View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Novak HVmax Pro
FS: Novak HVMAX Pro w/ 6.5 5mm shaft ( Almost Bnew installed in a kit only never run , setup only ) - 12K nego if pick up Ok for trade/swaping 2 bnew Lipo batts ( 3800mah or above , 20c and fit for T4 ) and BNew B6 charger OR SC10
Coming Soon!
For sale:
HITEC HS-5645mg DIGITAL SERVO(almost brandnew,once lang nagamit)
selling for 1.7k
rfs:hitec 7955tg
looking for a friend:
OS VZB VSPEC SLEEVE-kahit loose compression na basta walang gasgas or na-chip-off na inner part ng sleeve.baka may mga nakakalat lang kayo dyan sa mga toolbox nyo na hindi na pakikinabangan.
text me @ 09215209614-vince-binan laguna area
selling for 1.7k
rfs:hitec 7955tg
LF: Monster Truck Wheels
Looking for MT wheels and tires. One set. Used but in good condition. 12mm hex.
09167815445
09167815445
NEW ARRIVALS!!!!!
AVAILABLE FOR SANWA, FUTABA, KO PROPO AND SPEKTRUM
IN DIFFERENT DESIGNS AND COLORS!!!
FEEL THE DIFFERENCE!!
-----------SOREX BACK IN STOCK TOO!!------------------------
NEW ARRIVALS PART II
3RACING AND HOBBY PRO DRIFT PARTS AND ACCESORIES
WHEEL and TIRE SETS
LIGHT SETS
BODY ACCESORIES AND LOTS LOTS MORE
CHECK EM OUT AT THE SHOP!!!!!
WHEEL and TIRE SETS
LIGHT SETS
Looking for:
Any brand FM Radio TX and RX (preferably Futaba) that operates in the 27mHz range.
sana at a reasonable price...
pls PM me for offers
thanks in advance
thanks in advance
Pre order within this week
Pls. visit our website
Magic hand rc airplane
www.alphamodel.ucoz.com
Magic hand airplane
new itemswww.cyclonetoy.com
for inquire Globe 09158884491
suncell 09239392366
Coming soon!!!!!
Hitec HS-7950TH
Motor Type: Coreless
Bearing Type: Dual BB
Speed: 0.15 / 0.13 sec @ 60 deg.
English Metric
Torque: 403 / 486 oz./in. (6.0v/7.4v)
etailed Feature Descriptions
# G2 Digital Circuit
# Titanium Gear Train (MK first gear)
# Ultra Performance Coreless Motor
# Heatsink Case
# (8) O-Rings for Water/Dust/Fuel protection
# Dual Ball Bearing Supported Output Shaft
Programable Features Include:
* Dead Band Width
* Direction of Rotation
* Speed of Rotation (slower)
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
* Resolution* (default is high resolution)
* Overload Protection* (default is off)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers.
http://www.cyclonetoy.com/list_1.asp?id=1897
New DLE30 30cc gasoline engine 13.500 ARRIVING SOON Reserve 1 engine
DLE55 55cc gasoline engine ARRIVING SOON
1/10th High performance drift wheels 1,100 per set (4 rim and 4wheel per set)sale
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power suply for B6 and B5 850.00 ship
Brandnew in box intelellect 7.2 volts 3,500 mah nicd stick pack 1,200 ship
MAX FORCE 2000 mAh∕11.1V FOR futaba, jr GUNTYPE TRANSMITTER 1.450 free shipping
MAX FORCE 2000 mAh∕11.1V FOR futaba.spektrum,jr AIR TRANSMITTER 1,450freeshipping
Hitec HS-85MG Metal Gear Micro 1,200 ea. 2 pcs stock only
L: 29mm x W: 13mm x H: 30mm (1.14" x 0.51" x 1.18")
Transit: 0.16 sec/60° (4.8V) 0.14 sec/60° (6.0V)
Torque @ 4.8V: 3.0 kg-cm, (41.66 oz-in)
@ 6.0V: 3.5 kg-cm, (48.6 oz-in)
Weight: 21.9g (0.77oz)
T plug connector 3 pcs set male and female 200.00
Imax B6 Charger 3,250.00 ship [/COLOR] in stock 3 pcs avail.
