View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Flysky GT3C with the new redesigned and improved steering wheel
Available Colors: Silver + Black and Orange + Black
Price: 2600
Rapicon RC Fuel (Car)
25% 1430 per gallon
30% 1570 per gallon
Tornado RC Fuel (Car)
25% 1055 per 2.5L can
30% 1225 per 2.5L can
30% 1860 per gallon
we also sell per box (4 gallons or 6 2.5L cans) with discounts, txt or call for more info
we ship anywhere in the philippines
ITEM: 200cc Fuel Gun
Status: On Stock
Price: 950
ITEM: Turnigy nano-tech A-SPEC 6200mah 2S (7.4v) 65~130C Hardcase (NEW)
Status: On Stock
Price: 3365
ITEM: Turnigy Nanotech 6600mah 2s (7.4v) 65-130C hardcase
Status: On Stock
Price: 3160
ITEM: Turnigy Nanotech 6000mah 2s (7.4v) 65-130C hardcase
Status: out of stock
Price: 2760
ITEM: Turnigy Nanotech 5600mah 2s (7.4v) 50-100C hardcase
Status: On stock
Price: 2360
ITEM: Transmitter Radio Wheel (Aluminum)
Status: On Stock
Price: 600
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
Status: On Stock
Price: 700
Item: Flysky FS-SM100 USB RC simulator adaptor cable
Status: On Stock
price: 350
Item: Turnigy A-6-10 200W Balance charger & discharger
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Discharge current range: .1~5.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Status: On stock
Price: 3320
Item: 350w Power Supply
Input Voltage: 220~240V AC
Output Voltage: 13.8v DC
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
ITEM: Turnigy Accucel 6 Balance Charger
Status: On Stock
Price: 2000
ITEM: Power Supply 100~240v 5A (for battery chargers)
Status: On Stock
Price: 1000
BM-6 Cell Voltage Monitor 2-6S Lipo (Latest Version) (New Item)
Battery cell range: 2S-6S Lipo/Li-ion/LiFe
Voltage display resolution: 0.001V
Voltage Detection precision: 0.005V
Cell Voltage display range: 1.50-4.99V
Total Voltage display range : 3.00 ~29.94V
Alarm cell voltage: 2.00 ~ 4.00V
Status: On Stock
Price: 985
Item: Digital Caliper
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
Item: BMS-660DMG+HS Super Strong Digital Servo
torque: 14.2kg/cm @ 6v
speed: 0.17sec/60° @ 6v
status: On Stock
price: 1570
Item: BMS-820DMG+HS High Performance Digital Metal Gear
Torque: 10.6kg/cm , 142 oz/in @ 6v
Speed: 0.09 sec /60° @6v
Status: Out of Stock
Price: 2610
ITEM HK15298B High Voltage Coreless Digital MG/BB Servo
Torque: 18kg @ 6v, 20kg @ 7.4v
Weight: 66g
Speed: 0.18 / 60deg @ 6v, 0.16 / 60deg @ 7.4v
Voltage: 4.8v~7.4v
Motor type: Coreless
Status: On Stock
Price: 1395
Item: Turnigy 620DMG+HS High Torque Digital Metal Gear
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
Item: Turnigy 25mm Flywheel Removal Tool
For engines .21-.32
Status: On Stock
Price: 435
Item: Hard Steel Tweezer either Straight or Curved
Length: Straight 125mm Curved 120mm
Status: On Stock
Price: 135 (when ordering, please indicate if you want straight or curved)
X-BLADE Precision knife with replaceable SK-5 blade
Status: On Stock
Price: 70
Item: Hex Metric driver set 4pcs
Set includes: 1.5, 2.0, 2.5 & 3.0
Status: On Stock
Price: 700
Item: Hex Standard/Imperial/English driver set 4pcs
Set includes: 050, 1/16, 5/64 & 3/32
Status: On Stock
Price: 730
ITEM: 4mm long shaft Flat Head Screwdriver (for engine tuning)
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Item: Turnigy 4mm XL shaft Flat Head Screwdriver (for engine tuning)
Tip Length: 170mm
Status: On Stock
price: 265
Item: Turnigy 5mm long shaft Flat Head Screwdriver
Tip Lenth: 105mm
Status: On Stock
price: 235
Item: Turnigy Long Shaft Exhaust Spring Tool
Status: On Stock
price: 235
ITEM: TURNIGY 4pcs hex socket driver set
Status: On Stock
Price: 460
ITEM: Knife Edge Reamer 0.5-18mm
Status: On Stock
Price: 570
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
Status: On Stock
price: 470
Item: Turnigy Flywheel Key w/ H17mm Wrench Tool
Status: On Stock
Price: 370
***pictures at http://rccebu.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) – P1885
ITEM # 20: Brand new Savage X, XL Battery Box only – P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) – P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) – P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) –P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 29: Brand new O’Donnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300/piece
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) – P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) – P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) – P1520
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack – P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) – P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new O’Donnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P300
ITEM # 73: RPM Center skidplate for savage x – P1215
ITEM # 74: Losi 15mm shock boots for big bores – P640
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket – P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes – P1570
ITEM # 93: Mugen clutch spring 1.0mm - P155
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt - 70wt – P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 – P700/pack of 10
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe – P750
ITEM # 115: Exhaust gasket – P500/pack of 5
ITEM # 116: Exhaust Spring long –240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) – P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) – P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector – P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) – P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs (Now on Stock!!!)
