View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
For sale Reedy 121VR.21
fOR SALE:
REEDY 121VR.21 OFF-ROAD COMPETITION NITRO ENGINE
BREAK IN LANG DI NAGAMIT
sariwa pa
RFS: CHANGE PLAN po
selling it for 9.5k
Tel#02-6684434
sariwa pa
RFS: CHANGE PLAN po
selling it for 9.5k
Tel#02-6684434
FOR SALE
TAMIYA M05. Excellent condition , never raced.
Comes with Silver can Motor, Futaba S3003 servo and the ff. hop-ups:
- TRF M-Chassis Aluminum dampers set
- 3Racing M03M-11/V3 Swing Shaft Ver. 3
- 3Racing M03M-12/1/LB Rear Aluminum Hub Carrier 1 Degree
- 3Racing M05-01/LB Aluminum Motor Mount
- 3Racing M05-05/LB Aluminum Knuckle Arms for M05
- 3Racing M05-14/LB Aluminum Motor Heatsink Inside/Outside For M05
- 3Racing M05-15/LB Steering Track
- 3Racing M05-20/WO Aluminum & Graphite Battery Holder
- 3Racing M05-22/LB Steering Servo Linkage 95mm
- Tamiya Aluminum Linkage Set
- Full ball bearings
- Extra 3Racing ball differential
- 2 tires set: Original Mini "banana" rims with Tamiya radials (practically new)
Solaris dish rims with Solaris medium (36R) compound slicks
Will include a bashed Fiat Assetto Corse shell and other original spare parts.
Selling for P7,000 nego.
Get it at P8,500 will also include the Datsun 280ZX Shell and the Sweep wheelset and Atomic tires below.
RFS: di nagagamit, need funds for another project
TAMIYA DATSUN 280 ZX SHELL
For M05 short chassis, Brandnew uncut and unpainted, comes with driver figure, screws & nuts, decals.
Repriced to P900 fixed na
SWEEP pre-mounted tires for M-Chassis, Brandnew P900 nego
ATOMIC slick medium 32R compound tires for M-Chassis, Brandnew, P600
FUTABA FP-T4NBL 4 CHANNEL AM RADIO
New in box. AM 40 mhz, no manual, batts, & tx/rx crystals. Includes MCR-4AM receiver and built-in electronic speed controller (ch3) for brushed motor (aircraft).
Other Features:
• Servo reversing switch for each channel. Servos are reversed by using this switch.
• Newly designed sticks operate smoothly and positively. Spring tension mechanism allows adjustment of the operating feel of the stick lever.
• Nonslip adjustable lever head allows adjustment of the stick length as desired.
• Functional case, created as a result of the exhaustive pursuit of easier operation, has evolved a thick case which fits into the palm of the hand.
• Easy to read transmitter battery voltage/output level meter.
TX for P2,000.00
RX for P1,500.00
or P3,000 if you get both
If interested, please call or text at 0917-8134161. Meet up place: Ortigas Area
Thanks for viewing
Thank you RCTech
Other Features:
TX for P2,000.00
RX for P1,500.00
Thanks for viewing
Thank you RCTech
sir oro try back thread mayroon yatang for sale na slash , taga san pablo laguna di ko matandaan yung name
Various RC Parts for Sale!
***pictures at http://ceburc.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 6: Brand new 40 series Proline bowtie tires with velocity rims 14mm hex (1 tire is glued to the rim while the rest is unglued) - P3440
ITEM # 7: Brand new Team Losi Claw MT Tires with foam & rims 14mm hex - P3755
ITEM # 8: Used 40 series proline crimefighter tires with velocity rims 23mm hex. tread left 85% - P2525
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 10: Brand new HPI Savage Reverse Module -P2730
ITEM # 11: New HPI Savage XL TVP (Taken from a brand new never used Savage XL) - P2400
ITEM # 12: New HPI Savage XL conversion kit plus front drive shaft and engine mount w/ brace – (taken from a brand new never used Savage XL) - P4100
ITEM # 13: Brand new Team TCS 5mm thick Black Flux TVP - P2300
ITEM # 14: Brand new Team TCS 5mm thick Red Flux TVP - P2300
note regarding item 13 & 14:
-these tvp are a good upgrade to the stock tvp, they are so much stronger and looks better than the stock tvp, and they look so much better than the stock!
