View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
LF: Novak Smart Tray with power supply or adapter
PM me. thanks.
PM me. thanks.
wheels with tires
looking for 1/10 scale 26mm on road wheels with tires that will fit my hpi rs4. 0mm offset or 3mm. radial, touring tires only, 300 to 500 peso budget, kindly post some pics. thanks.
For Sale
For Sale:
A. GO NITRO ENGINE - .21R / PRO BUGGY 7PORT+2
PRICE: 5,000
B. ROTO START WITH BATTERY
PRICE: 3,000
MY MOBILE: 0917-8032326 / 09228553249
PRICE: 5,000
PRICE: 3,000
LAST POSTED ON PAGE 159
FOR SALE! BRAND NEW!
3Racing assorted Aluminum hop-up parts for Axial AX10 and Tamiya CR01.
CR01- Knuckle Arm, Alum. threaded shocks.
AXIAL AX10- Knuckle Arm, C-Hub, Stainless Outdrive, Y-Shape linkage connector.
LIPO PACKS 3.5K each w/ dean plugs-7.4V 4800mah 25C. 120Amps nominal discharge. (5 pcs. left)
TOWER-PRO MG995 Servo – 900 Pesos each B/new (Few stocks available so hurry!) - Metal gear digital servo, size:40mm*38mm*20mm, weight:48g, Speed (4.8v): 0.17sec/60degrees, Speed (6V):0.13sec/60degrees, Stall Torque (4.8V):13kg/cm., Stall Torque(6.0V):15kg/cm, horns included.
TOWER-PRO 9g Micro Servo – 350 pesos each - Dimensions : 22.6 x 21.8 x 11.4mm, Weight : 9g, Operating Speed (4.8V no load) : 0.12sec / 60 degrees, Stall Torque (4.8V) : 17.5oz/in (1.2 kg/cm), Temperature Range : -30deg to +60deg, Operating Voltage :3.0 - 5.0 Volts, Coreless Motor, All Nylon Gear, Connector Wire Length 150MM, Complete w/ 3 Horns.
HOBBY WING PROGRAM CARD - 850 pesos each Pocket Size! Set-up your BL ESC anytime, anywhere! No need to bring your laptops!
DEANS ( T- Connectors)- 200 Pesos/Pack
(3 males, 3 females, with Shrink tubes/ pack)
BULLET Connectors3.5mm- 200 Pesos/Pack
(3 males, 3 females, 6 Shrink tubes)
Mtroniks ESC’s: 100% Waterproof, B/New, Made in U.K., FOR CRAWLERS, DRIFTERS, ON/OFF ROADERS, BOATERS ON A TIGHT BUDGET! B/N,NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST**, ABSOLUTE short circuit and motor overload protection,
1. Mtroniks Viper ECO20- 2,000 each, (11 Pcs. Available)
B/New, 20Turn motor limit, Dual core microprocessor, 4-8 cells input voltage , 4 Layer super power circuit board, Thermal integrated protection system , Digital one touch setup, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55g http://www.mtroniks.net/details1.asp/ProductID/170/lockit/true/Viper-Eco20.htm
2.Mtroniks Viper Tempo 11- 2,150 each (Last piece na)11 turn motor limit, Dual core microprocessor, 4-8 cells input voltage, 4 Layer super power circuit board, Thermal integrated protection system, Digital one touchset up, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm, Weight : 55ghttp://www.mtroniks.net/details1.asp/ProductID/175/lockit/true/Viper-tempo11.htm
3. Mtroniks Viper RV Max- 3,550 each (Last piece na)
B/New, NO motor limit, 4.8-9.6V, Reversible, 1.2A BEC. wires included.
NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST** , ABSOLUTE short circuit and motor overload protection, No motor limit, Dual core microprocessor, 4-8 cells input voltage, Adjustable features include programmable punch on the forwards only range and programmable reverse (including disable) & programmable brakes on the reversible range, 4 Layer super power circuit board, Thermal integrated protection system, Digital one touchset up, Legendary 100% waterproof design, Dimensions : L39.0mm x W34.0mm x H13.0mm , Weight : 55g All VIPER ESCs are capable of running the highest capacity cells available & the latest high spec motors. Each VIPER ESC incorporates a 1.2A BEC and the latest state of the art technology and GEN-Xi power FETs! http://www.mtroniks.net/details1.asp/ProductID/173/sid/3/Viper-RV-MAX.htm
4. Mtroniks Viper Truck- 3,550 each (Last piece na) (wires included) 15 turn motor limit or dual 27 turn motor limit, adjustable brakes, adjustable reverse functions and a built in failsafe are standard on the Truck Speed Control, with soldering post for easy wire replacement.
http://www.mtroniks.net/details1.asp...iper-truck.htm
A break down of the Viper Truck specification can be seen below
COMPETITON ESC's
IP6 Sport (Competition ESC) - 5,500 each, B/N, Waterproof, 10T limit,Rated 350A continuous, peak 1,500Amps, Fully programmable punch, Drive Frequency 1.5KHz to 11.0KHz, Drive curve & brakes, 4.8-8.4V,4A Hyper BEC. http://www.mtroniks.net/details1.asp/ProductID/176/sid//IP6-sport.htm
IP6 Competition ESC- 7,300 each, B/N, Waterproof, NO MOTOR LIMIT, Rated Current Fwd. 660A- brake. 240A, peak Current Fwd. 2,640A- Brake 960A,Fully programmable punch, drive freq. 4-7 cells NiMh, BEC 5.6V/8.0Amps. Perfect for speed & power junkies! http://www.mtroniks.net/details1.asp/ProductID/177/sid//IP6.htm
Mtroniks Genesis Brushless Series ESC
1.Mtroniks Genesis Pro- 5,300 each, B/N, Brushless 100A peak, 4-8cell NiMH, 2-4 Li-Po, Li-Po Safe w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(LAST UNIT)
http://www.mtroniks.net/details1.asp/ProductID/179/sid/4/Genesis-PRO.htm
Mtroniks Genesis Pro/ KEDA 5900Kv COMBO- 8.6K, B/N 100A Peak ESC plus 36-50-06T brushless motor (540 Size) 5mm shaft.
2. Mtroniks Genesis Truck ESC- 6,100, B/New, 120A peak BL ESC, 6-12 cell NiMH, 2-4 Li-Po. w/ built-in 2,3,4S programmable voltage cut-off, intelligent start up, Adj. Punch, Timing, Rev. set-up and battery selection,(Perfect for E-Maxx, E-Savage etc.)
http://www.mtroniks.net/details1.asp/ProductID/200/sid/11/Genesis-truck.htm
Mtroniks Genesis Truck/ PLASMA 3000Kv COMBO- 10K ,120A limit ESC w/ 3000Kv Plasma BL motor 600 size 3.17mm shaft. http://www.mtroniks.net/details1.asp/ProductID/257/sid/25/PlasmaTruck.htm
Mtroniks Radio Equipment:
1. Mtroniks Micro Failsafe- 1,400 each, B/N, this new micro sized WATERPROOF failsafe is small enough to fit easily into those tight radio boxes or even just hang outside the box! It's waterproof after all!!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=Failsafe.jpg
2. Mtroniks ZGM (Zero Glitch Module)- 1,400 each, B/N, 100% waterproof, dimensions: L28mm x W14mm x D7mm http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=zgm.jpg
3. Mtroniks Signal Booster-1,400 each, B/N, the signal booster has been designed to improve the signal received from the channel it is connected in series with. The signal booster conditions the signal, filtering out any nonsense noise and amplifies the remaining data leaving a strong clean signal, giving crystal clear operation! This unit is also 100% waterproof!
http://s304.photobucket.com/albums/nn199/Tagasagwan/?action=view¤t=signalboost-WP.jpg
B/New KYOSHO V-One RR & slightly used KYOSHO V-One R:
B/New Kyosho V-one RR unassembled w/ kawahara racing chassis & front 1way diff., uncut unpainted LeMans body, includes stock diff. lots of extra parts. ( missing shocks and clutch).
