View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
RCmanila: Yes you are right open dapat. But in any case sir it has been decided to use the spec tire instead of open para masanay lang tayo ng ibang gulong for the coming HPI race in China. In fact, the rules is subject to change without prior notice. Thanks!
White Fang: Good question sir. This week test tires muna dadating dito. Different compounds yun which I will approve for all stock classes use. Yes, Solaris spec tire will be available as soon possible definitely before Sept 26.
http://www.solarisrp.com/tires.htm
Suggestion lang naman hehe
for sale
SERPENT 720 - 4K
08 version kit
hop ups
some spares
w/ box and manual
http://s686.photobucket.com/albums/v...t=IMG_2807.jpg
NOVAROSSI 353 PLUS 2 ENGINE - 5.5k
onroad 08 version
w/ box and manual
very good compression
new bearings and conrod installed
http://s686.photobucket.com/albums/v...t=IMG_4251.jpg
MUGEN SEIKI MTX4 BNEW PARTS 3.5k neg
sold as set
bnew and sealed
http://s686.photobucket.com/albums/v...t=IMG_4257.jpg
rfs - palit ng hobby
09189239320
08 version kit
hop ups
some spares
w/ box and manual
onroad 08 version
w/ box and manual
sold as set
bnew and sealed
09189239320
for sale:
hobao 46tooth spur gear for standard differentials( almost brandnew 99.9%)-900
ofna aftermarket .21 cooling head will fit GO ENGINES & NOVAROSSI (not suited for engines that uses turbo plugs)once lang nagamit -1.2k
hobao center torsen differential (needs new rubber o-rings)-1.5k
43tooth spiral cut ring gear front and rear-600
modified hobao hyper st nearly pro(80% pro) rolling kit with some brandnew spares,wheels and tires,rx batt etc.very well maintained no hidden defects,no broken bearings-7.5k
hitec hs5645mg-SOLD
all prices are fixed
looking for a friend:
OS VZB VSPEC SLEEVE-kahit loose compression na basta walang gasgas or na-chip-off na inner part ng sleeve.baka may mga nakakalat lang kayo dyan sa mga toolbox nyo na hindi na pakikinabangan.
pls text me @ 09215209614- vince- binan laguna area
pls include your name and username when texting
thanks!
hitec hs5645mg-SOLD
thanks!
Pls. visit our website
Magic hand rc airplane
www.alphamodel.ucoz.com
Magic hand airplane
new itemswww.cyclonetoy.com
for inquire Globe 09158884491
suncell 09239392366
Pre Order
30% YAK54 87in 50-60cc RC Gas Airplane 20,850 ARRIVING SOON!!!
Length: 1919mm(75.6in)
Wingspan: 2210mm (87in)
Wing area: 87.4dm2(1354sq in)
Engine 50-60cc gas
Weight: 7.3-7.7kg (16-17 lbs)
Radio: 4ch-6ch
ARRIVING SOON
YAK54 26-40cc Gas Airplane ARRIVING SOON!!!
http://www.sdshobby.com/yak54-2640cc...lane-p-55.html
Length: 1690mm (66.5in)
Wingspan: 1850mm (73 in)
Wing area: 65dm2 (1007 sq in)
Engine: 140~180 4C
26-40cc gas
Weight: 4.2-5.0kg (9.1-11 lbs)
Radio:4ch-6ch
COLOR="Blue"]Coming soon On SEPTEMBER[/COLOR]!!!!!
Hitec HS-7950TH
Motor Type: Coreless
Bearing Type: Dual BB
Speed: 0.15 / 0.13 sec @ 60 deg.
English Metric
Torque: 403 / 486 oz./in. (6.0v/7.4v)
etailed Feature Descriptions
# G2 Digital Circuit
# Titanium Gear Train (MK first gear)
# Ultra Performance Coreless Motor
# Heatsink Case
# (8) O-Rings for Water/Dust/Fuel protection
# Dual Ball Bearing Supported Output Shaft
Programable Features Include:
* Dead Band Width
* Direction of Rotation
* Speed of Rotation (slower)
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
* Resolution* (default is high resolution)
* Overload Protection* (default is off)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers.
http://www.cyclonetoy.com/list_1.asp?id=1897
New DLE30 30cc gasoline engine 13.500 ARRIVING SOON Reserve 2 engine
1/10th High performance drift wheels 1,100 per set (4 rim and 4wheel per set)sale
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power supply for B6 and B5 850.00 ship
Brandnew in box intelellect 7.2 volts 3,500 mah nicd stick pack 1,200 ship
MAX FORCE 2000 mAh∕11.1V FOR futaba, jr GUNTYPE TRANSMITTER 1.450 free shipping
MAX FORCE 2000 mAh∕11.1V FOR futaba.spektrum,jr AIR TRANSMITTER 1,450freeshipping
Hitec HS-85MG Metal Gear Micro 1,200 ea. 2 pcs stock only
L: 29mm x W: 13mm x H: 30mm (1.14" x 0.51" x 1.18")
Transit: 0.16 sec/60° (4.8V) 0.14 sec/60° (6.0V)
Torque @ 4.8V: 3.0 kg-cm, (41.66 oz-in)
@ 6.0V: 3.5 kg-cm, (48.6 oz-in)
Weight: 21.9g (0.77oz)
T plug connector 3 pcs set male and female 200.00
Imax B6 Charger [/COLOR] sold out arriving soon 3 pcs avail.
