View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
S> XERUN 13.5T MOTOR only.
few scratches but working perfectly!
P1500 NEGOTIABLE.
09175200092
P1500 NEGOTIABLE.
09175200092
SOLD
SOLD
LOOKING FOR:
looking for m05 body shell med WB.....
09216013419
09216013419
FOR SALE !!
Hitec 7966HB High Resolution High Speed Karbonite Gear
SPECS:
Speed: 0.10 sec/60 degrees at 4.8V
Speed: 0.08 sec/60 degrees at 6.0V
Torque: 91.65 oz/in at 4.8V (6.6 kg/cm)
Torque: 111.09 oz/in at 6.0V (8 kg/cm)
for only P1999
text or call: 0927 503 3572
SPECS:
for only P1999
FS>nanda nt-10 EP touring RC RTR
sold! thanks rc tech
For Sale!
FOR SALE or SWAP!
REPRICE and ADDED ITEMS
1) Team Magic 8th scale Comp Buggy 4,900 php Only! FREE SHIPPING!
with 2 bodies and lots of spares. PERFECT CONDITION!Ready to put your own nitro engine set ups!
RFS: Gagamitin ko sana to for EP conversion but its too heavy for my taste and very nitro specific yung layout nang chassis sayang lang kung ill changed it pa.
SWAP to 4x4 Sc, Savage or AXIAL AX10, SCX10 scaler chassis or offer me!
2) Turnigy 1:18th BRUSHLESS 4wd Stadium Truck 3,500 php Only FREE SHIPPING!
VERY FAST! Needs tx,rx and 1 Dogbone fits ae 18t dogbone or modified it a bit to fit.
Package Includes:
Turnigy stadium truck 4wd chassis
Wheels and tires
Powerful brushless motor
18 amp brushless esc capable of 2s and 3s lipo
Micro Servo
ST Body
Alloy center driveshaft
NEEDS one dogbone (fits 18t dogbones or other similar chassis with slight modification!)
FREEBIES!
Bnew Cond Turnigy 1800mah 2s lipo (Perfect fit sa truck and around 2cycles lang!)
Bnew Team Losi Mashers (1 pair)
Note if you dont have any extra rc18t dogbone you can make the turnigy truggy 2wd (rear wheel drive) so that you bash with it ASAP!
3) Traxxas Bandit Buggy RTR 8,500 php only FREE SHIPPING!
Package Includes
Traxxas Bandit Xl-5 chassis
Tamiya Sport Tuned Motor (Almost cond 5 runs lang!)
Tamiya Teu104bk esc with lipo cutoff
Magnum Steel Gear Transmission
New built shocks (50weight oil alla round)
Chassis is in very good condition NO BROKEN PARTS!
Sanwa Servo
Stock bandit wheels and tires (painted black!)
Futaba Attack Stick type radio and receiver
ADD 1,300php for that sexy onroad black wheels and tires!
OR 7,500 php lang knung without radio and receiver!
5) Futaba Attack am stick type radio 900 php Only! FREE SHIPPING!
Got this from sir dongskie but i have no use of it.
7) BNEW Tamiya Teu-104bk esc 850 php Only! HATI TAYO SHIPPING!
Brand new esc with lipo cut off!!!
8) BRAND NEW Hpi Slipper pad Assembly 400 php Only!
Extra lang fits hpi blitz , e-firestorm or any other similar chassis
9) Hummer H2 Scaler HARD BODY 1,700php Only! FREE SHIIPPING!
May konting scratches from normal use. Perfect for any 1/10th SCALER OR CRAWLER!!! Hard body very durable.May led lights na DIY.
IN CEBU
I do shipping thru LBC or AIR21[/B][/SIZE][/COLOR]
Text or PM me
David Suico 09235753444
THANKS RCTECH!!!
Package Includes:
Wheels and tires
Micro Servo
ST Body
FREEBIES!
Package Includes
Sanwa Servo
IN CEBU
Text or PM me
THANKS RCTECH!!!
