View Poll Results: JPRaceway : On-road or Off-road?
On-Road
![](https://www.rctech.net/forum/images/polls/bar2-l.gif)
![](https://www.rctech.net/forum/images/polls/bar2.gif)
![](https://www.rctech.net/forum/images/polls/bar2-r.gif)
![](https://www.rctech.net/forum/clear.gif)
60
69.77%
Off-Road
![](https://www.rctech.net/forum/images/polls/bar3-l.gif)
![](https://www.rctech.net/forum/images/polls/bar3.gif)
![](https://www.rctech.net/forum/images/polls/bar3-r.gif)
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Tamiya tt-01 rtr -7k fix traded to sir RJ
-aluminum shaft
-cf upper deck
-ball bearings
-medium silver shocks
-body post extension
-teu-101bk w/ deans
-johnson silver can 540 motor
-4200 east power nimh batts (very good numbers)
-jr racing z590m torque race servo (0.18 sec @ 4.8v)
-9 spoke bronzegold rims w/ hpde tires
-hpi tx blazer
-hpi micro rx
-supra shell (painted flat black)
-w/ box
Novak GTB 5.5r velociti motor w/ novak smart stop -8k
-1st gen
-heatsink w/ fan
-no motor limit
-box & manual
bnew intellect 5000mah 30c+ lipo -5k
-bullet connectors
-deans
-balance plug
-manual
imax b5 lipo/nicd/nimh/ lead acid charger - 2.8k Sold to sir kenikens
-complete connectors
-box & manual
-lcd plastic still intact
nissan s15 shell -500 petot
-very small crack in rear bumper
-chop trunk (for project sana)
-w/ the chop trunk
-painted metallic violet
-flat black hood
-nice for bashing
hotworks nissan 350z - 1k
-painted metallic blue
-with light buckets (front & rear)
-wings
-side mirrors
- very nice shell
-never race
PVC tires - 80 petot
-orange type
spur and pinion 48 pitch (55/25) - 150 petot traded to sir RJ
heatsink w/ hi speed fan - 350petot
3racing battery strap for carbon fiber chassis Bnew - 400 Petot
rfs: di kasya sa xray t2 '07 ko
-may palstic and manual pa
-never opened the screws
-very fresh
transmitter battery pack 800mah nicd -400 petot
-tamiya plugs
-yung isa solder niyo pa sa tx niyo mismo para magamit
-appliacble for megatech junior sports, and 2pl series
bashed dish rims w/ 100% abs tires - 200 petot traded to sir RJ
-good for practice rims
-omm offset
-team sorex brand
stock tt-01 shaft - 50petot traded to sir RJ
-kung gusto niyo balik sa normal yung shaft niyo
at wala na kayo neto hirs one for you
1500mah nicd - 400 for both traded to sir RJ
-needs cycle charging
-tagal ko na kase hindi nagamit wala kase ako discharger
for inquires pls txt me @ 09274488015 or pm me hir
you can also add my ym "[email protected]"
-aluminum shaft
-cf upper deck
-ball bearings
-teu-101bk w/ deans
-hpi tx blazer
-hpi micro rx
-w/ box
-1st gen
-heatsink w/ fan
-no motor limit
-box & manual
-bullet connectors
-deans
-balance plug
-manual
-box & manual
-w/ the chop trunk
-flat black hood
-nice for bashing
-wings
-side mirrors
- very nice shell
-never race
-orange type
-very fresh
-tamiya plugs
-omm offset
-team sorex brand
![gab3r7 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Tamiya body shells cost 1,600.00 pesos at Lil's hobbyshop, these are the older bodies that do not have chrome lightbuckets. the newer Tamiya bodies cost around 1,900.00 pesos.
the Tamiya TT01-D with body cost around 5,998.00 pesos. the Tamiya TT-01E with basic body (no lightbuckets) cost around 5,695.00 pesos, and bodies with lightbuckets cost 5,998.00 pesos.
hth!
hth!
