View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
for sale or trade
Ta05 rolling kit- 6,5k
-alum. front & rear block
-alum. dogbone
-alum. outdrive
-front & rear stabilizer
-new front & rear ball diff.
-tamiya TRF dampers
-b.new silvercan
-hpi chrome rims w/ 70% HDPE tire
picture to follow...
txt me na lang NO PM madalang lang ako mag online. tnx!!!
globe: 09062221764
sun: 09228959494
-alum. dogbone
-alum. outdrive
-tamiya TRF dampers
-b.new silvercan
globe: 09062221764
sun: 09228959494
FOR SALE:
Panther Komodo dragon 1/8th buggy wheels and tires(99% thread)-1.3k fixed
Futaba s3003 servos 2pcs.available-500 each
hobao center torsen differential- 1.5k
looking for:
micro temp gun
hitec 645mg servo
mugen mbx5t/mbx5 fuel tank
pls.text me@ 09215209614-vince-binan laguna
looking for:
micro temp gun
hitec 645mg servo
FS: RC items
1. APEX E+ NiCD/NiMH computer charger
* plugs directly to 12VDC P.S. / car battery
* 0.5A to 6.5A charge rate
* NiCD / NiMH automatic select
* charge 4 -9 cells
* no defect
P1.9K only
2. Futaba S9402 High Speed High Torque Servo
* coreless motor, good condition
P1.3K only
3. Venom Failsafe
* good condition
* best for nitro cars.
P850 only
Pick up location is along East Avenue, Q.C.
call or text 09167038717
Thanks!
* charge 4 -9 cells
* no defect
P1.9K only
P1.3K only
3. Venom Failsafe
* good condition
P850 only
Thanks!
indireactor 30amp discharger - 1k.
bnew orion 10.5 brushless motor - 3.5k neg.
orion 10.5 brushless motor (slightly used) -2.5k (reserved)
hudy comm lathe (with aluminum case,diamond bit and manual)-6k neg
09178134619 or 09228234619
lf: df03
LF: tamiya df03 rolling chasis
selling for a friend:
FS: tamiya TL01 rolling chasis in good condition
hopups: long arms, full ball bearings, stabilizers and sport tuned gears in 2.2k only
just pm me for those who are interested.
FOR SALE
for sale MJ FUTABA T2PHKA AM RADIO 27MHZ. W/ PAIRS OF CRYSTAL AND RECEIVER 1700 PESOS.09283426421
sir bakki ygpm
Spektrum DX3R
Guys,
I'm selling my slightly used Spektrum DX3R Transmitter and Receiver.
Comes with Manual, binding plug, and left-hand conversion kit.
P10,000
09167543471
Thanks for looking!
P10,000
09167543471
Thanks for looking!
ALSO AVAILABLE!!!!
RRP 64 PITCH PINIONS
TRINITY BUSHING AND BEARING OILS (ROYAL OIL TOO!)
TRINITY AFTER RUN
ASSOCIATED AIR FILTER OIL
DYNAMITE BIG DADDY FUEL FILTERS
PROLINE AIR FILTERS
PROLINE CURVED SCISSORS
AND LOTS MORE!!!
TRINITY AFTER RUN
PROLINE AIR FILTERS
AND LOTS MORE!!!
www.cyclonetoy.com
www.cheapricequalityrc.zoomshare.com
DLE-222 222CC 4 Cylinder Gas Engine will release out soon!