with aluminum case complete connector and
manual
Features;
Microprocessor controlled
Delta-peak sensitivity
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 580g
combo price imax b6 with 5 amp power supply 3,750 free shipping 3pcs stock
ImaxB5 2,750.00 in stock
Specifications:
Operating voltage range: 10.0~18.0Volt
Circuit power: Max. 50W
Charge current range: 0.1~5.0A
Current drain for balancing Li-po: 200mAh/cell
NiCd/NiMh battery cell count: 1~14cell
Li-ion/Polymer cell count: 1~5series
Pb battery voltage: 6V, 12V
Weight: 280g
Dimensions: 130*80*23mm
Program card 650.00
http://www.cyclonetoy.com/list_1.asp?id=122
regulator and ubec
UBEC-3A 880.00 ship
LI-PO REGULATOR 6V 780.00 ship
Voltage Display /Protector >> Volts (DC 3.7-20V LCD VOLTMETER) 1,750.00.00
1. 12 bits microchip IC design, reading voltage accurately.
2. Large LCD display shows battery voltage and 7-step capacity icon.
3. Capable of measuring 1-2-3-4 cell (3.7V-7.4V-11.1V-14.8V) Li-Po or 4.8V-6.0V-9.6V Ni-Cd/Ni-MH battery packs.
4. The test result shows under condition of 300mA current loading.
5. Test range is between 3.7V-20V.
6. Reverse voltage protection.
Futaba GY240 2,600 ingood condition 2,000 ship [/COLOR]
all Brandnew
Hitec HS7955TG 3,600 2 pcs avail
Hitec 7985MG 3,000 5 pcs in stock
Hitec 5245MG 1,500 10 pcs in stock
HS-7966HB Servo 3,000
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-68F to +140F)
Operating Speed (4.8V): 0.10sec/60° at no load
Operating Speed (6.0V): 0.09sec/60° at no load
Stall Torque (4.8V): 92oz/in. (6.6kg.cm)
Stall Torque (6.0V): 111oz/in. (8kg.cm)
Motor Type: Coreless Carbon Brush
SM Digital 57g/12KG Servo(Double Bearing)' 1,500 each free shipping
Description:
57.0g with torque 11.9kg-cm (4.8V) ;12.8kg-cm (6.0V); Wire: 20cm
Digital Micro Servo MG90S (Economic Version) 550.00 each
*Dimensions: 22.8*12.2*28.5mm
*Weight: 13.4g
*Operating Speed : 0.10sec/60degree(4.8v) 0.08sec/60degree(6.0v)
*Stall Torque : 1.8kg/cm(4.8v) 2.2kg/cm(6.0v)
*Temperature Range: 0 to +55 Degree C
*Dead Band Width: 5usec
Operating Voltage:4.8-6 Volts
Gear type: metal gear
tower pro 9G servo SG-90 350.00 each
Dimensions: 22*11.5*27mm
Operating Speed (4.8V no load): 0.12sec/60 degrees
Stall Torque (4.8V): 17.5oz/in (1.2 kg/cm)
Temperature Range: -30 to +60 Degree C
Dead Band Width: 7usec
Operating Voltage:3.0-7.2 Volts
Hawk propeller brand (Wood)
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=21
23 x 8 c 880.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
10 x 4.7 electric prop. 150.00
8 x 4 E. propeller 150.00
http://www.cyclonetoy.com/list_1.asp?id=568
Telemetry Combo Pack 3,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
engine head for savage .25 2,000 neg
98% brandnew Tamiya Super Modified Motor 11T 900.00 each
E.F wheel spats for yak54 for 120class = 750.00
E.F landing gear fairing for yak54 74" = 750.00
[SIZE="3"]HPI savage reprice 11,000
with .25 engine very fresh
2 pcs mg995 servo
spare brand new shell
/SIZE].