Slightly used V-one R assembled, w/ front 1way diff, includes Stock front diff. 6 wheels/tires, O.S. Max TR .12 engine & Pipe, 2 Speed auto clutch & transmission, No bodyshell. Both kits with boxes, front & Rear Stabilizers. ONLY being sold as PACKAGE! Repriced from 15K down to 13K NOW 10K na lang. NO ELECTRONICS!
Click here for product pictures:
NOVAK EVX1 w/ 2 Titan Motors- 4K Fixed, Like new kasi shelve queen ang E-Maxx ko. Perfect condition, NO thermal issues, Guaranteed mint!
I also accept payments thru
Text or Call Stephen 0919-8888865 Sorry No Trade! Pls. Include RCTech Username Meet up during Saturdays 7am-12noon at Kidney Center along East Ave. or Q.C. Track . Sundays 10am-12noon SM Megamall. Thanks to RCTech.net and Moderators!
- NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST**
- ABSOLUTE short circuit and motor overload protection
- 15 turn motor limit (Single motor)
- 27 turn motor limit (Dual motors)
- 1.5A External BEC
- Dual core microprocessor
- 5-10 NiMh cells input voltage (6.0 to 12.0V)
- Adjustable features include programmable reverse (including disable) & programmable brakes
- 4 Layer super power circuit board
- Thermal integrated protection system
- Digital one touch set up
- Legendary 100% waterproof design
- Dimensions : L39.0mm x W34.0mm x H13.0mm
- Weight : 55g
COMPETITON ESC's
FOR SALE LOSI 8IGHT 4WD NITRO BUGGY, ALUMINUM THREADE SHOCKS, ALUM KNUCKLE ARMS, TITANUM TURNBUCKLES, 150CC FUEL TANK, UNIVERSAL DRIVESHAFT, FRNT NREAR ALUM CHASSIS BRACE, ALUM STEERING BULKHEAD, MILLED CHASSIS, BNEW UNPAINTED BODY, XTRA PARTS, BOX N MANUAL.. 12.5K
FOR SALE BNEW DIGITAL X CHARGER B6, SAME AS IMAX B6, 1-6 CELL LIPO, LIFE, LI ION, 1-15 CELL NICD-NIMH, COMPLETE HARNESS, BUILT IN LIPO BALANCE... 3K LOWEST PRICE IN RCTECH., 5UNITS AVAILABLE
NO TRADE, NO PM, NO LAST PRICE SA TEXT!
09063147021-KENET
09063147021-KENET
Looking for
Looking for:
- 2 Pcs. Metal idler gear for Traxxas Emaxx1. If possible w/ bearing.
- Revo spec clutch conversion for Emaxx1.
Kung may Emaxx1 parts kayo na naka tambak lang and willing kayo ibenta nang mura, Pagusapan natin
Baka meron din kayo counter gear ng Tamiya M01. Ito yung 2nd gear from the pinion.
Text or call 09198888865
FOR SALE M8 AND ORION ADVANTAGE CHARGER
FOR SALE
SANWA M8 RADIO
MANUAL
TX AND RX 40.75MHZ
SUPERB CONDITION
ALAGANG ALAGA.
sold tnx sir jhon...
BOX AND MANUAL
FRESH NA FRESH
SUPER KINIS PA
ALAGANG ALAGA PO MGA BOSING
PRICE IS 4K FIX NA PO MGA SIR.
JUST CALL OR TEXT 09195010333 - VINA23
FAIRVIEW AREA.