For SALE HPI RS4 PRO & PRO3
ITEM#1 - HPI RS4 PRO, STILL FRESH WITHOUT ELECTRONICS:
This is the PRO version. Everything that can be carbon fiber is and all turnbuckles are titanium... Electronic installed, ESC & Motor are sold separately, discounted if purchase together. No receiver. Price includes custom painted body and brand new spare parts:
X3 HPI A450 SUSPENSION ARM SET
X1 HPI A350 UPPER SUSPENSION MOUNT SET
X1 HPI A460 FRONT UPRIGHT SET
X2 HPI A558 DIFFERENTIAL SHAFT
X1 HPI A241 BELT S3M 501 (167T)
X1 HPI A255 ONE-WAY PULLEY 15T (BLACK)
x1 HPI 6507 BODY POST SET
X1 HPI A838 FLANGE PIPE 3x4.5X5.5
HPI RS4 PRO -> S O L D
ITEM#2 - CC MAMBA MAX ESC -> S O L D
ITEM#3 - CC 1/10 MAMBA SENSORLESS BRUSHLESS MOTOR CMS36/5700KV -> S O L D
ITEM# 4 - HPI RS4 PRO3 HARA, FRESH
HPI RS4 Pro 3 Hara. which has alloy cvd, alloy bulkhead up front. Only ran it a few times , and sat the car on my shelf. This is a rolling chassis, no motor, no receiver and no ESC but comes with custom painted body and some brand new spare parts:
x2 HPI A451 SUSPENSION ARM/REAR HUB SET
x1 HPI A748 BELT S3M 459 (153T)
x1 HPI A749 BELT S3M 213 (71T)
HPI RS4 PRO 3 HARA -> S O L D
REASON FOR SELLING: SHIFTING HOBBIES
MARIKINA..
TXT/CALL: 0928-194-5286 ROLLY
For more pics. click on link below to see original post...
http://www.rctech.net/forum/9510820-post29995.html
MARIKINA..
for sale : scx10 honcho body
scx10 kit honcho body
11k (kit only)
not tortured used
w/ alluminum upgrade
trail ready set up
w/ cr tuned motor
slightly scratch on body and kit (got from trail and comp) but no deffective
lightkit w/ module included
good as new
see to appreciate
slight nego for pick up
send me sms for rolling kit or rtr package
brand new tt01 type es with hop ups
w/ semi bashed custom evo x shell
electronics
9k
for faster transactions, send me sms 09235791910
malate area
11k (kit only)
not tortured used
trail ready set up
w/ cr tuned motor
good as new
see to appreciate
electronics
9k
malate area
HSP Flying Fish 1 Electric DRIFT RC Car 1/10 Scale
2.4Ghz Controller Sytem
PRICE: 5895.00 Pesos
FEATURES:
Four wheel drive system
Front/rear camber and toe-in setup
Powerful RC 540 motor
Anodised aluminium centre drive shaft
High performance front/rear diffs
Stable suspension arms & solid front/rear shock tower
Oil filled aluminium capped shocks
Precise steering fitting delivers quick response
High precision SP03018 electronic speed control (ESC)
Complete ball bearings for a smooth and an efficient drive
High performance anti-skid drift tires, chrome plated spoke rims & pre-mount drift wheels
7.2v 1800mAh Ni-MH battery power
Extra large front bumper foam provides protection against sudden impacts.
SPECIFICATIONS:
Height: 112mm
Length: 360mm
Width: 200mm
Gear Ratio: 6:1
Track: 195mm
Ground Clearance: 4.5mm
Motor: RC540
Wheelbase: 260mm
Radio: 2ch Stick type 27mhz
Wheel Diameter: 65mm
Wheel Width: 26mm
Battery: 7.2v 1800MaH with charger
cp #
09054191867
FEATURES:
SPECIFICATIONS:
Height: 112mm
Length: 360mm
Width: 200mm
Gear Ratio: 6:1
Track: 195mm
Motor: RC540
Wheelbase: 260mm
Wheel Width: 26mm
cp #
09054191867
mga sir pa up lng
[QUOTE=sherwin03;9519265]mga sir ino pong meron for sale reciver
futaba 3 ch micro reciver
R123F 40 MHZ
and up ko ng
serpent impulse chasis found from sir (slayer) tnx sir
still looking and searching
serpent 720 kit
gpx4 pro kit
serpent impulse kit
set of belts for dis kit kahit tingi tngi ok lng
09219965322
thanks rctech
focus muna sa 1/10 onroad and 1/8 buggy hyper8 hintayin mo ko kukunin n kita next wik.
R123F 40 MHZ
and up ko ng
serpent 720 kit
gpx4 pro kit
serpent impulse kit
09219965322
thanks rctech
