View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
looking for pinion gear for tamiya tao 2 chassis, please text me the price and the number of teeth ng pinion gear na meron po kayo. tnx
driks
09192321255
driks
09192321255
SUB C Battery Dischargers
Much More Zero V Discharger
-almost new (no scratch and no defect)
-box in mint condition
-includes manual and unopened stocking post
-php800(firm) reatails for 1.6K
http://i187.photobucket.com/albums/x...4/a777cebf.jpg
http://i187.photobucket.com/albums/x...4/f26195be.jpg
Here are the specs :
Light-weight(205g), compact(90 x166 x 60mm) and safely designed.
6 bulbs ensure proper connection.
New layer system for small pit area (can be connected by body clips).
Can be multi-stacked.
R/C car-concept-designed.
Tested by world champion Surikarn Chaidajsuriya.
The management method for enhancing voltage with Zero-V
1.Discharge three days on Zero-V tray.
2.Disconnect then leave the battery till next race.
3.Discharge again 1 hour before charge.(Bulbs will not turn on. however, discharging is proceeding)
4.Disconnect then charge.
Roche Digital Proffesional Batteryl Discharger
-used but not abused
-color purple (aluminum)
-perfect condish / no scratch
-includes box, manual and connectors
-selling php2.5K (bought for $130 online)
http://i187.photobucket.com/albums/x...4/2bf2e335.jpg
http://i187.photobucket.com/albums/x...4/0a581300.jpg
Specs:
-Adjustable discharge current 1-3A (0.1A increament)
-auto cut off
-adjustable dischrge cut of voltage per cell 0-0.9V (0.1A increament)
-aluminum case w/ heatsink
-adjustable spring clips for easy insertions
-for SubC Ni-Mh and Ni-Cd cells
-Transparent plastic tape protection
-12v adaptor included
-bright LED for each cell status
contact: 0917 8553317
Specs:
-auto cut off
4 sale hammer monster truck
4 sale hammer monster truck 28 engine italy w/d servo recever & controler ...11k pwd ring swap .habao hyper or tmax tex or col,,,,,,,,,09071494121 thk
LF: Tamiya Pajero Kit
http://www.tamiyausa.com/product/ite...oduct-id=49490
0918-9143768
For sale: Traxxas E-maxx PHP18500.00
With TQ3 controller
Never run.
0918-9143768
With TQ3 controller
Never run.
rc stuff
brand new JPRacing FX 21 B8T Offroad engine(Novarossi 421B modified version by JPRacing)...10k fix
brand Ballistics 2700mah nimh rx battery(it will fit mugen,losi and hobao)....2k fix
BL esc with motor and Esavage
http://www.philippinercdrifters.org/...showtopic=3639
BL ESC with motor
Mtronics Genesis pro ESC
1 Keda 550 6T motor slightly used (in esav few times)
1 Keda 600 9T motor Bnew
All for Php 10k
Esavage with new stock esc and two motor only no tx,rx,battery and charger
This is use only for few times sa asphalt. Not bashed in very prestine condition.
Php 10k
09063679306
BL ESC with motor
All for Php 10k
Php 10k
09063679306
SALE PRICE!! NEW TAMIYA KITS!!
FOR SALE!!! LOWER PRICE THAN LOCAL HOBBY SHOPS!! ***SOLD!!! THANKS!!!***
1. TAMIYA BMW Z4 - M Coupe Racing - with ESC already! Just 5,500 pesos!!!
2. TAMIYA AVANTE MK.II - FULL BALL-BEARINGS ALREADY! Just 5,500 pesos!!!
INTERESTED LUCKY BUYERS PLEASE E-MAIL ME at [email protected] or [email protected] (Items are in Makati City)
"BOTH KITS FOR 10,000 PESOS ONLY!!!"
2 TAMIYA RZ 23-turn motors like new condition 600 pesos each
Purple 3-RACING motor heat sink with Fan 600 pesos
Set of 4 E-Savage wheels/tires 1000 pesos
If interested please contact me at 0927-996-9175 Alexander thanks
.Pro-Line Speed Hawg II 2.2 Truck Tires with inserts (on road tires)
-brand new
-fits 2.2" wheels
-2 sets(4 pcs)
-3k slightly neg can be traded with size .15-.18 engine in good compression
reference pix:
http://www2.gpmd.com/image/p/proc1080.jpg
3. Tamiya PAjero Metal TOp(with missing parts)
-with newly painted body,
-wheels and tires
(missing parts: motor mount, drive gear, other end of the drive shaft,)
-2.5k or make an offer
4.ALso Selling RC10GT PARTS and NTC3 PARTS
-pm me the part number
RFS:needs funding for my scoot,
buyer handles the shipping
09206570091
xkenikensx187 <- ym
-brand new
-fits 2.2" wheels
-2 sets(4 pcs)
reference pix:
-wheels and tires
09206570091
xkenikensx187 <- ym
LAST POSTED ON PAGE 173
FOR SALE! BRAND NEW!