![vlozity is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
For Sale
Bnew Turnigy Accucel-6 50W 5A Balancer/Charger
P 2,680.00
![](http://i226.photobucket.com/albums/dd77/rgl726/ACC6.jpg)
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 11~17v
Circuit power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: .1~5.0A
Discharge current range: .1~1.0A
Ni-MH/NiCd cells: 1~15
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~20v
Weight: 355g
Bnew HXT 10kg Servo (metal gear) 55g / 10kg / .16sec
P 700 each
![](http://i226.photobucket.com/albums/dd77/rgl726/hxt12K.jpg)
Torque Rate: 10KG
Speed: .16sec/60deg
Input: 5~7v
Type: Digital
Gearing: Metal
Weight: 55g
Size: 40.7 x 19.7 x 42.9mm
HXT900 9g / 1.6kg / .12sec Micro Servo
P 350
![](http://i226.photobucket.com/albums/dd77/rgl726/TPSG90.jpg)
Size : 21x12x22 mm / 0.74x0.42x0.78 in
Voltage : 3v ~ 6v
Weight: 9g / 0.32oz
Speed : 0.12 sec/60(4.8V)
Torque : 1.6 kg-cm
Working Temp : -30C~60C
Teflon Bushing, 15cm wire, coreless motor
Servo arms & screw included
TURNIGY 5-7.5A (8~42v) HV UBEC for Lipoly
P 1,500
![](http://i226.photobucket.com/albums/dd77/rgl726/TR-5A-UBEC.jpg)
Spec.
Output (Constant): 5v/5A or 6v/5A
Input: 8v-42v (3-10cell lipo) High Voltage
Weight: 37g
Quiescent current: 20mA
Type: Switching, however because of the noise reduction (thin metal case & filter) this unit gives the same noise as a Linear BEC.
GT Power Twin pack charge lead (2 x 3S)6S
P 500
![](http://i226.photobucket.com/albums/dd77/rgl726/GT-Twins.jpg)
Designed for iMAX and GT-Power chargers (B6,B8,A8,A6).
This harness allows you to charge and balance 2 3S packs at full rate with the 6S port.
This is a great and simple way to charge two packs at once.
GT-Power Voltage Analyzer 3 in 1 2-6S
P 1,500
![](http://i226.photobucket.com/albums/dd77/rgl726/GT-Voltage-Ana.jpg)
Features:
For the real time display of the R/C model battery voltage and the lowest voltage record and the setup of the low voltage alarm while flying
High precision display of individual cell voltage (1-6S shows separately) and the total voltage
With the special LCD screen which can indicate data clearly
With the reverse polarity protection for cell input
It can setup the range of Lipo/LiFe alarm voltage
Specifications:
Used for 2-6S Lipo/LiFe battery
Volatge display resolution: 0.01V
Dimensions: 69 x 33.4 x 10.7mm
ZIPPY Flightmax 2200mAh 3S1P 25C
P 1,700
![](http://i226.photobucket.com/albums/dd77/rgl726/2200-3S-25.jpg)
Spec.
Capacity: 2200mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 25C Constant / 35C Burst
Weight: 171g (including wire, plug & shrink wrap)
Dimensions: 106x36x25mm
Balance Plug: JST-XH
Discharge Plug: T-Connector (Deans Type)
ZIPPY Flightmax 1300mAh 3S1P 15-25C
P 1,200
![](http://i226.photobucket.com/albums/dd77/rgl726/F1300-3S-15.jpg)
Capacity: 1300mAh
Discharge: 15C Constant / 25C Burst
Weight: 102g (including wire, plug & shrink wrap)
Dimensions: 73x20x35mm
ZIPPY Flightmax 1000mAh 3S1P 25C
P 1,200
![](http://i226.photobucket.com/albums/dd77/rgl726/1000-3-25.jpg)
Capacity: 1000mAh
Weight: 86g (including wire, plug & shrink wrap)
Dimensions: 73x36x18mm
ZIPPY OEM 2200mAh 2S1P 20C (Good for Reciever Pack)
P1,200
![](http://i226.photobucket.com/albums/dd77/rgl726/OEM2200-2.jpg)
Spec.
Minimum Capacity: 2200mAh
Configuration: 2S1P / 7.4v / 2Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 130g
Pack Size: 105 x 33 x 16mm
Charge Plug: JST-XH
For Sale Lipoly Batteries
just contact me for your needs (no. of cells and capacity) i will qoute the price
items is in cebu
call/txt 09173232700/09228232700
P 2,680.00
Features;
Time limit function
Spec.
