View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
FOR SALE! BRAND NEW!
Futaba TEU-101BK- 1.4K B/new, factory sealed. Taken from a b/new kit.( Open for swap with M03 parts. Alum dampers etc.)
3Racing assorted Aluminum hop-up parts for Axial AX10 and Tamiya CR01.
CR01- Knuckle Arm, Alum. threaded shocks.
AXIAL AX10- Y-Shape linkage connector, Steering link set,angled linkage set.
Genuine B/new AXIAL PARTS!
Axial AX10 stock Damper set- 1.2K- set of 4 shocks, Bnew, taken from a B/new kit. Mounting screws included.
Axial AX10 stock Chassis set- 800 pesos- a pair of brand new Anodized black aluminum chassis.
Axial AX10 stock Slipper clutch set- 1.2K W/ Spur gear! Brand new taken from a B/new kit.
TOWER-PRO MG996R SERVO- (OUT OF STOCK) Upgraded version of the famous MG995. The MG996R has smoother operation due to a whole new PCB circuit, IC control so it CENTERS perfectly! Metal gears are further improved so it's more quiet. Perfect for 1/8 & 1/10 scale Cars,Buggy,Truggy, MT's. Safe for large scale plane application!
TOWER-PRO 9g Micro Servo – 350 pesos each - Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD - 850 pesos each
Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack (OUT OF STOCK)
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
Mtroniks Viper ECO20- 2,000 each, (9 Pcs. Available)
B/New, 20Turn motor limit, built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers), Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g http://www.mtroniks.net/details1.asp/ProductID/170/lockit/true/Viper-Eco20.htm
IP6 Competition ESC- 7,300 (last piece)
B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies! http://www.mtroniks.net/details1.asp/ProductID/177/sid//IP6.htm
Mtroniks Genesis Pro (brushless esc)- 5,300 each,
B/N, Brushless 100A peak, 4-8cell NiMH, 2-4 Li-Po, Li-Po Safe w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(LAST UNIT)
http://www.mtroniks.net/details1.asp/ProductID/179/sid/4/Genesis-PRO.htm
Mtroniks Genesis Pro/ KEDA 5900Kv COMBO- 8,600 B/N 100A Peak ESC plus 36-50-06T brushless motor (540 Size) 5mm shaft.
Mtroniks Micro Failsafe- 1,400 each(OUT OF STOCK),
B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=Failsafe.jpg
Mtroniks ZGM (Zero Glitch Module)- 1,400 each,
B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=zgm.jpg
Mtroniks Signal Booster-1,400 each,
B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=signalboost-WP.jpg
Click here for product pictures:
Posting for my Brother: Used items for sale!
Tamiya TLT Chrome wheels and tires- 1.3K neg. set of 4 ( Rare )
Tamiya CR01 Vise Crawler tires- 1.2K neg. Seldom used. set of 4
I accept payments thru Bank Transfers or Credit cards via
Text or Call Stephen 0919-8888865 Sorry No Trade! Pls. Include RCTech Username Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
energy e.c
for sale again! energy EC 11.1volts 2200MAh 25c bnew lipo batteries with deans plug..
==2pcs available for 1400php EACH only!!==
note: may avail ako na used na for 1100php..
yung bnew 1400php..
kindly text or call for sure buyer 0909-6335678...
meet anywere in manila or qc area..
kindly include your location when texting so we can set our meeting place halfway.
yung bnew 1400php..
mamba25
for sale! castle creations mamba 25 esc (aka sidewider) plus 4400kv trinity brushless motor and a bnew castle creations usb programming kit and software!
actual pics:
3200php for all only!!
text or call 0909-6335678 for sure buyer.
always include your location when texting so we can set our meeting place halfway in manila or quezon city area...
thanks!
RTF ELECTRIC HELICOPTER
FOR SALE: VERY NEW RTF ELECTRIC HELICOPTER
HONEY BEE CP 2 ( CAN DO SLIGHT 3D, INVERT )
VERY FRESH, VERY NEW, just hovered for less than 5 mins for testing
- relatively brand New
- Very Fresh and New
- No deffects, damages
- RTF kit ( radio, lipo batt, charger,4 IN 1 GYRO etc..)
Free: ALL BrandNew Spare Parts
- 1100 mah lipo battery
- 2 main wooden blades
- 1 set tail boom
- 1 set complete main frame assembly
- 2 sets fly bar
- fly paddle
- rotor head
- batt holder
- training kit
- heat sink for main and tail motor
http://www.twf-sz.com/english/products.asp?prodid=0002
actual pic..some spares not included..upon request
http://i273.photobucket.com/albums/j...F/DSC00192.jpg
* this item will arrive to me on Jan 19. can ship it on that day onwards
*will accept reservation for sure buyers
price: 7,000 only Negotiable FREE SHIPPING
pm or 0922 84 777 66
also for sale.....