Watch the video::
http://www.cyclonetoy.com/listzt.asp?id=1284
1/5 HPI Baja 5B Gasoline 23cc Buggy RTR Clone 32,500 php
http://www.cyclonetoy.com/list_1.asp?id=1350
Text or call 09158884491
A123 Battery 2300mah arrving soon
SM Digital 57g/12KG Servo(Double Bearing)
arrving soon
http://www.cyclonetoy.com/list_1.asp?id=1547
4.8V
Speed Torque
sec/60o kg-cm
0.18 12.1
6.0V
Speed Torque
sec/60o kg-cm
0.16 13.1
Limited items only all brand new
Heavy duty servo cable 300mm 130.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1216
Dynam 25amp Esc php 750.00
Heavy duty servo cable 600mm 180.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1218
Energy EC Power lipo Brand
11.1v 1,500mah 15c lipo 1,350.00 free shipping
http://www.cyclonetoy.com/list_1.asp?id=944
11.1V 1600mah 8C Gun-Type Transmitter 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=943
11.1v 2200mah 20c lipo 1,450.00 free shipping
http://i248.photobucket.com/albums/g...34016480-1.jpg
7.4V 2200mah 12C 1,300.00
http://www.cyclonetoy.com/list_1.asp?id=949
lipo 7.4 3500mah 25c sold out
11.1V/2200mAH/ 12C 1'350 free shipping
http://www.cyclonetoy.com/list_1.asp?id=939
Regulator/Lipo Cutoff
UBEC-5A-HV (High Voltage) 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=1209
(Lipo cutoff)LiPo Battery Protector for Car 950.00
stock 7 pcs in stock free shipping
Manual
http://www.hobbywing.com/english/Art...?ArticleID=402
Charger and Connectors
T plug connector 3 pcs set male and female 200.00
http://www.cyclonetoy.com/list_1.asp?id=131
Imax B6 Charger 3,150.00
http://s248.photobucket.com/albums/g...current=b6.jpg
Imax b8 Charger with connectors and aluminum case 3,750.00
http://www.cyclonetoy.com/list_1.asp?id=1174
5A adaptor for Imax charger and other brand charger 750.00
http://www.cyclonetoy.com/list_1.asp?id=1213
Program card 650.00
http://www.cyclonetoy.com/list_1.asp?id=122
Servo
Tower pro 9G micro servo 350.00
http://www.cyclonetoy.com/list_1.asp?id=160
Tower pro MG995 sold out
http://www.cyclonetoy.com/list_1.asp?id=163
Hitec HS-7955TG Servo 3,350.00
Motor Type: Coreless Bearing Type: Dual Ball Bearing
Speed: 0.19 / 0.15 sec @ 60 deg.
English Metric Torque: 250 / 333 oz.in (4.8v/6v) 18 / 24 kg.cm
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 2.29oz 65.00g
Hitec hs65MG sold out
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60° at no load
Operating Speed (6.0V): 0.11sec/60° at no load
Stall Torque (4.8V): 25 oz/in. (1.8kg.cm)
Stall Torque (6.0V): 31 oz/in. (2.2kg.cm)
SPE 43CC Gas Engine with pitt muppler 10,500 in stock
http://www.cyclonetoy.com/list_1.asp?id=162
Hawk propeller brand (Wood)
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=21
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
19 x 8 c 750.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
10 x 4.7 electric prop. 150.00
8 x 4 E. propeller 150.00
http://www.cyclonetoy.com/list_1.asp?id=568
Igniter with battery and meter 800.00 1 unit avail.
http://www.cyclonetoy.com/list_1.asp?id=1157
Tower pro voltage monitor 450.00
http://www.cyclonetoy.com/list_1.asp?id=886
futaba 3pk module 75mhz php 1,000
Futaba 40mhz R149 DP Dual conversion 9 channels PCM receiver no crystal, 3,500.00 reprice 2.6k rush shipping included
Selling for a friend
Brandnew Super chipmunk 30 made in japan for 7,500
spec.
Watch the video::
arrving soon
4.8V
Speed Torque
sec/60o kg-cm
0.18 12.1
6.0V
Speed Torque
sec/60o kg-cm
0.16 13.1
Manual
Program card 650.00
Servo
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
19 x 8 c 750.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
spec.
WTB: TT-01 Tamiya
Hi there,
kng cno ang ngtitinda ng tamiya TT-O1 rtr sa halagang P1.8k-2.2K. pls contact me at sms #: 0916-783-7858. pls dnt PM me. items must be in good condition.
Tamiya Pajero and TB-01 parts/hop-ups
LF:
guys i'm looking for a used but not abused Tamiya cc-01 pajero kit and Tamiya TB-01 hop-ups,
pls text me asap 0922-869-62-73
thanks
thanks
Item for pick up at Timog, QC area. Office hours.
Axial AX-10 Scorpion Pro Kit.
NIB
PHP13,000.00
0918-9143768, mobile landline 572-6921
NIB
PHP13,000.00