Weight: 355g
P 700 each
Torque Rate: 10KG
Speed: .16sec/60deg
Input: 5~7v
Type: Digital
Gearing: Metal
Weight: 55g
P 350
Voltage : 3v ~ 6v
Weight: 9g / 0.32oz
Torque : 1.6 kg-cm
P 1,500
Spec.
Weight: 37g
P 500
P 1,500
Features:
Specifications:
P 1,700
Spec.
Capacity: 2200mAh
P 1,200
Capacity: 1300mAh
P 1,200
Capacity: 1000mAh
P1,200
Spec.
Pack Weight: 130g
Charge Plug: JST-XH
items is in cebu
![rgl726 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
I am selling my Team Magic G4 nitro RC with .12 RB Concept engine, igniter, starter box with battery and 2 bodies ( 1 racing,1 bashing), and reciever battery pack, without electronics. see to appreciate. Pls. call or text me at 301-03-63 or 0921-668-57-76 look for KIT. thanx
*****SOLD TO ANTHONY.....THANK YOU RC TECH!!!!! PLS. DELETE*****
![kitoy is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
hi guys;
for sale
Hpi rs4 nitro limited ss kit(last kit n my 12rss 1+hp engine)
-super fresh
-ugrade polish pipe orig Hpi
-box,manual,spare parts
-2pl lcd radio,rx,tx,servo
-acura rsx body
-engine is super excellent(ss kit only w/ nickel carbide tech. found in F1 cars)
-No regrets 100%
-12k neg
rfs:ready for abroad
txt/call 0927-3933086,no trade,pm tnx mga sir's
for sale
-super fresh
-acura rsx body
-No regrets 100%
-12k neg
![auto is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Pre-owned HPI white rims with winoy tires - P500 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0032.jpg
New Chrome 10-Spoke Rims with Winoy Tires – P 700 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9873.jpg
New Black 5-Dual Spoke Rims with Winoy Tires – P 700 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9887.jpg
New Black 6-spoke Rims with Winoy Tires - P 700 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0351.jpg
New Chrome 5-Spoke Rims with Winoy Tires – P 700 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9868.jpg
New E-Flite Blade 400 - P 10,700 (free shipping)
- completely factory assembled airframe
- capable of sport flying & 3d aerobatic right out of the box
- factory installed DS75 digital submicro servo & G110 micro headlock gyro offers precise and powerful control
- included 420H brushless motor & 25a brushless ESC deliver incredible power & performance
- Ccpm control w/ push-pull elevator & direct-to-swash aileron/pitch linkages
- plug & play - add your favorite TX & RX to be ready for hovering & 3d aerobatics.
http://i221.photobucket.com/albums/d...s/102_1571.jpg
New Team Vertex VTX-ST1 RTR 1/8 scale truggy - P19,000 (free shipping)
- CLICK this to see it in action: YouTube - Team VTX-ST1
- note: HINDI PA NA-BREAK-IN
- front pivot ball suspension / extended chassis / captured arm mounts
- front universal drive shafts / sealed bevel gear diffs
- big bore racing shocks / complete ball bearings
- vertex 0.26 drill start engine / 49t steel spur gear
- low CG radio tray / fully adjustable suspension
- 3 shoe aluminum clutch / 150cc fuel tank with filter
- hi-torque steering servo / spiral cut steel conical gears
- heavy duty suspension arms / complete w/ drill starter & nitro kit
-![](http://i221.photobucket.com/albums/dd198/warnov/truggy%204sales/100_1549.jpg)
- http://i221.photobucket.com/albums/d...s/100_1552.jpg
- http://i221.photobucket.com/albums/d...s/100_1555.jpg
- http://i221.photobucket.com/albums/d...s/100_1553.jpg
- http://i221.photobucket.com/albums/d...s/100_1554.jpg
- http://i221.photobucket.com/albums/d...s/100_1559.jpg
- http://i221.photobucket.com/albums/d...s/100_1560.jpg
New TLU-01 Led Light – P 800 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0047.jpg
New Sanwa 1301 Servo – P 500 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9954.jpg
New Futaba S3003 Servo with Tamiya Badge - P500.00 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9956.jpg