BrandnewTeam losi AfterShock with integy upgrade parts 32,500 neg. 28,900 reprice
box and manual and spare stock parts
no electroni include
Hot Bodies UFO Wheels
for the HPI Savage Truck. 2,300 reprice/B][/COLOR]
EV 97 airplane with OS 52 engine complete standard futaba servo 5,800.00
BRAND NEW IN box Voyager™ 40 MkII ARF 7,800
Wingspan: 59.5 in (1510mm)
Wing Area: 602 sq in (38.8 sq dm)
Weight: 5.1 lb (2310g) Fuselage Length: 46.8 in (1190mm)
Requires: 2-stroke .40-.46 cu in (6.5-7.5cc) engine & 4-channel radio w/4 standard servos
Brandnew Goldberg Tiger 2 ARF .40-.46,61" 8,900.00
Wing Span: 61" (1549mm)
Wing Area: 680 sq in (43.93 sq dm)
Wing Loading: 16.80 oz/sq ft (51.26 g/sq dm)
Airfoil: Semi-Symmetrical Low-Wing
Fuselage Length: 56" (1422mm)
Weight: 4.75-5.25lbs (2155-2381g)
Engine: .40-.46 (6.5-7.5cc) 2-stroke
or .40-.50 (6.5-8.2cc) 4-stroke
Radio: 4 Channel (dual ailerons, elevator, rudder, throttle)
Servos: 5 Standard
Misc. Items: Building and Field Equipment.
Brandnew O.S. 61FX ABL w/ Bisson O.S. .61 FX Pitts Muffler and stock Muffler 11,680.00
Brandnew S.TIGRE GS90 6,500.00
Magic hand airplane
suncell 09239392366
Coming soon!!!!!
Hitec HS-7950TH
English Metric
# Heatsink Case
* Dead Band Width
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
manual
Features;
Time limit function
Spec.
Weight: 580g
Specifications:
Weight: 280g
Program card 650.00
regulator and ubec
UBEC-3A 880.00 ship
all Brandnew
Description:
*Weight: 13.4g
23 x 8 c 880.00
20 x 8 c 850.00
20 x 10 c 840.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
Key Features
2 pcs mg995 servo
/SIZE].
Servos: 5 Standard
for sale
ITEMS ARE NEGOTIABLE [hirit lang ng hirit]
1pc Silver can [hindi ksma motor mount at pinion]- P200 - P150 REPRICED
http://i107.photobucket.com/albums/m...e/DSC_3839.jpg
1pc Tamiya GT Tuned Motor 25T [needs a new pair of brushes] - P400 - P350 REPRICED
450 - ill include a new pair of brushes
http://i107.photobucket.com/albums/m...e/DSC_3827.jpg
1pc Power Supply for your chargers 12v 5amps - P800 - P750 REPRICED
http://i107.photobucket.com/albums/m...e/DSC_3855.jpg
rfs: hindi kona sila kailangan
XRAY T1 '05 (ARTR) P10,500 [negotiable] [no swaps/trades]
rfs:selling for a friend
- HPI s15 shell w/ light buckets [f/r]
- w/ FrontOneWay
- JR Racing Z270 servo
- Futaba mc330cr esc
- Tamiya BZ 23T motor
- Rims with 40% drift tyres
- Futaba mj AM w/ crystals
- DIY battery strap
- no batt included
pics:
http://i107.photobucket.com/albums/m...e/DSC_3842.jpg
http://i107.photobucket.com/albums/m...e/DSC_3843.jpg
http://i107.photobucket.com/albums/m...e/DSC_3845.jpg
http://i107.photobucket.com/albums/m...e/DSC_3846.jpg
http://i107.photobucket.com/albums/m...e/DSC_3847.jpg
http://i107.photobucket.com/albums/m...e/DSC_3848.jpg
http://i107.photobucket.com/albums/m...e/DSC_3849.jpg
http://i107.photobucket.com/albums/m...e/DSC_3850.jpg
http://i107.photobucket.com/albums/m...e/DSC_3851.jpg
SOLD ITEMS
1pc Futaba S3003 Servo - P300 - sold to gab3r7
1pc Futaba FP-R122JE AM RX 27mhz - P300 - sold to gab3r7
1pc 3800mah intellect nimh battery w/ deans plug [charge numbers 3800+] - P900 - sold to sir glenn
1pc 3700mah tamiya nimh battery w/ deans plug [charge numbers 3100-3200] - P700 - sold to sir glenn
Salamat sa inyo mga sirs!
contact info:
YM: akosigeloman
Cel #: 09276478065
bilin niyo na mura na toh! para makapag lipo na ulit! wo0ho0! thanks!
meeting spots:
Alabang [Festival Mall, ATC]
Makati [Glorietta, PS1]
TAFT [DLSU, CSB]
Pque [Sucat, Bicutan]
Pasensha na nung una na malalaki yung pics links na lang siya
Peace
- w/ FrontOneWay
- DIY battery strap
- no batt included
pics:
SOLD ITEMS
contact info:
YM: akosigeloman
Cel #: 09276478065
meeting spots:
TAFT [DLSU, CSB]
Peace
MUGEN MBX5 buggy, OS .21 V spec VZB engine, OS pipe and Kyosho GP10
Trader Rating: 20 (100%+)
FOR SALE!
