View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Hello gpxjoe or anybody out ther whos willing to help
I have an rtr 1/8 scale, which will be park for months my servo got busted,
Want to confirm re ARO alternative
- 2t oil ( any ) ?
- how many drops ?
- my car is a pull start, how many times should i pull it
- should i cover it with my glow plugs while pulling
- what would be a good wrap to use
Thank you
- 2t oil ( any ) ?
- how many drops ?
Thank you
Tamiya TT-01 Type E 4wd RC Chasis 1/10 Scale w/ electronics - Php4000.00
Kit is in very good working condition with minor scratches on underside of chassis.
Rear differential is locked due to drift set-up (can easily be taken out since glue gun was used.)
Included:
Tamiya 18 Spoke Black Wheels
Tamiya Anodized Blue Wheel Nut 4pcs
Tamiya Aluminum Shaft
Tamiya Road Tires 4pcs
Tamiya 540-type Motor
Tamiya TEU-105BK ESC - Converted already to Dean's Connector
Sanwa SRM-102 Servo
TT-01 Type E Manual
Free:
Full Ball Bearings 12pcs - (Already Installed)
NICD Battery RC2400SP
Add Php500.00 for front one way (almost new)
0917-8157771 please text me so i can text you the Sulit Ad link
Included:
Sanwa SRM-102 Servo
TT-01 Type E Manual
Free:
Hello cant wait for the reply lol
Got my 2t put around 10 drop in the carb and pulled several time
What do you think , did i miss anything ?
up
Hobao Hyper10sc Rolling Kit - 7k
- All Stock.
- ARTR with Brushless Motor, Servo and ESC for 10k
Tamiya M05 Rolling Kit - 3.5k
- Upgraded Motor mount/Steering Holder
- Free Silvercan and Servo
- 2-Shells
Yokomo BD5 Rolling Kit with lots of spares - 10k
Tamiya Unimog CR-01 - 10k
With free silver can motor and feetech servo
SMS me if interested i can email you pictures.
0917-8575436
Up still available...
- All Stock.
- 2-Shells
0917-8575436
By Mike Garrison
LiveRC.com
Serpent 747 designer, Michael Salvan, has sat down and explained weight distribution in general as well as specifically on the 747. He incorporated a very unique weight distribution sliding weight system for the 747 which he also explains!
Serpent Tech Talk:
www.serpent.com
By Michael Salvan
In the set-up of racing cars in general, weight distribution and balance is very important.
In the Serpent 747 I introduced an easy way to use this knowledge in a very quick way, so that the change of the weight distribution can be made very fast, but still secure, even during a pitstop if needed.
The "sliding" brass weights in the 747 are locked with only 1 screw in position to the chassis. There are 3 slots to choose from . I added some markings on the chassis to make changing the position easy and precise. This easy adjustment makes the sliding weight a very powerfull set-up tool!
Each brass weight weighs 25 grams ( part number #804273 ) , and a maximum of 3 weights can be fitted. I advice to use maximum 2 weights to allow some adjustment. Of course the number of weights also depends how the weight of the whole car is and what the rules for maximum weight in your country is. See image 2.
In most cases the 2 weights only are already around 3% of the total weight of the car, making this a more powerfull tool than for example anti-roll bars
By moving the weights more forward you should notice the car to have more understeer and by moving the weights more backwards you should notice it to have more oversteer.
As starting point you can put one weight in the middle of the front sleeve, and one in the middle of the rear sleeve.
To learn the benefits of the weights, I suggest to move the weights with 2 or 3 lines at a time, so you can really noice the strong change, and you will learn what it does to the handling of the car. During a race, you will then learn to use smaller steps, to maximise the benefit. Even during a pitstop in a final this can be done quick and precise.
Enjoy your racing !
By Mike Garrison
LiveRC.com
Serpent Tech Talk:
www.serpent.com
By Michael Salvan
Enjoy your racing !
First remove the glow plug, then remove air filter, then add 10 drops to the carb, then put throttle servo on fullthrottle, then get toilet paper and cover the head wer the glow plug is, then bump start. Do it Siguro twice mga 2 seconds bump starting it. U should see the oil in the toilet paper,if u don't, ur not doing it right. After you see the oil in the toilet paper, reinstall the glow plug, put the flywheel in maluwag position, and seal the pipe, carb, and fuel inlet of carb, then you can leave it alone na for up to a year Siguro or more
Happy racing!
For Sale: SHELLS!!
SHELLS for sale
P2,000 civic FD
>unpainted/uncut
>with accessories/rear body kits
P2,000 abc person s14
>unpainted/uncut
>with accessories / yokomo light buckets
(EvoX sold to sir benjie of zambales )
(hi-ace sold to sir Edgar of cabu )
(rx-7 sold to sir benjie ulit sa baguio naman hehhe )
contact me thru:
cp: 0 9 1 6 6 9 1 0 6 0 3
ym: antii.hack
SHELLS for sale
P2,000 civic FD
>unpainted/uncut
>unpainted/uncut
contact me thru:
ym: antii.hack