with aluminum case complete connector and
manual
Features;
Microprocessor controlled
Delta-peak sensitivity
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 580g
combo price imax b6 with 5 amp power supply free shippingsold out arring soon
ImaxB5 2,750.00 in stock
Specifications:
Operating voltage range: 10.0~18.0Volt
Circuit power: Max. 50W
Charge current range: 0.1~5.0A
Current drain for balancing Li-po: 200mAh/cell
NiCd/NiMh battery cell count: 1~14cell
Li-ion/Polymer cell count: 1~5series
Pb battery voltage: 6V, 12V
Weight: 280g
Dimensions: 130*80*23mm
Program card 650.00
http://www.cyclonetoy.com/list_1.asp?id=122
regulator and ubec
UBEC-3A 880.00 ship
LI-PO REGULATOR 6V 780.00 ship
Voltage Display /Protector >> Volts (DC 3.7-20V LCD VOLTMETER) 1,750.00.00
1. 12 bits microchip IC design, reading voltage accurately.
2. Large LCD display shows battery voltage and 7-step capacity icon.
3. Capable of measuring 1-2-3-4 cell (3.7V-7.4V-11.1V-14.8V) Li-Po or 4.8V-6.0V-9.6V Ni-Cd/Ni-MH battery packs.
4. The test result shows under condition of 300mA current loading.
5. Test range is between 3.7V-20V.
6. Reverse voltage protection.
Futaba GY240 2,600 ingood condition 2,000 ship [/COLOR]
all Brandnew servo Free shipping
Hitec HS7955TG 3,600 1 pc avail
Hitec 7985MG 3,000 5 pcs in stock
Hitec 5245MG sold out pcs in stock
Hitec 645MG 1,600 in stock
HS-7966HB Servo 3,000
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-68F to +140F)
Operating Speed (4.8V): 0.10sec/60° at no load
Operating Speed (6.0V): 0.09sec/60° at no load
Stall Torque (4.8V): 92oz/in. (6.6kg.cm)
Stall Torque (6.0V): 111oz/in. (8kg.cm)
Motor Type: Coreless Carbon Brush
SM Digital 57g/12KG Servo(Double Bearing)' 1,500 each free shipping
Description:
57.0g with torque 11.9kg-cm (4.8V) ;12.8kg-cm (6.0V); Wire: 20cm
Digital Micro Servo MG90S (Economic Version) 550.00 each
*Dimensions: 22.8*12.2*28.5mm
*Weight: 13.4g
*Operating Speed : 0.10sec/60degree(4.8v) 0.08sec/60degree(6.0v)
*Stall Torque : 1.8kg/cm(4.8v) 2.2kg/cm(6.0v)
*Temperature Range: 0 to +55 Degree C
*Dead Band Width: 5usec
Operating Voltage:4.8-6 Volts
Gear type: metal gear
tower pro 9G servo SG-90 350.00 each
Dimensions: 22*11.5*27mm
Operating Speed (4.8V no load): 0.12sec/60 degrees
Stall Torque (4.8V): 17.5oz/in (1.2 kg/cm)
Temperature Range: -30 to +60 Degree C
Dead Band Width: 7usec
Operating Voltage:3.0-7.2 Volts
Hawk propeller brand (Wood)
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=21
23 x 8 c 880.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
10 x 4.7 electric prop. 150.00
8 x 4 E. propeller 150.00
http://www.cyclonetoy.com/list_1.asp?id=568
Telemetry Combo Pack 3,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
engine head for savage .25 2,000 neg
98% brandnew Tamiya Super Modified Motor 11T 900.00 each
E.F wheel spats for yak54 for 120class = 750.00
E.F landing gear fairing for yak54 74" = 750.00
[SIZE="3"]HPI savage reprice 11,000
with .25 engine very fresh
2 pcs mg995 servo
spare brand new shell
/SIZE].