SANWA M8 RADIO
MANUAL
TX AND RX 40.75MHZ
SUPERB CONDITION
ALAGANG ALAGA.
BOX AND MANUAL
FRESH NA FRESH
SUPER KINIS PA
FAIRVIEW AREA.
FOR SALE
T4 ASSOCIATED STADIUM TRUCK. INCLUDES........ 17 turn associated motor,B new A1 LRP ESC FORWARD REVERSE13 TURN MOTOR LIMIT.1STOCK STEERING SERVO,TIRES FRONT AND REAR,W/ BODY NO TEAR.W RADIO TQ AND RX. BATTERY NA LANG KULANG TAKBO NA.......EXTRA PARTS ALL FOR php.7,000 SEE THIS PICS http://photos-p.friendster.com/photo...171126311l.jpg http://photos-p.friendster.com/photo...940763112l.jpg http://photos-p.friendster.com/photo...615256833l.jpg 7K NA LANG WITH EXTRA USE RIMS FRONT AND REAR.
super clodbuster
(for sale until friday)
[B]FOr sale Super Clodbuster /B]
run few times(backyard bashing only)
rolling kit with body
comes with:
2 mabuchi motor
tires
rear lock diff
makinis pa yung body.
6.5k neg
RFS: tinatamad sa crawler project.
pwede rin trade to a crawler
2.75mhz fm FUTABA Megatech
-transmitter
-receiver
-no xtals
2.8k neg
get all for 8.3k
09156988883
buyer handles the shipping
comes with:
2 mabuchi motor
tires
rear lock diff
6.5k neg
-transmitter
-receiver
-no xtals
2.8k neg
get all for 8.3k
09156988883
IPINAGBIBILI:
TAMIYA TAO5 1ST GEN -2.5K
MGA KASAMA
*SPPOOL ONEWAY
*DEFFRENTIAL
*UNIVERSALS
PANGARRERA POH LABAN NETO. DI U MAG-SISI
PA PM NALANG POH MEET AT CAVITE IMUS OR QC PROJ4
MGA KASAMA
*SPPOOL ONEWAY
*DEFFRENTIAL
*UNIVERSALS
BOSZ NEIL2WD, DI KO POH MA-GETZ U. BAKET POH GANUN YUNG RESULTS NG REYS MO? DIBA MA-GETZ U UNG POINTS SA TATLONG FINALS LANG? BAKIT WEIRD ATA BOSZ?
PAKI EKSPLIKA POH. TALAGANG DI ME MA-GETZ EH
LOOKING FOR:
#TB601-Speed Mind New Transmitter Bag For SANWA M11 2.4GHz.
HENRY - 09279241821
HENRY - 09279241821
Item for pick up at Timog, QC area. Office hours.
#1 Vintage Kyosho Super 10 PHP18,000.00
OS max 12 CV-X engine, consumed 8 tanks
2 speed
carbon deck
upgraded shocks
tuned exhaust
Futaba controller
Free 2nd Kyosho Super 10 with wide arms.
-includes Kyosho stock engine
You can chop up the 2nd unit for parts or whatever you want to do with it.
Straight sale only.
#2 Traxxas E-maxx gen 1 PHP18,000.00
Never run
With TQ3 controller
0918-9143768, mobile landline 572-6921
2 speed
carbon deck
upgraded shocks
tuned exhaust
Futaba controller
Straight sale only.
Never run
With TQ3 controller
SALAMAT POH BOSZ RCKARTIPS. BUTI PA U NASAGOT ME NG TAMA. DI KO LAM KAY TOMMEMACKINEN PARANG GALET U ME? WAG POH GANUN BAKA HIHGBLOOD PO YOU RACING BLOOD KA PA KAMO REKTA SA PUSO MO YAN BRAD. HEHEHE
BOSZ NEIL2WD PAG SUMALI POH AKO F1 WAG U PO ME FIGHT AH? HEHEHE
!!!BOOM!!!
!!!BOOM!!!