ITEM # 147: HPI Machined Bulletproof Diff Gear Set – P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) – P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) – P725
ITEM # 151:Savage 25/x/ss/flux center drive shaft – P635
ITEM # 152:NEW HPI Savage X Roll Bar, Handle, Engine Protector – P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator – P1967
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO or LBC prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.75% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyer’s reference
We accept orders for hard to find parts (please call or text for more details)
Price: 2600
25% 1430 per gallon
30% 1570 per gallon
30% 1860 per gallon
Status: On Stock
Price: 950
Status: On Stock
Price: 3365
Status: On Stock
Price: 3160
Price: 2760
Status: On stock
Price: 2360
Status: On Stock
Price: 600
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Status: On Stock
Price: 700
Status: On Stock
price: 350
Status: On stock
Price: 3320
Output Amps: 25A
Output Watts: 350W
Status: On Stock
Price: 3700
Status: On Stock
Price: 2000
Status: On Stock
Price: 1000
Status: On Stock
Price: 985
range: 0-150mm
Accuracy: +/- .02mm
Status: On Stock
Price: 1380
status: On Stock
price: 1570
Price: 2610
Weight: 66g
Voltage: 4.8v~7.4v
Status: On Stock
Price: 1395
Servo
Torque: 10.6kg/cm
Speed: .13sec/ 60°
Status: On Stock
price: 1510
For engines .21-.32
Status: On Stock
Price: 435
Status: On Stock
Status: On Stock
Price: 70
Status: On Stock
Price: 700
Status: On Stock
Price: 730
Length: 105mm
Number of units: 3
Status: On Stock
Price: 170
Tip Length: 170mm
Status: On Stock
price: 265
Tip Lenth: 105mm
Status: On Stock
price: 235
Status: On Stock
price: 235
Status: On Stock
Price: 460
Status: On Stock
Price: 570
Status: On Stock
price: 470
Status: On Stock
Price: 370
ITEM LOCATION: Cebu
Shipping details:
FS: TRANSMITTERS TX/RX
Selling the following items:
1. Futaba 3PJ 40mhz TX with receiver - 1,500php fixed
2. Team Associated XP3D 27mhz TX with receiver (almost brand new, came from RTR) - 1,500php fixed
Both are in good working condition.
RFS: Already have a 2.4ghz system MT4
For pick up at Centris Q.Ave weekdays, Visayas Ave. weekends.
Call/Text 0917-8791424 (paul)
Thanks and good day.
Unit will be tested upon meet up for your peace of mind. Ill bring my own servoand batts.
Thanks!
Looking for scx10 or tf2, may ngpapahanap lang, pm me your best offer
2013 PHILIPPINE OFF-ROAD NATIONALS
OFF-ROAD RACING CLASSES & RACE SCHEDULES
April 14, 2013
Nationals for 1/8th SCALE EP BUGGY
Venue: CIRCULO VERDE, Quezon City
APRIL 28, 2013
Nationals for 1/8th SCALE NITRO BUGGY
MAY 12, 2013
Nationals for EP SHORT COURSE 4X4
JUNE 2, 2013
Nationals for NITRO TRUGGY
RACE DATES SUBJECT TO CHANGE DUE TO INCLEMENT WEATHER
Map to: CIRCULO VERDE -
http://i32.photobucket.com/albums/d1...010GOOGLE1.jpg
SHORT COURSE & E-BUGGY RULES:
http://www.rctech.net/forum/7320376-post10256.html
NITRO 1/8th SCALE BUGGY (IFMAR SANCTIONED) RULES:
- ENGINE SIZE: .21 CC
- FUEL TANK CAPACITY: 125 MILLILITERS/4.23 FLUID OUNCES
- MINIMUM WEIGHT: 3.2 KILOS
- 3 HEATS 10 MINS QUALIFYING
- CHRISTMAS TREE FORMAT
THIS IS THE RACE PROGRAM:
TRACK RULES & REGULATIONS
1) No Practice during race intervals, only during lunch break will it be allowed. Penalty deduction of 20 secs will be assessed to any violators.
