View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
TAMIYA TT-01 FUTABA 2PL 2GHZ
TAMIYA TT-01 (two times lang po pinaandar)
semi set-up
98% Driftech Tires
Kit Light
FUTABA 2PL 2GHZ
complete box and manual
Brandnew Tamiya Super Stock Motor
RFS: Wala pong gumagamit
the Whole Package po 20,000.00
text or call 0921 9930701
0921 9930701
alabang,muntinlupa area
meet @ATC,Festival,Southmall,
semi set-up
98% Driftech Tires
Kit Light
FUTABA 2PL 2GHZ
0921 9930701
looking for:
donut racing cooling head for go.21 engine
used or bnew
pls text me @ 09215209614
used or bnew
good day maam/sir
can you help me find HSP products here in philippines, i snap the string of my pullstarter and i lost my spring. i searched around manila and quezon city but they have no stock almost all of there products are HPI
pull starter code R020 or i you have some replacement springs i'm willing to buy it
if you know where to buy pls send me a message
#09178833986
thank you
i can't upload pictures
#09178833986
thank you
I don't think we have local distributors for HSP Products here in PH. Better buy it online on their website http://www.hispeedmodel.com/ or replace your engine, which i think would be much easier cause of local parts support for the engine. Check your user's manual if the engine can be replaced.
Hello Sir,
I don't think we have local distributors for HSP Products here in PH. Better buy it online on their website or replace your engine, which i think would be much easier cause of local parts support for the engine. Check your user's manual if the engine can be replaced.
my rc is 1/10th scale
for sale
Tamiya M03L Brand New Kit UnAssembled
*includes brand new TEU101bk ESC
*(w/out body & tire set)
3.3k w/ 1 free stick type (nicad) battery pack
Sanyo Ni-Cad Battery Pack 350.each
(2 packs available)
*48P pinion gears 150.each
-14t,17t,23t(sold)
18t,19t,20t,24t (english unit)
tamiya pinion gears 200.each
-14t,17t (brand new/unused)
can trade w/48P 29t,31t,34t
call or txt 0922-8583385
(2 packs available)
-14t,17t,23t(sold)
FOR SALE
TRF-415 Low Friction Front Belt
-New naka pack pa
-Php400
HPI TE37 Rim with HPI T-Drift
-yung TE37 - 3mm offset lahat
-yung T-Drift Twice lang po nagamit sa makinis
-Php700
TRF Blue Titanium Turnbuckles
-ill include 1 pack low friction adjusters
-turnbuckle itself cost 800 pesos brand new
-Php400
Click Image Thumbnails to Enlarge
TA05 Swing Shaft - 46mm
-New in Pack
-Php500
TRF-415 Differential Parts
-2pcs. Low Friction Pulley
-1pc. stock pulley
-1pc. thrust bearing
-4pcs. Differential Plates
-Aluminum Outdrive - Rear
-Php500
Yokomo Altezza and Tamiya R35,, RX7 Bodies
-yung RX7 walang crack
-yung R35 bashed walang bumper
-yung Yokomo Altezza wala din crack pero puro body holes
-Php600 para sa tatlo
-Click Image Thumbnails to Enlarge
Items in Cavite... Pa ship handle nyo shipping... Kapag shell ayaw ko po shipping...
PM, Text, YM, Mail = 09213343302,,[email protected]
-New naka pack pa
-Php400
-Php700
-Php400
-New in Pack
-Php500
-1pc. stock pulley
-Php500
FOR SALE
Futaba PCM 40 mhz receiver with 40.695 crystal - P1k
Associated Factory Team 2wd Buggy B4
Box and Manual
2 Painted bodies, Rolling chassis, extra rear tires
P5K
CRT 0.5
extended chassis
rolling Chassis with box and Manual
P5k
NOVAK Velociti Brushless Motor 4.5R
P2K
Novarossi .21-5K
P8k
RC10GT with aluminum chassis,
RB engine and aluminum tuned pipe.
Stock servos, no Tx and Rx.
Reciever 5 cell battery
complete with box and manual.
P5K -------------------------------------------SOLD!
Futaba Mini Servo S3002, 2Pcs--------------SOLD!
Futaba 9402, 2pcs - P1.5K each-------------SOLD!
KO PROPO 2144 Digital Servo 1 pc - P2K---SOLD!