New TT-01 Urethane Bumper – P 300 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9851.jpg
New Yeah Racing Graphite Sticker (size 5.75” x 8” / 2 sheets) - P400 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9855.jpg
New Sport Tuned Motor with Heat Sink – P 800 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9911.jpg
New Sport Tuned Motor – P 600 (free shipping)
http://i221.photobucket.com/albums/dd198/w...ms/IMG_9899.jpg
Pre-owned Duratrax Intellipeak charger for nimh/nicad only - P 1,800 (free shipping)
http://i221.photobucket.com/albums/d...s/102_1569.jpg
Pre-owned Bionic pulse charger / discharger - P 800 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0378.jpg
New Tamiya TRU-02 AM 2ch. Receiver - P 800 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0356.jpg
New Tamiya TRU-02 AM 2ch. Receiver with 1 pair AM crystals - P 1,100 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0365.jpg
http://i221.photobucket.com/albums/d...s/DSC_0367.jpg
New Tamiya TEU-101Bk ESC - P 900 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0377.jpg
Pre-owned RC car stand - P 500.00 (free shipping)
http://i221.photobucket.com/albums/d...s/DSC_0375.jpg
Unused 19t pinion (1 pair) and 20t pinion (1 pair) - P400 (free shipping)
note: no more crub screw. jst use your d one fr your old pinions..
http://i221.photobucket.com/albums/d...s/DSC_0045.jpg
ALL ITEMS ARE IN CEBU:
CELL NO.: 0923-3876500 / 0917-3204740
![catch my drift is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
1. e-revo stock body, in good condition,slightly used - 1.5k
2. LRP Ai,automatic digital esc w 19 turn epic motor, used,good condition- SOLD!!!
3. futaba FASST magnum 3pm 2.4 ghz, transmitter reciever, used, excellent condition - 7k
4. hemi-cuda shell for e revo/emaxx, bashed, - 800
5. traxxas talon tires from erevo,14mm, used once, excellent condition - 1.5k
6. proline bowties mounted on 40 series wheels, 23mm,used,tires in very good condition,seldom used- 1.5k
7. motor heatsink, b-new,from hvmaxx motor,will fit similar size-800
8. 23mm hexes,used - 500
9. associated t4 kit with lots of parts (no electronics) - 10k na lang!!
10.piranha digital charger,110v,with clips for car battery charging-SOLD!!!
RFS: not quitting, bawas lang ng rc stuff..
NEGOTIABLE!!
09157975459
4700276
renie
NEGOTIABLE!!
09157975459
4700276
renie
![erinkirk is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
added pics po!
Novak Velocity Light 5.5 Motor
Complete box, wires, no defects
5 times used, smooth, high RPM
With new bonded rotor
RFS: need extra funds
-Php 1500
TA05R with additional hopups and new spares
Complete box and manual
First owned, no defects or loose treads
RFS: need funds for new project
With Futaba S3003 servo
-Php 12000
Airflow
09162852677
StaMesa area
-Php 1500
-Php 12000
Airflow
09162852677
StaMesa area
![Airflow is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![](http://i29.photobucket.com/albums/c279/atp3/Picture006-3.jpg)
![](http://i29.photobucket.com/albums/c279/atp3/Picture007-2.jpg)
mint condition pa, may punit lang ng konti sa front pero nirepair ko na kaya ok na ulit. =)
ok na pang bash..
350php lang!
text or call 0909-6335678 for sure buyer.
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
![sixsix1 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![aramacir is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
hth!
hth!
to put this into perspective... if we convert Philippine Pesos into Singapore Dollars
standard Tamiya body shells PHP1600.00 = SGD48.24
Tamiya body shells with light buckets PHP1900.00 = SGD57.25
TT-01 kit with standard Tamiya body shells PHP5695.00 = SGD171.59
TT-01D and TT-01 kit with light-bucket equipped Tamiya body shells PHP5998.00 = SGD180.69
hope this also helps
![Tommi Makkinen is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