BrandnewTeam losi AfterShock with integy upgrade parts 32,500 neg. 28,900 reprice
box and manual and spare stock parts
no electroni include
Hot Bodies UFO Wheels
for the HPI Savage Truck. 2,300 reprice/B][/COLOR]
EV 97 airplane with OS 52 engine complete standard futaba servo 5,800.00
BRAND NEW IN box Voyager™ 40 MkII ARF 7,800
Wingspan: 59.5 in (1510mm)
Wing Area: 602 sq in (38.8 sq dm)
Weight: 5.1 lb (2310g) Fuselage Length: 46.8 in (1190mm)
Requires: 2-stroke .40-.46 cu in (6.5-7.5cc) engine & 4-channel radio w/4 standard servos
Brandnew Goldberg Tiger 2 ARF .40-.46,61" 8,900.00
Wing Span: 61" (1549mm)
Wing Area: 680 sq in (43.93 sq dm)
Wing Loading: 16.80 oz/sq ft (51.26 g/sq dm)
Airfoil: Semi-Symmetrical Low-Wing
Fuselage Length: 56" (1422mm)
Weight: 4.75-5.25lbs (2155-2381g)
Engine: .40-.46 (6.5-7.5cc) 2-stroke
or .40-.50 (6.5-8.2cc) 4-stroke
Radio: 4 Channel (dual ailerons, elevator, rudder, throttle)
Servos: 5 Standard
Misc. Items: Building and Field Equipment.
Brandnew O.S. 61FX ABL w/ Bisson O.S. .61 FX Pitts Muffler and stock Muffler 11,680.00
Brandnew S.TIGRE GS90 6,500.00
Magic hand airplane
suncell 09239392366
Pre Order
Engine 50-60cc gas
Radio: 4ch-6ch
ARRIVING SOON
Engine: 140~180 4C
26-40cc gas
Radio:4ch-6ch
Hitec HS-7950TH
English Metric
# Heatsink Case
* Dead Band Width
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
manual
Features;
Time limit function
Spec.
Weight: 580g
Specifications:
Weight: 280g
Program card 650.00
regulator and ubec
UBEC-3A 880.00 ship
Description:
*Weight: 13.4g
23 x 8 c 880.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
Key Features
2 pcs mg995 servo
/SIZE].
Servos: 5 Standard
just a suggestion lang, when you do the tire testing, best it be done mid to early afternoon (between 12-3pm). as we all know at JP Raceway, the track conditions while the sun is still up is different then during the late afternoon/early evening. if they work fine when the temps are up, then you get a better assurance that they will indeed be good through the course of a race day.
another thing, when do you announce who falls under novice and pro stock?
lastly, for mod open tires naman diba? just making sure. thanks in advance.
MUGEN MBX5 buggy, OS .21 V spec VZB engine, OS pipe and Kyosho GP10
RUSH SALE!!!!!!!!
RCManila: I can't merge Novice and Super Pro for this race since the objective of the series is to give chance for the novice to win a series. I will post here later on the driver ratings for each class. Thanks for your query.
robo: Tires used the from our last HPI Challenge in Bangkok were HPI Gumballs and I should say they are good for one use only at RCS. Not the best choice really but everyone had to use it. As usual. For this year's tires for China, still is a question mark. They announced that Gumball will be scrapped out as the hand out tire and nobody knows at this time what spec tire to use in China. So right now, I think Solaris is our best choice as spec tire for our series and not Gumballs which really dont last or handle that well. Yup testing is a must in the morning considerably. In fact the track in Shanghai is not disclosed yet so I can't say whether it is indoor or outdoor pa. There were last minute changes sa venue kasi from Guangzhou to Shanghai so I really cant tell the track conditions. As for open mod, you may use any tire and its open naman if there is a quorum of at least 5 .
[Kyosho Giga-Crusher Nitro Remote Control Monster Truck. With two x 26cc engines,Three speed transmission and reverse gear
sell @ 20k
item is in cebu, free shipping po
you can pm me or email @ [email protected]
or txt @ 0917480066 or 09239713080 Francis "nuki" Del Rosario
OS .91 sx ring heli engine brand new
OS Crankcase 91SX H with crankshaft and cover plate brand new
OS crankcase 91SX H only brand new
all @ 12k item is in cebu free shipping
you can pm me or email me @
[email protected]
or sms me @
09174180066
09239713080
sell @ 20k
[email protected]
or sms me @
09174180066
09239713080
Selling my RC
HPI Rush Evo(Nitro)
0.15T Engine-Good running condition
Brandnew Rotostarter with extra backplate.
with servo
1/2 half gallon nitro fuel
1 glow plug and charger
Extra rims (front)
Selling it for 6000 slightly negotiable
Tamiya Toyota Supra(Drift Specs)
bought last May completely assembled last July
All stock complete box and accesories
With servo and TEU-101BK
Orig price:6,800 (Tamiya Ayala)
selling it for 6500 slightly negotiable
TX and RX already sold
RFS: Quit R/C
Items negotiable
Item in Cebu
Pics to follow
Kindly PM or Text 09216777699 indicate your username
HPI Rush Evo(Nitro)
with servo
Extra rims (front)
RFS: Quit R/C
Items negotiable
Item in Cebu
Pics to follow
up ko lang!
looking for: xray m18 pro
I'm looking for 1:18 xray m18 pro. My contact no. is 09273062196
looking for black foot rims
need blackfoot rims special the front wheels.
pm me or txt me for the price
09052198844
09052198844
Robo: you got it
HPI Challenge in China will provide free handout tires and motors in all classes. For short, it's free!