3Racing assorted Aluminum hop-up parts for Axial AX10 and Tamiya CR01.
CR01- Knuckle Arm, Alum. threaded shocks.
AXIAL AX10- Steering link set, Y-Shape linkage connector, angled linkage set.
LIPO PACKS 3,500 each w/ dean plugs-7.4V 4800mah 25C. 120Amps nominal discharge. (3 pcs. left)
TOWER-PRO MG995 Servo – (OUT OF STOCK)
TOWER-PRO 9g Micro Servo – 350 pesos each - Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD - 850 pesos each Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
Mtroniks ESC’s: 100% Waterproof, B/New, Made in U.K., FOR CRAWLERS, DRIFTERS, ON/OFF ROADERS, BOATERS ON A TIGHT BUDGET! B/N,NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST**, ABSOLUTE short circuit and motor overload protection,
1. Mtroniks Viper ECO20- 2,000 each, (10 Pcs. Available)
B/New, 20Turn motor limit, Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g http://www.mtroniks.net/details1.asp/ProductID/170/lockit/true/Viper-Eco20.htm
2.Mtroniks Viper Tempo 11- 2,150 each (Last piece na)11 turn motor limit, forward/brake only, Dual core microprocessor, 4-8 cells input voltage, 4 Layer super power circuit board, Thermal integrated protection system, Digital one touchset up, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55ghttp://www.mtroniks.net/details1.asp/ProductID/175/lockit/true/Viper-tempo11.htm
3. Mtroniks Viper RV Max- 3,550 each (Last piece na)
B/New, NO motor limit, 4.8-9.6V, Reversible, 1.2A BEC. wires included.
NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST** , ABSOLUTE short circuit and motor overload protection, No motor limit, Dual core microprocessor, 4-8 cells input voltage, Adjustable features include programmable punch on the forwards only range and programmable reverse (including disable) & programmable brakes on the reversible range, 4 Layer super power circuit board, Thermal integrated protection system, Digital one touchset up, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm , Weight : 55g All VIPER ESCs are capable of running the highest capacity cells available & the latest high spec motors. Each VIPER ESC incorporates a 1.2A BEC and the latest state of the art technology and GEN-Xi power FETs! http://www.mtroniks.net/details1.asp/ProductID/173/sid/3/Viper-RV-MAX.htm
4. Mtroniks Viper Truck- 3,550 each (Last piece na) (wires included) single 15 turn motor limit or dual 27 turn motor limit, adjustable brakes, adjustable reverse functions and a built in failsafe are standard on the Truck Speed Control, with soldering post for easy wire replacement.
http://www.mtroniks.net/details1.asp...iper-truck.htm
A break down of the Viper Truck specification can be seen below
COMPETITON ESC's
IP6 Sport (Competition ESC) - 5,500 each, B/N, Waterproof, 10T limit,Rated 350A continuous, peak 1,500Amps, Fully programmable punch, Drive Frequency 1.5KHz to 11.0KHz, Drive curve & brakes, 4.8-8.4V,4A Hyper BEC. http://www.mtroniks.net/details1.asp/ProductID/176/sid//IP6-sport.htm
IP6 Competition ESC- 7,300 each, B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies! http://www.mtroniks.net/details1.asp/ProductID/177/sid//IP6.htm
Mtroniks Genesis Brushless Series ESC
1.Mtroniks Genesis Pro- 5,300 each, B/N, Brushless 100A peak, 4-8cell NiMH, 2-4 Li-Po, Li-Po Safe w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(LAST UNIT)
http://www.mtroniks.net/details1.asp/ProductID/179/sid/4/Genesis-PRO.htm
Mtroniks Genesis Pro/ KEDA 5900Kv COMBO- 8,600 B/N 100A Peak ESC plus 36-50-06T brushless motor (540 Size) 5mm shaft.
Mtroniks Radio Equipment:
1. Mtroniks Micro Failsafe- 1,400 each, B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=Failsafe.jpg
2. Mtroniks ZGM (Zero Glitch Module)- 1,400 each, (LAST UNIT) B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=zgm.jpg
3. Mtroniks Signal Booster-1,400 each, B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=signalboost-WP.jpg
Click here for product pictures:
I also accept payments thru
Text or Call Stephen 0919-8888865 Sorry No Trade! Pls. Include RCTech Username Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
- NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST**
- ABSOLUTE short circuit and motor overload protection
- 15 turn motor limit (Single motor)
- 27 turn motor limit (Dual motors)
- 1.5A External BEC
- Dual core microprocessor
- 5-10 NiMh cells input voltage (6.0 to 12.0V)
- Adjustable features include programmable reverse (including disable) & programmable brakes
- 4 Layer super power circuit board
- Thermal integrated protection system
- Digital one touch set up
- Legendary 100% waterproof design
- Dimensions : L39.0mm x W34.0mm x H13.0mm
- Weight : 55g
COMPETITON ESC's
LOOKING FOR X2 UN PAINTED BODY TXT ME AT 09283426421