Slightly Use E SKY BELT CP RTF color: Yellow
- radio w/ receiver
- charger
- 1800 mah lipo battery
- box and manual
- brushless motor
- ESC
- servos
- brandNew carbon blades
-JR G410T head lock gyro ( for 30 size heli, very stable )
- Carbon Main Frame
- metal upgrade ( swash plate)
- spare stock main frame
- spare servo rod for rudder
- blade holder
- training skids
ACTUAL PICS...
http://i273.photobucket.com/albums/j...F/DSC00178.jpg
http://i273.photobucket.com/albums/j...F/DSC00179.jpg
http://i273.photobucket.com/albums/j...F/DSC00180.jpg
P12,500.00 Negotiable Free Shipping
get both for 15,500 Negotiable
- 1 set tail boom
- 2 sets fly bar
- fly paddle
- rotor head
- batt holder
- training kit
also for sale.....
- radio w/ receiver
- charger
- box and manual
- brushless motor
- ESC
- servos
- Carbon Main Frame
- blade holder
- training skids
ACTUAL PICS...
Hobby Shops in Makati
Hi guys,
I will be coming to the Philippines at the end of January (I'm in Australia) and wanted your advice on some good hobby shops in and around Makati. I race cars (1:8 off road, 1:10 on and offroad).
Thanks for all your help guys!!
FOR SALE BRAND NEW ON ROAD TIRES FOR 1/8 1/10 SCALE MONSTER TRUCK, 14MM HEX, IDEAL FOR EREVO, EMAXX, ESAVAGE, TMAXX, SAVAGE NITRO , MGT, TNX... 2.5K ONLY
FOR SALE BNEW HPI 4.6 PULLSTART.. 1K ONLY., USED PULLSTART FOR .21, .25HPI ENGINE.. 800 RESERVE!!!
FOR SALE TRAXXAS 2CHANEL AM RADIO WITH AM RECEIVER 1.5K SOLD!!!
FOR SALE TRAXXAS TQ3 3CHANEL AM RADIO WITH 3CHANEL RECEIVER... 2K SOLD!!!
FOR SALE SANWA MX3 DIGITAL FM RADIO, 3CHANEL WITH 40MHZ RX311 RECEIVER... 3.5K
FOR SALE ASSOCITED FM DIGITAL RADIO, 3CHANEL WITH MICRO 27MHZ RECEIVER... 3.5K RESERVE!!!
NO TRADE, NO PM
09063147021-KENET
REVO 3.3 RTR SOLD!!!!
NO TRADE, NO PM
09063147021-KENET
TAMIYA F-350 FOR SALE....RTR PRICE LOWERED TO 16K
TAMIYA F-350 HI LIFT WITH RADIO AND ELECTRONICS..PRICE LOWERED TO 16K RTR NA FREE SHIPPING...
(0920) 981-6868
(0920) 981-6868
Novak Smart Tray SE
-Blue LED
-Hold discharge feature
-very fresh/like new
-box/manual
-2.5k
Team Atlas Battery Heatsink/Jig
-good as new
-1k
Assorted 27t motor
-(tuned for racing preference)
-fresh/mint/fast...
-800 each
Assorted EMAXX1 Parts (Brandnew)
-spur gear (Bnew)
-Slipper Pegs
-front alum skid plate
-Alum chassis brace
-slipper plate
-input/output drive shaft
Yokomo BD/LCG parts
-arms
-front 1way
-CVD's
-alum front and rear knuckles
-shock assembly set of 4
-motor tear drop mount for CGM (blue alum)
Pick up point is makati Pasong tamo or QC (araneta ave) area.
