View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Losi 8T
2-MG995 servos
8 tanks jammin .28 XPS
1600mah rx pack
extra set of tires
13,000 fixed
Airtronics RDS8000
3-receivers
lipo tx pack
12,000 NOW 10,000
Sanwa M11
2- sr300 rx
box and manual
10,000 neg
speedmind bag for ex10 helios
1,300 NOW 1,200
Thundershot rolling chassis w/o body
orig wheels and tires included
1,000
Tamiya Pajero body bnew
painted anzahl silver
1,500
LOSI HYDRA DRIVE 1,500
6amps power supply 13.8 regulated 1,000
assorted electronic stuff for airplane also available
esc,prop,servos,etc.
let me know what you need, i might have it.
pics to follow
09178224217
09228224217
2-MG995 servos
1600mah rx pack
extra set of tires
13,000 fixed
Airtronics RDS8000
3-receivers
lipo tx pack
12,000 NOW 10,000
Sanwa M11
2- sr300 rx
box and manual
10,000 neg
1,300 NOW 1,200
1,000
1,500
pics to follow
09178224217
09228224217
Looking for:
-tb03 aluminum steering rack
-27t 0.6 module pinion
forsale or swap
-used trf shocks with stock springs 800php
-Dyna run motor 300php
-Kyosho 19t motor 300php
-hitec robonova1 gold edition. with ir remote. ready to walk and perform. 27,000php
sample video
txt me 09157653765.
forsale or swap
sample video
txt me 09157653765.
doen, reserve na sakin ung shock
Speed Passion Drift Master BL Combo (used) - SOLD
-sensorless
-program card
-manual
-nosram fan
Futaba 2PL 2.4ghz Radio (used) - SOLD
-mint condition
-box & manual (to follow na kay Edong)
HB Pro Spec Ball Diff (used) - 1.5k
-one mint condition
-one working condition but needs rebuild w/ rebuild kit - 1.5k
Tamiya Assembly Universal Shaft (used) - 1k
-TT01 / TA04
-39mm steel
Futaba 3PM-MX Steering Wheel (used) - SOLD
Tamiya Springs Red (Super Soft) - SOLD
Tamiya Springs Stainless (Soft) - P200
HPI 39T Diff Pulley & 18T Alum Center Pulley - P300 ea
Kawada 98T Spur & 40T Pinion 64Pitch - P300 ea
-almost bnew
-test fitted only
Tamiya Spur & Pinion 48Pitch (used)
-TA05 70T spur - P150
-TT01 61T spur - SOLD
-24T Pinion - SOLD
-18T Pinion - P100
RFS: not in use
Contact: 09178830406
Meet Up:
-weekdays (makati, pasig, ortigas area)
-saturday (driftmeet F48 or PNP)
-sunday (alabang to cabuyao area)
-sensorless
-program card
-manual
-nosram fan
-mint condition
-one mint condition
-TT01 / TA04
-39mm steel
-almost bnew
-test fitted only
-24T Pinion - SOLD
-18T Pinion - P100
RFS: not in use
Meet Up:
selling/trade
[sold
D8 SAVAGEX ELECTRONICS ENGINES BATTS TIRES
HB D8T Php9,000SOLD!!!!!!!!!!!!!!!!!!!
HPI savage X Php 15,000
-HPI 17mm hex convertion
-HPI bullet Proof Differential
-HPI Steel disc breaks
-HPI Aluminum suspension geometry kit
-HPI Aluminum threaded shocks (8 pcs)
-HPI Spring purple and orange
-HPI Fuel filter
- O.S. 30 VG ( nabreak in lang wala pa 1 gallon tinakbo)
-Golden Horizon aluminum throttle mix arm
-Integy Aluminum gas tank protector
-Blue plastic center skid plate
-Proline bowtie's 40 series
-Axials oversize 40 series rims
-Carbon Fiber wing mount
- with 2 body shells 1 display shell 1 bashing shell
-HB D8 Wing
-hpi rotostart (no batts)
-BNEW hitec 7955titanum gear servo
- very slightly used sanwa WRX
requires gas radio and reciever
hotbodies d8 almost rtr Php 27,000
- reedy engine rvr .21 ( new piston sleeve and conrod and bearing)
- dynamite tuned pipe
- bls352 steering servo
- bls 452 throttle servo
- HB aluminum front knuckle arms and hub
- HB aluminum rear uprights
- HB lightened drive train ( gears, shaft, diffs, gear inside the diff, joints)
- HB long shocks rear
- HB yellow spring for the rear
- Newly rebuilded shock ( replaced shock components)
- HB aluminum servo horn
- Aluminum throttle servo horn