ITEM # 15: Brand new Racers Edge 1/8 silicone exhaust deflector - P450
ITEM # 16: Brand new HPI Roto Start 2 with shaft (xl length) - P2750
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 18: Brand new 23mm Hex set (colors available white) - P950
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) – P1885
ITEM # 20: Brand new Savage X, XL Battery Box only – P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) – P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) – P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) –P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 25: Brand new Racers Edge 3600mah 7.2v stick pack – SOLD (THANX MIKE)
ITEM # 27: Slightly used Sirio .27 engine 9 port (a small road rash on top of the cooling head) - P6700
ITEM # 28: Brand new Top 528XPS engine made by novarossi - P8700
ITEM # 29: Brand new O’Donnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) – P270/piece
ITEM # 30: Good as Brand New Hyperion EOS Battery Charger USB Adapter Cable (reference # HP-TI-PRGUSB) (only used 1 time to upgrade my Hyperion EOS0610i NET) - P1200
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) – P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 36: OFNA throttle linkage kit blue (part # 10724) - P690
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) – P1520
ITEM # 42: HPI Savage 16 tooth vented clutch bell (brand new w/ bearings) – SOLD (THANX JOSHUA)
ITEM # 45: Used Masher tires 40 series w/ Jconcept rulux rims 17mm hex tread left 85% - SOLD (THANX GARRICK)
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack – P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 56: Slightly used Proline Bowtie w/ velocity rims (#1134) 17mm hex truggy tires tread left 90% - SOLD (THANX JAMES)
ITEM # 58A: Brand new Proline Hole shot (#9026) w/ proline velocity rims 17mm hex buggy tires tread left 97% - SOLD (THANX MARK)
ITEM # 58B: Slightly used Proline Hole shot (#9026) w/ proline velocity rims 17mm hex buggy tires tread left 97% - SOLD (THANX RICHIE)
ITEM # 60: GRP TRC 1:8 buggy Cubic tires w/ rims buggy tires tread left 95% - P1835
ITEM # 61A: Used Proline Road Rage tires (#9012) w/ Team Losi Dish Rims 17mm hex buggy tires tread left 80% - SOLD (THANX TIM)
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) – P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new O’Donnell hot glow plugs standard purple long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) - P270
ITEM # 71: HPI Savage xl front and rear skid plates w/ bumpers and Bulkhead Lower Plates - P685
ITEM # 76: HPI Slipper Clutch Pad – P537
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 79: HPI Savage engine mount – SOLD (THANX MARK)
ITEM # 80: HPI savage x engine protector - P365
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 86: RB Concept TM728 standard combustion chamber
ITEM # 87: RB Concept one way bearing
ITEM # 89: Duratrax rotostart backplate - P995
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket – P110/piece
ITEM # 93: Mugen clutch spring 1.0mm - P420
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 96: HPI Racing 17t vented clutch bell – SOLD (THANX MARK)
ITEM # 98: Blue Block After Run Oil 5.25 fl. Oz. – SOLD (THANX GARRICK)
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 – P700/pack of 10
ITEM # 105: HPI Rotostart Starting shaft- P700
ITEM # 106: Losi tire glue standard - P570
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 110: Used Rotostart 2 w/ starting shaft & 1800mah battery pack – SOLD (THANX JEK & YUCHENGCO)
ITEM # 111: Used Nova Cooling Head for Picco .26 - P1750
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe – P750
ITEM # 115: Exhaust gasket – P470/pack of 5
ITEM # 119: NIB Futaba Reciever R603FS - P4351
ITEM # 120: NIB Futaba Reciever R604FS – P4645
ITEM # 121: NIB Futaba Digital Servo S9351 - P4528
ITEM # 122: NIB Futaba Digital Servo S9156 - P4533
ITEM # 123: NIB Futaba Brushless Servo BLS451 - P4621
ITEM # 124: NIB Futaba Brushless Servo BLS452 - P4454
ITEM # 125: NIB Futaba Brushless Servo BLS254 - P4784
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 127: BN W/O Original Packaging Hobbywing Xerun Brushless Motor 4274 – P4755
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 129: NIP Hobbywing ESC Platinum Pro 150a Opto (website: http://www.hobbywing.com/english/ArticleShow.asp?ArticleID=441) – P4885
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs (out of stock)