BRAND NEW!
SPEKTRUM DX6i
- incl. AR6200 full range DSM2 receiver
- incl. 110vac overnight wall charger
- incl. sealed 4pcs. size AA spektrum rechargeable batteries
- incl. box and manual
will INCLUDE!
BRAND NEW! (still in a box)
GWS DHC2 BEAVER KIT
- incl. brushed motor (b/n of course)
FOR PhP 9K ONLY! (Last price na po )
(SELLING AS PACKAGE ONLY)
HITEC FLASH-5 X SYSTEM RADIO (Used but in very good condition)
- incl. ELECTRON 6 35MHZ 6chl. receiver
- channel assignment /5 channel
- digital trims
- 5 model memory
- countdown timer feature
- mxingfunctions,,,elevon and V tail
- data reset feature
- initial mode program review
- epa,era,dual rate
- servo reverse
- glider acro fkp1 and glider flap2
- aileron/rudder mixing
- glid mode or glid mode program supplement
- glid acro or combination aerobatic glder supplement
FOR PhP 5.5K ONLY! (FIRM...no last price )
CALL/TEXT me at 0918-925-3968 (Leevan)
meet-ups
along naia, sucat road, alabang, laguna area --- during weekdays
weekend naia, moa area only.
BRAND NEW!
SPEKTRUM DX6i
will INCLUDE!
GWS DHC2 BEAVER KIT
- digital trims
- 5 model memory
- epa,era,dual rate
- servo reverse
meet-ups
pro D spec r- 17k
(3 months old hindi na ginagamit) now accepting trade any items psp+cash or xbox360 or ps3 or pc+cash or ofer lower kit+csah or str8 swap pm or txt lang
o and i do accept iphone+cash or ako mag add if mataas na klaseng iphone ty
cash 17k
swap 19k
walang gas gas
Chassis Protector since day one
hop ups palang 5k na
- FOW
- titanium Screws and some bolts
- Stabilizers "soft"
- servo saver
- body post intentions
- orange spacers
- protective film
PICS
http://img.photobuck.../Photo-0064.jpg
http://img.photobuck.../Photo-0065.jpg
http://img.photobuck.../Photo-0066.jpg
http://img.photobuck.../Photo-0067.jpg
http://img.photobuck.../Photo-0063.jpg
shells
impala RARE-1.5k http://img.photobuck.../Photo-0058.jpg
ALL PRICE ARE FIXED. AND NO TRADE . NEED CASH. BAWAL UTANG
warning device -200 reserve to lito
pm phabling214
txt 09173790202
INDICATE YOUR NAME WHEN TXTING TY
added items:
am crystal 27.195 bnew 350 sa lils - 250 nalng bnew
futaba am receiver -400nakita ko na
RIMS
old school 800 - http://img.photobuck...es/IMG0035A.jpg
shiny 600- http://img.photobuck...es/IMG0036A.jpg
may crack to so 200 petot nalng - http://img.photobuck...es/IMG0037A.jpg
yung 2 painted red 2 painted yellow - 300 -http://img.photobucket.com/albums/v464/shabadoodles/IMG0038A.jpg
painted gold 300- http://img.photobuck...es/IMG0039A.jpg
2 set for 400 petot - http://img.photobuck...es/IMG0041A.jpg
all rims for 1.7k all out ksama gulong
eto iba pics -http://img.photobucket.com/albums/v464/shabadoodles/IMG0040A.jpg
http://img.photobuck...45308148m93.jpg
meeting place ps1 lang po. para dun sa bibili tt me ty
meron me 12 pcs magz ng mga rc hapon nga lang pero marami kayo pde makita kita lang pero hindi basa hahaha baka may interesado pm txt or pm thx
cash 17k
swap 19k
walang gas gas
- FOW
- servo saver
- orange spacers
- protective film
PICS
shells
pm phabling214
txt 09173790202
added items:
RIMS