PM lang if interested
LF truggy or buggy RTR
need a buggy or truggy 1/8 size nitro RTR txt or pm me -thanks 09178115597
FOR SALE TRUGGY RTR
FOR SALE: HONGNOR JAMMIN X1 CRT READY TO RUN
- ready to run
- .28 engine w/ pull start ( stock )
- futaba digital servo for steering
- stock for throttle
- receiver battery ( GP Brand )
- fuel bottle
- 95% tire thread pa
- w/ brand new ho bao pro kit tires, never been used ( 3,000 if bought separately )
- futaba gun type radio w/ receiver, crystals
- bashed up stock shell
- box and manual
- cnc chassis brace
- spare dogbone for front and rear arm
- free plastic parts that comes along with the kit
- wrench tool for tire hex and glow plug
24K Free Shipping, Price is Negotiable
pm or 0917 62 69217
http://i273.photobucket.com/albums/j...F/DSC00186.jpg
http://i273.photobucket.com/albums/j...F/DSC00187.jpg
http://i273.photobucket.com/albums/j...F/DSC00188.jpg
http://i273.photobucket.com/albums/j...F/DSC00189.jpg
- ready to run
- fuel bottle
- box and manual
- cnc chassis brace
pm or 0917 62 69217
1. KIT-9.9K ONLY
VERY FRESH TAMIYA TB01
-CARBON FIBER LOWER DECK(99% no scratch)
-CARBON FIBER UPPER DECK(99% no scratch)
-FULL BALL BEARING
-UNDER CHASSIS PROTECTOR
-ALUMINUM (SILVER) FRONT C-HUBS
-ALUMINUM (SILVER) REAR UPRIGHT
-ALUMINUM (SILVER) FRONT SUSPENSION ARMS
-ALUMINUM (SILVER) REAR SUSPENSION ARMS
-ALUMINUM (SILVER) OIL-FILLED TREADED SHOCKS
-ALUMINUM (SILVER) SHAFT
-ALUMINUM COATED DISC BREAKS
--REAR DIFF LOCK (ALUMINUM (BLUE) SPOOL ADOPTER)
-LIGHT WEIGHT GEAR SET F/R
-SILVER COATED 6 SPOKES WHEELS W/ HPI DRIFT TIRES (90%)
-TAMIYA DISH WHEELS (0MM OFFSET) (WHITE) W/ TAMIYA TIRES (80%)
- EXTRA HDPE DRIFTIRES (BNEW)
-PLASTIC SPARE PARTS CAN BUILD A NEW STOCK KIT
http://i40.tinypic.com/2w5n3fq.jpg
http://i40.tinypic.com/24ooxup.jpg
http://i43.tinypic.com/zwakcx.jpg
http://i43.tinypic.com/o7uan8.jpg
http://i44.tinypic.com/206zj1v.jpg
http://i40.tinypic.com/154f2p4.jpg
http://i39.tinypic.com/16joe46.jpg
2. HPI eSAVAGE with SUNCON H2- 18K ONLY
-mtroniks BL esc pro
-Keda 9t BL motor size 600 5mm shaft
-extended chassis
-hpi Aluminum threaded shocks
-modified battery holder
-bnew novak 16t 5mm pinion gear
-DIY light kit
-more pics upon request
http://i43.tinypic.com/2uppq11.jpg
http://i39.tinypic.com/xpubn4.jpg
3. SERVO - 950 only
TowerPro MG945
- high torque high speed digital metal gear servo almost bnew
- ball bearing
- .24sec/60deg.
- 13kg/cm torque
4. E-SAVAGE CHASSIS - 500 ONLY
- aluminum silver coated twin vertical chassis
- very gud condition
text me at 09282155035
accept swap
-FULL BALL BEARING
-extended chassis
-DIY light kit
3. SERVO - 950 only
TowerPro MG945
- ball bearing
- .24sec/60deg.
- 13kg/cm torque
accept swap
For Sale:
2008 Platinum Edition Traxxas Revo
11 tanks of fuel used only to break-in engine
NEVER ran on dirt
35k
Text Only: 0917-529-5037
NEVER ran on dirt
35k
FOR SALE/TRADE:
Hitec HS5645 MG Digital servo (Ultra Torque) 3 pcs.
at 4.8v:
0.23s/60 deg
10.3Kg.cm!
-in good condition
-currently residing in my Raptor 30 --- No crash whatsoever.
Reason for selling: Too much torque, not enough speed for MY flying style. hehe
selling it for 1.8k each. buy all 3 and will give discount.
OR... trade with 3pcs servo, preferably something faster with atleast 5kg.cm of torque.
0905-3533449
-kokok-
at 4.8v:
0.23s/60 deg
10.3Kg.cm!
-in good condition
0905-3533449
-kokok-
Hi,
Looking for 12-15amp esc para sa brushless motor ng slow fly planes.
PM me or text me 09279757129
please include price and contact info.
Makati Area
Makati Area
sale
Sale Serpent S400 very fresh! no scraches i use chasis protector, with gear diff, spare parts 10k nalang. complete with box and manual call or txt 09175342692
