View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
LF
LF: walkera rx701
09272776118
09272776118
For sale Tamiya TL-01
hop ups:
TA03 Ball Diff
Full ball bearing
Tamiya universal shaft
Tamiya Hollow carbon drive shaft
Tamiya hollow carbon gear shafts
adjustable upper link
Tamiya speed tuned gear
HPI drift tires and rims
LRP esc
Tamiya silcone oil filled shocks
3racing blue alluminum anodized king pin
blue alluminum stearing shaft
futaba s3003 servo
Tamiya super stock type-T motor
Futaba radio T2PHKA
Hi-tec 24 cell peak detection charger CG-330 w/built in glow plug igniter charger
selling price: 6k negotiable
09983333311-kit
thank you rctech
TA03 Ball Diff
Full ball bearing
LRP esc
futaba s3003 servo
Futaba radio T2PHKA
09983333311-kit
thank you rctech
Baguio
May alam po ba kayo na track sa Baguio pang off-road? Saka may mga taga Baguio po ba dito? Salamat.
ForSale TT01-E
Tamiya TT01-E
Php1,700.00 only
Adjustable rear suspension arms
TRF medium springs (white coated)
Tamiya Aluminum Propeller Shaft
Tamiya Aluminum Shaft cup
Tamiya Front and Rear Stabilizer bars (mounted on lower suspension arms)
Stock gear diff (front and rear)
Sport Tuned motor
SOLD SOLD SOLD SOLD
Makati/Marikina area
Php1,700.00 only
Sport Tuned motor
SOLD SOLD SOLD SOLD
i'd love to see this. whats great about t-maxx is that it can be extended without any complication, just time consuming due to modding, not like REVO's.
Fs
Aluminum handle Igniter with free back up using AA battery p850
Nitro engine starter with backplate for SH28 or similar p1100
1/10 Short course rocket tires mounted on LOSI TEN 2.0 black rims with soft inserts p800 a pair or p1500 for 4pcs
Once used.
Redcat 1/8scale monster truck/truggy universal shafts p550 (orig price is 950)
New
09175797230
Meet ups at alabang, jp raceway or NAIA TERMINAL 3 vicinity
Once used.
New
09175797230
Taga baguio po ako..(docrex) sa scale rc po kami nagpopost, si pinoyrc baguio rin, may mga kasama din kami taga pangasinan at may drift tract kami sa calasiao.. Scale crawler po kasi rig ko ngayon kayo kahit saan puwede. :-) ito po number ko (09084421178)
Thanks docrex. Sumilip ako sa scale rc, hindi ako maka-relate. malamang dahil 2 months palang ako sa RC, at electric off-road ang nilalaro ko ngayon. He he he. Off road track, wala ka bang alam na nasa Baguio o sa malapit doon? Nasa destino ako nagtatrabaho e, monthly lang ako umaakyat sa Baguio. Sana may track na malapit doon para makalaro din pag bakasyon.
item sold.
na pansin ko, integy aluminum arms gamit mo. how do you like it?
aking REVO 3.3 na convert ko nang electric.
my build can be seen here
http://www.ultimaterc.com/forums/sho...d.php?t=185456
TRAXXAS REVO 3.3
Selling my Traxxas REVO 3.3 with RPM Front/Rear Upper/Lower Arms, Electronics, EZ Start w/ Battery
It comes with extras listed below
Brand New:
- 1 set Dual Steering Bell Crank 5344,5309
- 1 Steering Servo 2075 Waterproof
- 1 Throttle Servo 2056 waterproof
- 1 Micro Shifting Servo 2065 Waterproof
- 1 Differential Front/Rear 5380/5379X
- 1 set Fuel Tank 5363X with Cap Lid & Tubing
- 4 Shocks Front & Rear
- 1 Long Travel Rocker Set
- 1 set Integy EVO 3 Rear Lower arm (L+R) T3206Blue
- 1 set Integy EVO 3 Rear Upper Arm (L+R) T3207Blue
- 1 set Integy White Clutch Shoes
- 1 set Traxxas Clutch Shoes 4146X
- 2 sets Center Drive Shafts 5456, 5457, 5458
- 2 pieces Tie Rods (Turn Buckle)
- 1 set EZ Start Wiring Harness
- 4 17mm Traxxas Blue Wheel Hub & Nut Adapter
- 1 set REVO Tools (Traxxas Supplied)
- 2 Glow Plugs (OS-A7 & Traxxas)
- 14 mm Wheel Hexes & Pins
- Greg Adler Slayer Pro Body
Used:
- 1 Tenergy 4200mAh 7.2V NiMH (Extra for EZ Start) 6 Charges approx.
- 8 Duracell AA 2000mAh NiMH with Charger for TQ
- 1 PE-1 Temp Gun (needs battery replacement)
- 1 HSP Fail Safe
- set Adapter to fit Slayer Pro Body
- 1 Mark Jerome Slayer Pro Body
- 1/2 Gal Nitro
- 1 Fuel Bottle
All for PHP 23,000. Please call or text 09267476959
Brand New:
Used:
- 1 HSP Fail Safe
- 1/2 Gal Nitro
- 1 Fuel Bottle
Last edited by Logic8; 10-23-2013 at 06:32 PM. Reason: taking out revo brand new body
used LRP Nitro Engine ZR.30 X Competition engine (losi spin start installed/can be removed for buggy use) (1 3/4 gallon though it including break in) 12K 11K 9K 8K
used Tenergy 6v 3300 mAh batt pack P900
used Futaba S9450 digital servo P3.5k
used Losi F/R servo P400
new Losi Aluminum Diff Case, Blue:LST2/XXLP990
new Dubro Silicone Fuel Tubing, 2', Medium P500
new Losi Combo Pull/Spin Start Assembly P1.1k
new Losi F/R Differential Bevel Gear set P695
new Losi Pull Start One-Way Bearing P875
new Losi LST XXL Exhaust Header P1.2k
new Losi Clutch & Nut Hardware P500
new Losi Cluth Nut & hardware P525
new Losi Exhaust spring P250
used HobbyWing XERUN KV2250 Sensored Brushless Motor (middle connector was replaced - see photo) P3.5k
More parts HERE
Ask any question you have (private message/sms)
Will add more items as I find them. Thanks for looking
Contact number +639266838717
--- Losi Cluth shoes (shows some scratch marks due to install/uninstall) P1k
new Losi Front/Rear High Speed Transmission Bevel Gear Set (28/17) P660
new Losi Titanium Nitride Differential ring/pinion P2.5knew Losi Front/Rear High Speed Transmission Bevel Gear Set (28/17) P660
More parts HERE
Had a nice chat last week with the owner of ABC hobby shop during the mid 80's he is into airsoft now.
