View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Hope see everyone this year.
(N.B: TAC 2013 Driver)
FOR SALE SAKURA ZERO WITH 17.5 BRUSHLESS MOTOR, HOBBYWING ESC,
ALUM. THREADED SHOCK, ALUM. SUSPENSION MOUNT, ALUM. MOTOR MOUNT, SERVO AND RECEIVER NOT INCLUDED 7,500
09228218191
09228218191
Looking For
Muchmore Cell Master Legend (Purple)
Muchmore Powerstation Pro(Black)
Muchmore Dual Fan cooler (Purple or Black)
Muchmore CTX-D2 or Dr. 4K
Novak Smart Tray or Flatliner
Txt me if you have any 09177576817
For sale Tamiya TL-01
hop ups:
Tamiya TA03 Ball Diff
Full ball bearing
Tamiya universal shaft
Tamiya Hollow carbon drive shaft
Tamiya light weight chasis
Tamiya hollow carbon gear shafts
Tamiya adjustable upper link
Tamiya speed tuned gear
Tamiya quick release battery holder
HPI drift tires and rims
LRP esc
Tamiya TA03 low friction dumper set
3racing blue alluminum anodized king pin
blue alluminum stearing shaft
futaba s3003 servo
Tamiya super stock type-T motor
+Futaba radio T2PHKA
+Hi-tec 24 cell peak detection charger CG-330 w/built in glow plug igniter charger
selling price: 4,500
09983333311-kit
09295048888
thanks rctech
Full ball bearing
LRP esc
futaba s3003 servo
09983333311-kit
09295048888
thanks rctech
HPI Savage XS flux rtr 11,500
HPI savage slux xs rtr 11,500
bnew body shell bought by action hobbies @ 1.7k yesturday
painted only never been run.
with brushless flux vektor 4000kv 4 pole
Hobbywing sw8 80amp esc up to 3s lipo
Upgraded adjustable steering rod
Upgraded adjustable camber link
Almost bnew on-road tires
Lots of extra parts including 4pcs extra rims
HPI trf-40 2.4ghz tx+rx
2s lipo nalang tatakbo na.
Can add 2s lipo 5000mah just 1,000
Meet ups
Pasig/Manila/Ortigas/Q.C./Cubao
Please txt me @ 09335520500
Meet ups
================SALE ENDED, THANK YOU=================
for sale
RC SHELLS
takata dome for tb03 - 1.3k
painted
never used
tbo3 holes
yokomo ferrari f50 - 800
tc 3 holes
painted ferrari red
unknwon crawler shell - 300
will include
protoform chrysler shell
if youl get all shells
check pic for reference
also accepting trades for cc01
hop ups
also looking for hsp pangolin
tranny
contact me through
09176668514
im not alsways online
https://www.facebook.com/Mikemenggay...=3&uploaded=13
RC SHELLS
painted
never used
tbo3 holes
tc 3 holes
painted ferrari red
will include
hop ups
tranny
contact me through
09176668514
Hyperion EOS 720i Net3 AC/DC 20A Charger Balance Charger 1S-7S 16N Store Mode[/b] (LIGHTLY USED)
* 12-Bit Balance Circuit Resolution for superb accuracy
* Charges 1s-7s Lithium Polymer and A123 batteries as well as Nimh, Nicad and Lead Acid* Built-In USB DataPort and supplied USB cable
* Hardware support for EOS Control & Data Suite PC Software
* 20 Memory slots for batteries
* CYCLE mode for LiFePO4 and LiPo
* Convenient DC Cord Storage on charger bottom (see pics above)
* HP/PQ and JST XH balance adapters included
ITEM CONDITION:
protective film still on
charging lead soldered to deans (see photo)
comes with original box and accessories (usb cable and Hyperion Multi-Adapter Balance Board are also included - not pictured)
P5.5k with free shipping to your doorstep (LBC)
Spektrum SR3300T w/ telemetry (USED) P2kprotective film still on
HobbyWing XERUN KV2250 Sensored Brushless Motor (middle connector was replaced - see photo) (USED) P2.5k
Dubro Silicone Fuel Tubing, 2', Medium (NEW) P500
Losi LST XXL AIR FILTER Mach 454 (NEW) P500
Tenergy 6v 3300 mAh batt pack (USED) P900
Futaba S9450 digital servo (LIGHTLY USED) P3k
--- Losi Cluth shoes (shows some scratch marks due to install/uninstall) P1k
Losi Front/Rear High Speed Transmission Bevel Gear Set (28/17) (NEW) P660
Losi Titanium Nitride Differential ring/pinion (NEW) P2.5
Losi Combo Pull/Spin Start Assembly (NEW) P1.1k
Losi F/R Differential Bevel Gear set (NEW) P695
Losi Pull Start One-Way Bearing (NEW) P875
Losi LST XXL Exhaust Header (NEW) P1.2k
Losi Clutch & Nut Hardware (NEW) P500
Losi Cluth Nut & hardware (NEW) P525
Losi Exhaust spring (NEW) P250
Losi F/R servo (USED) P400
Additional P150 /shipment
LRP Nitro Engine ZR.30 X Competition engine (losi spin start installed/can be removed for buggy use) (1 3/4 gallon though it including break in)(USED) $old Thanks sir Wed & rctech
More parts HERE
Ask any question you have (private message/sms)
Will add more items as I find them. Thanks for looking
Contact number +639266838717
Some stuffs for disposal
Very slightly used Tamiya Formula Tuned motor - 800
LRP Vector x-11 4.5t BL motor - 1,800
HPI Rally/Pro 2 slipper assy w/87t spur gear - 1,000
Brand new mounted Tamiya F103 type B front tires 800
Brand new F103 carbon reinforced front arms set - 400
Brand new SC10 2wd gear diff rebuild set - 500
Brand new TRG Le mans front bumper set - 600 sold!
Brand new Hot Bodies alumn belt pulley (16,17,18T) - 500
Brand new GPM CC-01 alloy rear damper mount set - 800
09178903878
09178903878
pa help nman mga sir.... bakit hindi ko ma-setup yung esc start mode ng hanggang level 5 pataas? hanggang level 4 lang siya w/c is 4 blinks sa led? paturo nman sa mga naka-try mag set ng level 5 pataas. TIA