2) No cursing and shouting at Marshals - Penalty deduction is 1 lap.
3) No confronting & cursing of fellow racers at the Driver's Stand during the race - Deduction of 1 lap is the Penalty.
4) Complaints & question will only be entertained after 1 round of all race heats completed.
5) No hacking or rough driving during the race - failure to comply with the Bump and Go rule upon order of the race officials will result in a Penalty of 1 lap deduction.
6) No shortcut or cutting corners during qualifying & the race - Penalty is a deduction of 1 lap.
7) Lapping cars should be given the right of way, failure do so upon order of race officials will result in a Penalty and 1 lap deduction.
8) Make sure to Register your frequency before turning "ON" your transmitter.
9) Keep Race Track and Pit Area clean at all times.
REGISTRATION
No need to submit your PT# ahead of time. You will be instructed to have your kit pass by the loop before each heat.
Here are instructions on installing Personal Transponders to help avoid miscounts:
http://i32.photobucket.com/albums/d1...ropermount.jpg
Nitro Buggy Race Fee: P1,500.00 on the day of the race.
Late registration, will be allowed to run after 1 round of qualifying.
EP Race Fee: 1,200.00 on the day of the race.
Included with each Race Fee:
LUNCH, T-SHIRT, RAFFLE STUB.
For any questions please post your queries at the QCRCCC thread here on RCTech.
This specific thread announcement will be locked.
*** THANK YOU SPONSORS!***
Helicopters
For Sale
Item 1
P18,000.00
Size 30 Nitro Helicopter
Carbon Frame
Hirobo Parts
With TX / RX
Fuel and Starter na lang ang kulang
Item 2
P12,000.00
450 Size Helicopter with lots of freebies
2.4ghz Remote
1 Lipoly Battery
Extra Frame
Extra 2 Canopy
Extra 1 Tail boom
And lots and lots of spares (almost all of them are brand new)
Perfect for begginers (dami pamalit)
Both are extremely negotiable )
Disposing this medyo sawa na and no time to fly
Open for swap with the following
Evo 4 Spoiler
Evo 4 Bumper
Recaro / Sparco Seats
Open for TAWAD
malay mo bigay ko diba
0922 808 8293
Bulacan / Trinoma / MRT Buendia
Item 1
P18,000.00
Carbon Frame
Hirobo Parts
With TX / RX
Item 2
P12,000.00
2.4ghz Remote
1 Lipoly Battery
Extra Frame
Extra 2 Canopy
Extra 1 Tail boom
Evo 4 Spoiler
Evo 4 Bumper
Open for TAWAD
0922 808 8293
FOR SALE!!
for sale
RFS:
sayang lang wala akong time too busy sa ibat ibang mga bagay!!
BNEW AND NDI NAGAMIT BINUO LANG
still complete with box nid nalang ng FOW and electroncs go na kayo
sold as package 6.5k mura na po ito
TEH-R31 with CF Convertion worth 6.5k
CS Ready at 80% with complete cs gears for r31 worth 550php
rear solid spool worth 900php
square 40t pulley for the rear worth 400php
6.8k as package FIX!!!
FREEBIE KO MGA ALLEN SCREW DRIVERS and etc...