- Jet Racing aluminum 5mm reinforce front shock tower
- Jet racing aluminum steering support
- Jet racing ackerman steering link
- Mud guards
- Almost new bodyshell
- Newly replaced bearing
- High downforce wing
- New wing mounts
- 1 set proline revolver tires
Uninstalled part
-jet racing aluminum chassis stiffner ( front and rear)
PICS to FOLLOW wala camera ni esmi hehe
other items for sale :
electronics :
2 pcs transponder 3500 ea
2 pcs r604FS 3500 ea
1 pc r603FS 3000 ea
1 pc BLS352 servo 3500 ea
1 pc BLS 452 servo 3500 ea
1 pc S9157 ( nalagay lang sa chassis di nagamit) 3000
1 pc nosram cooling fan 1500
1 pc starterbox 1500
2 pcs life batt 7.2 v 1500 ea
Nitro engine :
1 Reedy .21 nabreakin lang 9000
1 Alpha .21 orange head very slightly used 4000
1 reedy tuned pipe efra 2035 3500
Tires:
1 set proline caliber buggy 1500
1 set proline bowtie buggy 1500
2 pcs proline bowtie buggy 1500
1 set proline crime fighter 1500 1 time used mga 10 mins
interested ? you can contact me @ 09178523336
-HPI Fuel filter
-HB D8 Wing
- Mud guards
- New wing mounts
Uninstalled part
electronics :
1 pc r603FS 3000 ea
Nitro engine :
Tires:
Location: Fighting out of the PHILIPPINES by way of VANCOUVER B.C
Trader Rating: 17 (100%+)
Lf: used spektrum sr3000 reciever
Looking For: used Spektrum sr3000 reciever
you can reach me at 09178121640
O.s engine
Still Looking for O.s Engine with pipe and manifold,tz 5 port SIlver.or tz 3 port blue head..Must be in good compression,willing to test with my compression tester. BUDJET 3,000 thanks.
FOR SALE HPI CYCLONE S
ALMOST STOCK LAHAT
EXCEPT SA:
3RACING DAMPERS
3RACING(STEERING LINK ATA)
GRAPHITE SHOCK TOWER (F & R)
CENTER ONE WAY
NAKA CS(COUNTER STEER) 50+ %
KIT LANG FOR 5K ONLY.
GOOD CONDITION PA TONG KIT NA TO..YUNG PIC TO FOLLOW NA LANG MUNA PO.THANKS
MEET UPS: BULACAN OR MANILA AREA
TEXT OR CALL: 09173436357/09235911544
THANK YOU RCTECH!
ALMOST STOCK LAHAT
EXCEPT SA:
3RACING DAMPERS
CENTER ONE WAY
THANK YOU RCTECH!
HPI Blitz ESE w/ Team Associated Gear Differential. No Tires, No Electronics... Php 8,500.
09228271641
Commonwealth Area
09228271641
Commonwealth Area
Looking For:
- hobao hyper21 turbo pull start assembly
- savage x .28 pull start assembly
- fuel bottle
- an igniter that uses sub c but can be changed
Pls pm me if you have.
- fuel bottle
up!
bili na sirs! pwede din swap sa spektrum dx3s/dx3r or futaba 4pl/4pk!
PICTURES UPLOAD
Slightly Used TA05 Version 2
Actual Pic:
hop ups installed:
1) 54170 TA05 Ver.II Low Friction Drive Belt (342mm)
2) 54078 44mm Swing Shafts
3) 54077 44mm Lightweight Rear Swing Shafts (Blue)
4) 54076 TB-03 Wheel Axles
5) 42102 TRF Special Damper (Hard Black Coating)
6) 54231 TA05 V.II Carbon Reinforced Chassis
7) 40524 Blue Aluminum Turnbuckles.
8) 53906 Aluminium Hex Head Ball Connector
9) Front & Rear Stabilizers
10) Blue Aluminum Ball Nuts
11) Plastic Disc Brakes
12) Honda Civic Mugen RR Shell
9k!!
09175339653
Actual Pic:
hop ups installed:
9k!!
09175339653
OT...
POSTING GUIDELINES
3) No HUGE IMAGES. Not only do these slow page loading, they ruin the format of the thread. It's frustrating having to keep scrolling up and down because of slow image loading but it's doubly frustrating having to scroll sideways too. If you don't have image editors, search for "irfanview" using google. Download, install and use it.
Guys..
Pakiusap po baka sakali lng po pede gawing thumbnail na lang po mga images. yan tagalog na po.. like the guidelines says " Its FRUSTRATING"
Reminders po ulit... at ulit... at ulit...
Salamat po
lookinng for
looking for pipes and exhaust manifold rear for
nitro 21 engine will use for buggy
09219965322
thanks rctech
09219965322
thanks rctech
