View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
FS
[QUOTE=loubrianagustin;11743598]hi guys forsale or for trade this trex 600 kit (no blade and canopy)but with motor and bec for only 6k santolan pasig just text me 09153078798
all the parts you see is all brandnew( head assemble,tailboom,tail slider buttom plate ,bearings in bearing block and tail ,metal elevator,tailboom,,batt tray,thrush bearing ,,tail boom support rod,swash ,landing skid,belt).... heres the pix .RFS need some space
Update Again 6k nalang po with motor and bec pero one of the tail grip need to replaced or swap sa rc item basta pang heli or 3gx plus 2k or Xg7 or XG7 reciever with telemetry straight swap....
Attachment 1025738
Attachment 1025738
guys, san kya magandang lugar pang rally ng 1/10?? sa sonic ok ba?
ITEM SOLD
TAMIYA PORSCHE 911 GT3 CUP TEAM KTR Electric 4wd RC – 5.5K
Tamiya TA03F front motor 4wd belt-drive chassis (gray edition)
Used but in very good condition
Includes the following:
Tamiya Type T 23T modified electric motor
Tamiya TEU-101BK electronic speed control (deans plug installed)
Futaba 3003 servo
Brand new HPI X-Pattern radial tires (unglued)
Brand new HPI Chrome wheels (6mm front/9mm rear)
Tamiya plastic-body oil-filled shocks
Tamiya TA03 stabilizers (blue-front/orange-rear)
Brand new Tamiya Porsche 911 GT3 Cup Team KTR Polycarbonate body professionally painted and decaled (with light buckets front and rear)
Full ball bearings
Just install your favorite TX/RX and battery then play
If interested, text/call at 09175671547 Senen
No PM pls. No trade pls.
Futaba 3003 servo
Full ball bearings
to the buyer: many thanks!!!
to Rctech: thanks too....
Guys i found another post in a different thread
5-Step for Cleaning a nitro engine:
1) DE-GUNK IT!
First, remove your engine from your Vehicle, and then use an old toothbrush or a stiff-bristle paintbrush to rub away as much grime as you can. Aerosol nitro cleaners work well as long as the gunk buildup hasn't been left for so long that it's baked onto the engine like armor.
2) CLEAN GLOW-PLUG AREA. Before you remove the glow plug from the cooling head, you must thoroughly clean the area around it with motor spray. If you don't, you risk allowing the dirt that has collected around the glow plug to drop into the combustion chamber.
3) REBUILD THE CARBURETOR. If your engine still has good compression, your carb's 0-rings may be causing the problem. These small, rubber 0-rings on the needle valves serve a dual purpose: they seal the needles against air and fuel leaks, and they provide the resistance against their housings that's required to keep the needle-valve settings stable while you drive the car.
4) SEAL IT. After you've cleaned your engine thoroughly (or you'll contaminate inner areas) and replaced any worn carb parts, seal certain areas to further protect it. Sealing takes only a few minutes, and it can save you hours of frustration later.
5) REPLACE THE FUEL TUBING REGULARLY. This is yet another relatively cheap, easy-to-replace item that is often overlooked. Over time, fuel tubing is likely to crack or develop tiny puncture holes, and most bashers will run it until it fails.
Regards,
Berry Martin
1) DE-GUNK IT!
Regards,
Berry Martin
FS
1. tamiya datsun 240z clear body. 1.5k
a. comes with light bucket
b. TLU-01 with complete LED's
c. complete decals
d. with 4 spare 26mm radial tires
2. IMAX B6 charger. 1.5k
http://www.rctech.net/forum/members/...n-charger.html
for both 2.5k
call or text 09175411732
c. complete decals
for both 2.5k
For Sale Or Trade: SOLD na ito. ty
Tamiya TA-05r
-aluminum bulkheads
-aluminum steering
-aluminum toe blocks
-aluminum center brace
-motor
-extra chassis (IFS)
-Brandew new slick tires
-body Zonda
-Belts etc
What you see is what you get
Text me if interested @ 09162100627 / 09228450727
Tamiya TA-05r
-aluminum bulkheads
-aluminum steering
-motor
-body Zonda
-Belts etc
Thanks guys for this thread, it will help us newbies a lot. Thanks!!!
Items for Sale: Repriced!
Selling some of my RCs.
1. Acme 1/10 full aluminum crawler with teu104bk esc naka deans plug, 2pcs 55t motors, futaba am txrx 1600nicd battery naka deans plug and hi-torque servo. No body mounts and shell. Asking price P10,000.00.
if kit without any electronics (no motors, esc, servo, txrx) P7,000.00
2. Busted TL01 chassis. Not rolling. May mga kulang and cracks. For Parts P1000.00
Note: If you get the acme crawler with the asking price you get the tl01 as a freebie.
Thanks RC Tech
also selling:
1. Aeolian 120A 1/8 Brushless ESC with program card sensored/sensorless pwede -P4,200.00 repriced to P 4,000.00
2. 1880KV Brushless Motor 5mm - P2,500.00 repriced to P 2,200.00
3. xb8 nitro converted to EP Kit with 14mm conversion for MT Tires with 14mm hex hubs with used revo wheelset. -P5,000.00
kit
buggy wheel set
mt wheel set
extended 14mm hexhubs
1 & 2 combo - P6,000.00 (free pinion 14T) repriced to P 5,500.00
1,2 & 3 - P10,500.00 repriced to P 10,000.00 shoulder niyo na shipping.. Freight Collect
PM me your offers.
Thanks RC Tech
also selling:
kit
buggy wheel set
mt wheel set
PM me your offers.
c. complete decals
for both 2.5k
c. complete decals
for both 2.5k
SOLD. thanks rctech
FOR SALE MY BELOVED TT01D COPPERMIX REPRICED!!!!!!
Good Day Guys!
Im selling my beloved TT01D Nissan copper mix RTR na, for 8,000 only
complete with...
-Original shell (painted and re-designed)
-Battery (1600ni-cad)
-Charger (Bionic slightly used)
-Alloy main shaft (Center one way) UPGRADE
-Alloy steering arm, UPGRADE
-Remote (team losi spektrum 2.4 ghz)
-Box ng kotse with original manuals.
-Additional accessories
- 1 set rims ( silver )
hindi abused tong kotseng to,bihirang nagamit at nilaro lang sa open space ng bahay,
ill send pictures sa private emails kung sino may interesado,
just txt me to this no. 09062991588
REASON FOR SELLING - Need cash pang paaral
MEET UPS: Only weekends Afternoon
PLACE: GATEWAY MALL,SM MEGAMALL,SM MARIKINA,STA.LUCIA GRANDMALL, SHANGRILA AND ROBINSON GALLERIA and ROBINSONS METRO EAST
Thanks and God bless to RC TECH.
complete with...
L/F
LOOKING FOR SAKURA S 1/10 TOURING/ DRIFT CAR..
BUDGET 4K
TXT ME OFFER::
09161850443
TIA...
BUDGET 4K
TXT ME OFFER::
09161850443
TIA...