laki na ng tipid nyo more than 1k
UPDATED WITH PICS
send me as sms
09153514256
meet ups mrt stations or boni mrt or robinson pioneer yan lang aside from those other places shipping na ang option OR PWEde din naman pagusapan
NOTE:
if shipping buyer should shoulder the shipping fee
RFS:
UPDATED WITH PICS
send me as sms
09153514256
NOTE:
TAC Round 4 Results (March 9, 2013)
Jr. Stock Class
1st Timothy Angtuaco
2nd Luigi Briones
3rd Gabe Monzones
4th Louise Binotapa
5th Paco Fernandez
6th Kiko Fernandez
Super Stock Class
A-Main
1st Leo Virtusio
2nd Migui Briones
3rd Rains Viola
4th Tim Medrano
5th Raymond Cruz
6th Ike Del Castillo
7th Nomad Moina
8th Dennis Bacani
B- Main
1st MG Pacson
2nd Kits Fernandez
3rd Lawrence De Leon
4th Harold Abiera
5th Patrick Maranan
Mini Class
1st Noel Aldaba
2nd Jason Dela Cruz
3rd Edward Angtuaco
4th Emil Pineda
5th Jun Soriano
F1 Class
1st Yuichiro Takaya
2nd Noel Aldaba
3rd Norman Cruz
4th Edward Angtuaco
5th Gabe Monzones
6th Vince Rivera
7th Rey Parco
FF03
1st Jason Dela Cruz
2nd Noel Aldaba
3rd Edward Angtuaco
4th Jun Soriano
GT Class
1st Gerome Ling
2nd Yuichiro Takaya
3rd Noel Aldaba
4th Edward Angtuaco
5th Jason Dela Cruz
6th Norman Cruz
Jr. Stock Class
2nd Luigi Briones
3rd Gabe Monzones
4th Louise Binotapa
5th Paco Fernandez
6th Kiko Fernandez
Super Stock Class
A-Main
1st Leo Virtusio
2nd Migui Briones
3rd Rains Viola
4th Tim Medrano
5th Raymond Cruz
7th Nomad Moina
8th Dennis Bacani
B- Main
1st MG Pacson
2nd Kits Fernandez
4th Harold Abiera
5th Patrick Maranan
Mini Class
1st Noel Aldaba
2nd Jason Dela Cruz
3rd Edward Angtuaco
4th Emil Pineda
5th Jun Soriano
F1 Class
1st Yuichiro Takaya
2nd Noel Aldaba
3rd Norman Cruz
4th Edward Angtuaco
5th Gabe Monzones
6th Vince Rivera
7th Rey Parco
FF03
1st Jason Dela Cruz
2nd Noel Aldaba
3rd Edward Angtuaco
4th Jun Soriano
GT Class
1st Gerome Ling
2nd Yuichiro Takaya
3rd Noel Aldaba
4th Edward Angtuaco
5th Jason Dela Cruz
6th Norman Cruz
For sale TEH R31 RTR
RTR PACKAGE ONLY, NO PART OUT !
UPDATED : Added more Items
my asking price is 23K (NEGOTIABLE) Just Hit me with youre OFFER
TEH-R31 Eagle Racing CF convertion
FUTABA 4PK
SAVOX SC-1257 TG
SPEED PASSION REVENTON S (SENSORED)
SPEED PASSION 13.5T Competition 3.0
YOKOMO Shell (JZX100)
IMAX B6 Charger w/ Power Supply
TOOLBOX
Kit:
R31 Eagle Racing CF Convertion
R31 Eagle Racing Front One Way
R31 Eagle Racing Multi Diff Solid Spool axle
R31 Eagle Racing Aluminum Steering
R31 Eagle Racing Wide Angle Unis. F/R
R31 Eagle Racing Aluminum 10deg. C-hub
R31 Eagle Racing Aluminum Motor mount (Gold)
R31 Eagle Racing Aluminum Spur Gear Holder
Aluminum Dampers (not sure Eagle Racing)
55% CS/Overdrive
F- 40 / 14 (Aluminum)
C- 18 / 18 both Aluminum Pulleys
R- 21 (Aluminum) / 36
Spring
F= Tamiya RED shoft Spring (but binalatan ko na dahil nababakbak para mas malinis tignan)
R= Super SOFT (from inertia)
Electronics
BL COMBO SENSORED w/ LED Program Card Box and Manual
esc : SPEED PASSION REVENTON S
motor : SPEED PASSION 13.5T Competition 3.0
http://i1002.photobucket.com/albums/...ps6e572062.jpg
Servo
SAVOX SC-1257 TG
http://i1002.photobucket.com/albums/...ps4eff3e42.jpg
TX / RX
TX : FUTABA 4PK with USER MANUAL
hop ups:
Aluminum Steering wheel
short Antenna
2100mAh Li-Fe Battery
RX : R614FF 2.4GHz FASST
http://i1002.photobucket.com/albums/...ps8482a2fb.jpg
BATTERY
Divi Li-Po 2800mAh
SHELL (no Damage, minimal scratch) this shell is from sir Kariton Drifting
YOKOMO JZX100 GOODYEAR
ROLLCAGE
LIGHT KIT
LIGHT BUCKETS
http://i1002.photobucket.com/albums/...pseb490ef6.jpg
CHARGER
IMAX B6 w Power Supply
http://i1002.photobucket.com/albums/...pse7e70dd2.jpg
TOOLBOX
almost b.new bought last Dec. 2012 may price tag pa
(yung part na Orange is made of metal kasya ang kit w/ shell and some spare parts)
http://i1002.photobucket.com/albums/...psd9eedcc1.jpg
FREEBIES
TOOLBOX (almost b.new bought last December2012)
Eagle Racing 21T Front Center Aluminum Pulley
TEH-R31 TUB CHASSIS
TEH-R31 Front and Rear Shock Tower
TAMIYA Adjustable offset rims with USED Threaded Tire (70%)
BASHING SHELL YOKOMO S14 w/ Light Buckets ang Wing
USED Painted Yokomo Rims (OFFSET maybe 6 or 7mm)
AND mag check pa ako sa tool box ko kung meron pa pwede maidagdag
ISSUES:
body post cut (advice to replace for other type or brand of shell)
Shock Piston need to replace for better performance but still in good working condition (may 2 piston modified 4 holes)
No Rear Diffuser
SHELL Wing Mount damage but already fixed
SERVO Wire is Cut almost 2inches nalang yun wire nya but malinis ang pag kakagawa
(ayaw ko kasi ng nakikitang nakapulupot yung mahahabang wires LOL)
MORE PICS.