SMS only +639178927243 or +639228154402
Box and Manual
P5K
CRT 0.5
extended chassis
P5k
P2K
Novarossi .21-5K
P8k
FOR SALE
X-Ray Shock Springs for touring cars.. Bnew with box and manuals.. some are lost but i'll throw in a set of tamiya springs(silver) can also be used in any touring shocks.. e.g. Tamiya, HPI, Kyosho, Associated, Yokomo.. what you see is what you get.. it indicates what colors/pairs are available and what is missing.. 600pesos
Kyosho GSX-11 Pull Start for Pure Ten series Bnew -SOLD-
TAMIYA Adspec Transmitter Radio.. First version pistol type, in good working condition.. with crystal 27mhzreciever not included.. -SOLD to hdny-
HOTBODIES Cyclone D4 parts (sold as package) 300pesos
61422 Front Suspension Arm Set
61442 Rear Shock Tower Graphite
61426 Front Hub Carrier
61425 Rear Hub Carrier
HPI R40 parts (sold as package) 300pesos
75005 Mid Brace 2mm/purple
87084 2Speed Lock Nut
72445 R40 Differential Shaft 6x25mm (gear diff/2pcs)
72444 Brake disc Rotor (stainless steel)
HPI Assorted Parts for RS4/Pro4 300pesos
A187 Threaded Shaft 4-40x24mm (4pcs)
Z136 Ball End 4-40 (4pcs)
75121 Pro4 Pivot Ball 3x5mm (4pcs)
A318 Rod End 5.8x18mm (8pcs)
A316 Rod End 5.8x12mm (8pcs)
BO36 Thrust Bearing 4x9x4mm
93510 Turnbuckle M4x20mm
HPI R40 Stock Chassis aluminum (purple bnew)
HPI R40 Upgraded/Lightweight/Thick Aluminum Chassis (Silver/bnew) both for 600pesos
Tamiya Aluminum Heatsink for 540type motor silver, used but not abuse 200pesos
KYOSHO Super10 Chrome Mesh Rims for Front/Narrow (pair) bnew 300pesos
Hirobo Tail Blades (white plastic OEM) bnew 200pesos
Master Airscrew Nylon Propeller 6x11 150each
Hirobo Glow Plug Extension for Shuttle ZX/ZXX, Genuine Hirobo/slightly used 250 pesos
KYOSHO Cessna 182 Skylane at KYOSHO Trainer 40 18K for the package
Both Ready to Fly na.. both kit individually equipped with 3003 servos, Futaba Reciever, O.S. 40FX Engine, Proppeller, with battery reciever at voltage indicator.. and they do share one radio.. yes isang "RADIO" lang for both plane and it is a Futaba SkySport.. yung trainer were flewn in Sta. Rosa Laguna siguro for 10hrs while yung cessna ay hindi pa napalipad both in good condition and no defects whatever.. SOLD AS SET LANG PO.. DI PUWEDE BREAK YUNG PACKAGE... sold as SET.. as "SET" huwag makulet.. makulet papaluin sa puwet...
No Reservations.. Priority to those who can get the items first.... Please indicate your rctech handle when texting para di nakakalito at maiwasan ang bogus, no name no reply.. no chikka text din.. lowered na yung price at last price na po.. sobrang baba na at bentang palugi na kaya please.. minimum po sana ng 500pesos worth for meet ups near Manila/Binondo/Caloocan/C-3 Road/5th Ave at R.Papa station area para po di lugi sa pamasahe.. or you can pick up the items near R.Papa station LRT line 1, puwede din po thru LBC but sagot niyo shipping.. also payable thru BPI savings account.. Thanks po and God bless
09238817827
09238817827
OS .21 Max RG engine
Attachment 572783
Attachment 572784
Attachment 572785
OS .21 ENGINE FOR SALE
comes with the FF:
EXTRA GLOW PLUG
IGNITER with Charger
FUEL BOTTLE
5 LITER FUEL JUG
AIR FILTER
PIPE
the engine has good compression and still race worthy
SOLD MY INFERNO
ALL THIS FOR 3,000PHP
for testings and fittings will do it at my place
call or text
09228236833
Benedict
Attachment 572784
Attachment 572785
comes with the FF:
EXTRA GLOW PLUG
FUEL BOTTLE
5 LITER FUEL JUG
AIR FILTER
PIPE
SOLD MY INFERNO
call or text
09228236833
Benedict
guys, anyone selling an rc10 b44 kit here? thanks!
Selling excess items:
New sport tuned motor + tamiya blue heatsink + carbon fiber upper deck for TT-01 P1,200.00
Used Johnson 540:P200.00
Brand new light paddles for shuttle (Blue) P500.00
Hirobo Starter Shaft used:P500.00
Slightly used wooden Hirobo Blades: P800.00
450 copter x pitch guage P250.00
Futaba GV-1 governor purchased July 2009
2 sensors 1 is brandnew. P6500.00 neg
Raptor 30 v1- P20,000.00 (THIS IS NEGOTIABLE- MAKE ME AN OFFER)
new canopy
almost new o.s. .32 engine
tt power mufler
wood blades
4 3001 servos
1 3004 servos
futaba gy240
rx battery
with some spareparts
Just add fuel and reciever and fly
(rfs: moving to a .50 size)
pls. txt 0916-4330416. Item location Antipolo or the Fort Area can also meet up in Ortigas, Katipunan Area
Tnx. RC Tech
ALSO LOOKING FOR
1PC FUTABA 3050
3 pcs 3001 servos or swap my 3 pcs 3003 (budget 300 each) for a friend
Pls txt or pm offers
new canopy
tt power mufler
wood blades
4 3001 servos
1 3004 servos
futaba gy240
rx battery
Tnx. RC Tech
ALSO LOOKING FOR
1PC FUTABA 3050
shinwa motor dresser ....800.00
Reedy Lipo 35c 4200mah New, just installed deans plug never use......4200.00
PROLINE BOWTIE MT MAX SIZE, PROLINE HARD MOULED INSERTS, PROLINE DEEP OFSET WHEELS.
SELLING ..........................1.0K FOR 4PCS
NOTE 1 HEX OF THE WHEEL IS DAMAGE...I EPOXY STEEL THE HEX TO IT.
http://i32.photobucket.com/albums/d1...emtwheels2.jpg
32pitch steel pinion gear 17 and 19 teeth
will work for Emaxx-1, 2 and E-revo...price 200.00 each
Team Losi NXT
Includes, OS plug w/ pull start, started box, original manifold and muffler,
3 pcs igniter, fuel bottle, rx pack battery 600mah, 800ml 20% fuel, box and manual
Price...............5.5k
What you need 2 pcs servos, servo saver, tx and rx
PM or txt 0917-8911698 office hrs. landline 743-2653
pls. include you name with your user name so I can reply.
pls dont txt 10 pm to 6am.
parts
prt