ITEM # 131: NIB Futaba 3pm – P9000
ITEM # 132: Used Team Losi XBT Buggy tires w/ Team Losi Dish rims 17mm hex. 2 tires 97% tread, 2 tires 90% tread – P1480
ITEM # 133: Used Team Losi Eclipse Buggy tires w/ 17mm hex. 85% tread – P1520
ITEM # 134: Brand NewPro-Grip Performance Devices buggy tires & rims 17mm hex - 1940
ITEM # 135: Used Werks Racing Lugs buggy tires & w/ yellow spoke wheelss 17mm hex. 80% tread – SOLD (THANX STEVE)
ITEM # 136: Brand New Proline Step-up buggy tires & dish rims – P1790
ITEM # 137: Used Panther buggy T905 (Gator) w/ Panther dish wheels 17mm hex. 85% tread – SOLD (THANX JEK)
ITEM # 138:Brand New Proline Crime-Fighter buggy tires w/ proline dish wheels 17mm hex –SOLD (THANX JON)
ITEM # 139:Proline Step-up buggy tires & dish rims (Brand New Tires w/ Used rims) 17mm hex – SOLD (THANX JEK)
ITEM # 140: Used Proline Hole shot (#9026) w/ losi rims 17mm hex tread left 95% - SOLD (THANX MARK)
ITEM # 141: Used Proline Bowtie truggy tires w/ proline dish rims 17mm hex. 85% tread –SOLD (THANX RICHIE)
ITEM # 142: Used Proline Crime Fighter truggy tires w/ proline dish rims 17mm hex. 85% tread – SOLD (THANX KLE)
ITEM # 143: Used Losi XTT truggy tires w/ Losi dish rims 17mm hex. 75% tread – P1260
ITEM # 144: Used Proline 40 series Crime Fighter Tires w/ proline dish rims 23mm hex. 70% tread – P1480
ITEM # 145: Brand New Airtronics 94758z digital highspeed/high torque digital metal gear servo Torque 92 / 115 Oz In @ 4.8 / 6.0V Speed 0.07 / 0.06 sec @ 4.8 / 6.0 V – P3485
ITEM # 146: Brand New HiTec 5996TG Digital Servo Torque: 89/111 oz @ 4.8/6.0V Speed: 0.13SEC/0.10 sec @ 4.8/6.0V – P3185
ITEM # 147: HPI Machined Bulletproof Diff Gear Set – SOLD (THANX JEK)
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) – P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) – P725
ITEM # 150:Hobao D8/T wing & wing mount – P1055
ITEM # 151:Savage 25/x/ss/flux center drive shaft – P635
ITEM # 152:NEW HPI Savage X Roll Bar,Handle,Engine Protector – P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.6% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyer’s reference
We accept orders for hard to find parts (please txt or call if you need more details)
THANX RCTECH !!!
ITEM LOCATION: Cebu
Shipping details:
THANX RCTECH !!!
WTB CHARGER
WANTS TO BUY CHARGER COMPLETE khit walang BOX bsta my manual pwde ring turuan mo ko lhat ng functions para ok
1.5k budget MUST be digital BALANACE charger
complete po lhat ng accessories ng pangcharge khit wlang powersupply pwde
VERY GOOD CONDITION!
batangas RC track
Pare that's good uwi ulit ako sa batangas I will visit your race track.
Great event by the organizers. Nice to meet the friendly racers from Baguio.
Dami kids racers dun... meron mga 6 year olds!!!
Nice race and had fun...thanks to all the people who made it possible and to all baguio racers...nice meeting you...
Just some video and photos from the Tamiya RC event
6 year old kids!!! Wow.
Mr. Ironman, never left the driver stand.
The race board.
http://www.rccartips.com/tamiya-asia...011-baguio.htm
+ YouTube Video | |
The race board.
looking for cheap radios with receiver.
text/call me .09178224217 / 09228224217
FS & LF
for sale hpi rotostart (pinalitan n po ng switch & wla n po battery cover) reserved to Bryan Savage
RFS: change engine & pull start n gmit ko
looking for:
1. hpi savage reverse gear (same po ng nasa pics)
baka po meron kyo sira n reverse module pero ok p yung mga gear n nasa pics
2. lipo low voltage buzzer (2s,3s,4s) bnew or used, if use yung in good/excellent condition
looking for:
item no.1 still looking
item no.2 bought already from champion
THANKS RCTECH
For Sale:
Tamiya Hornet w/ TEU101 and full ball bearings - Php 6,500 (neg)
Tamiya TT01D Type E with Full Ball Bearings, extra chassis , Tamiya RX7 Body Shell, Tamiya Sport Tuned Motor, Tamiya Aluminim Motor Mount, HPI Drift Tires, 3Racing Shocks, 3Racing Aluminum Steering, 3Racing Front One-Way, 3Racing Ball Differential, 3Racing Aluminum Main Shaft, 3Racing Swing Shaft, 3Racing Bevel Gear Shaft, 3Racing Upper Suspension Mount, 3Racing Wheel Adaptor (5mm). - Php 7,500
Tamiya Super Clod Buster - Php 8,500
Competition Electronics Pittbull charger for NiMH and NiCd batts - Php 3,300 (neg)
Proline Caliber SC 2.2"/3.0" M2 (Medium) Tires Mounted on Split Six Black One-Piece Wheels - Php 1,000 (fixed)
if interested just PM me your email address for the pics
09228271641 - Jeff
QC area
09228271641 - Jeff
QC area