http://s1002.beta.photobucket.com/user/carb0n/library/
RFS : Planning to get 1:1, and nagiging too much busy nadin sa work....
For Inquiries
Send me SMS or CALL 09065812324
Open For Meet Ups Depende sa Magiging usapan
No Lowballer Please ! only for Serious buyers
FUTABA 4PK
SAVOX SC-1257 TG
TOOLBOX
Kit:
55% CS/Overdrive
Spring
Electronics
Servo
SAVOX SC-1257 TG
TX / RX
hop ups:
short Antenna
BATTERY
Divi Li-Po 2800mAh
ROLLCAGE
LIGHT KIT
LIGHT BUCKETS
CHARGER
TOOLBOX
FREEBIES
TEH-R31 TUB CHASSIS
ISSUES:
No Rear Diffuser
MORE PICS.
For Inquiries
SUPER NEGOTIABLE !
For Sale:
1. Team Associated XP3-SS 3 channel TX/RX 2.4GHz -----1.7k shipped
Looking for :
1. Steering Block Component (pivot ball) For Traxxas E maXX kahit 1 pc lang... See picture below (yung naka encircle lang ng RED) pm or text me. di kasi magkasya ang stock part, baka may extra kayo mga sir kahit isa lang.
2.Hobbywing 120A or 150A EZRun Brushless ESC. or any 1/8 brushless
scale ESC.
3. Hop up parts for Traxxas E maxx....
4. Steel idler
Contact 09189590528
Thank you RC tech
Looking for :
scale ESC.
4. Steel idler
Contact 09189590528
Thank you RC tech
looking for: any 1/10 hsp kit or rtr elect or nitro ung cheap price lng po sana. tx me 09173821238
hi i just want to ask if there are any suppliers of nitro fuel in bacolod?i plan to run my 10th sccale touring there soon if theres a nitro supplier there
For Sale:
Tamiya TT01 – 11K
- Hobby Wing EZRun 9.5T and 60A Brushless Combo Motor and ESC
- Full ball bearings
- Team GPM alloy arms front and rear
- Team GPM alloy knuckles
- Tamiya Front One way, Stock Locked Rear Diff
- 2 batteries 5000mah 20C
- Urethane Blue foam bumper
- Eagle Racing Oil-Filled Shocks
- Carbon Center Stiffener
- Alloy Center Shaft
- Turnigy GTX3 Transmitter and 2.4GHZ Receiver
- Deans Plug
- Fan for ESC and Motor + Heatsink
- at least 3 sets of wheels with drift tires
- 1 new set of drift tires
- With 1 Bashed Shell – HPI Red Mitsu Evo X
- All plastic parts unused (arms, knuckles etc.)
- with box
- 2 months used
RC 1/10 Shells:
Tamiya Yellow Evolution VII– 2k
– comes only with the kit
- with light buckets and LED
- With muffler, wing and side mirrors and wiper
- Unused no damage
- TT01 holes
HPI Panda AE86 - 800
- Used only once, no damage
- HPI TCFD body holes
HPI Gray BMW M3 with– 2k
- light buckets and LED controller
- with side mirror and wing
- No body holes yet used only with stealth mount
Charger:
G.T. Power A620 Charger – 3k
- Can charge, NiCad, NiMH, Lipo, Life and Car batteries (Lead Acid)
- Can charge, discharge, balance, storage etc. modes
- Can charge up to 20A
- complete wires
- with 12A Avacus Power Supply
- Free Toolbox for your carrying needs
Buy all for 16k Fixed.
SMS only - 09178153270
Link and pics:
http://www.sulit.com.ph/index.php/vi...ls+and+Charger
Tamiya TT01 – 11K
- Deans Plug
- with box
- 2 months used
RC 1/10 Shells:
- Unused no damage
- TT01 holes
Charger:
- complete wires
Link and pics:
