motor
Proline wheels in Losi Eclipse tires
Hong Nor CNC C hub
Hong Nor CNC Kncukle arms
Hong Nor CNC Rear Hub
Hong Nor CNC front and rear shock Towers
T-Bone Racing Front Bumper
Proline Ford Raptor Body
2) HPI ESE Blitz kit w/ MIP Ball diff 5,500 only!
Comes with proline chevy body as well
3) HOBAO Hyper Mini STE kit (12th scale) 6,000 php Only!
4x4 with 3 differential truggy! SUPER DURABLE!
2) REDCAT Tornado Truggy (8th scale) 8,000 php Only!
4x4 truggy kit with free brushless motor! SUPER DURABLE!
3) CASTER RACING Buggy MMM POWERED ARTR (8th scale) 13,000 php Only!
8th scale 4wd buggy mamba monster max powered buggy! SUPER FAST!
2) Turnigy 2100kv 8th scale BRUSHLESS motor! 2,200php Only!
Almost NEW! Ran less than 8 packs! Up to 4s. 36mm by 65mm yung size! Installed in my nanda buggy and tried in my redcat avalanche and it was CRAZY FAST! Never overheated!
3) Traxxas Slash STRC LCG Converted kit 6,000 php Only! FREE SHIPPING NA! LESS 1,500php na!
Letting go of my beloved HANDLES LIKE A DREAM and BETTER than my BLITZ ese!
SWAP to DX3S,DX3R, 3PK, or 4PL Radio and receiver combo!
Package Includes:
FRESH Traxxas Slash 2wd chassis (converted to LCG na)
STRC LCG Conversion kit
Rustler Chassis
RPM Knuckle arms
RPM Rear Hub Carriers
RPM Rear Arms
Traxxas Alloy Shock Caps
BRAND NEW Proline FORD Shell (painted Tamiya Met Blue)
USED hyper 10TT wheels and tires
3) PROLINE Ford Body for SC 2,400 php Only!
BRAND NEW with scale lightbar, DIY lights. Holes are for traxxas slash. Fits MOST 10th scale SC's. Painted tamiya metallic blue!
4) EZrun Program card 450 php Only! HATI TAYO SHIPPING
5) Turnigy TRACKSTAR Program Card 500 php Only!
David Suico
NEW NUMBER!0922-4195930
ITEM IS IN CEBU
SHIPPING IS THROUGH LBC!
bentoy101 is offline
Old 03-20-2014, 09:36 AM
  #88433
Trader Rating: 14 (100%+)
mikeygar is offline
Old 03-20-2014, 03:30 PM
  #88434
densanity's Avatar
Default for sale
HPI racing Muchmore ac/dc charger
with Muchmore cell balancer
acdc patrick model
SOLD! 03/21/14
densanity is offline
Old 03-20-2014, 09:59 PM
  #88435
xands05's Avatar
Default Tamiya teu 105bk
Originally Posted by xands05
Looking for Teu 103bk or teu 105bk.. 2nd hand only but in good condition.
PM me your offers.
up
xands05 is offline
Old 03-21-2014, 02:07 AM
  #88436
jether's Avatar
Default ....
jether is offline
Old 03-21-2014, 02:23 AM
  #88437
STEALTH's Avatar
Trader Rating: 21 (100%+)
Default Early 1980's Off-Road Racing...
Circa 1983... This is what I remember when I first started getting into the hobby... It was probably 8 or so months before the Original AE RC10 Gold Tub was officially released in 1984 (and its subsequent domination of every track around). Tamiya & Cox/Kyosho kits were the preferred choice by many... I got myself a Tamiya Super Champ for a Grade 7 Graduation Gift...
These were the days of crude home made parts, modifications and hop-ups. In some ways (and in retrospect), it was a magical time to be I the hobby despite all the limitations... Nothing like seeing your own home made mod work to improve your kit!
Here are some nostalgic pics for those who were into the hobby back then...
STEALTH is offline
Old 03-21-2014, 08:48 AM
  #88438
Ogawa_Seiki671's Avatar
Default Greetings from Guam.
Anyone in the P.I run r/c's?
Ogawa_Seiki671 is offline
Old 03-21-2014, 03:02 PM
  #88439
Update last item...
Speed passion 4.5t modified motor bnew 2k na lang.
Pls sms...09209706001
jonp is offline
Old 03-21-2014, 05:20 PM
  #88440
Default For Sale: Team Checkpoint TC-1030 Charger
w/ Hyperion Lipo Balancer & Nosram 14amp Power Supply
Reprice: 5thou only
PM or text me @ 0933-5256760
corics715 is offline
