View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Si Jopet is playing? Sana naman, magsasara nalang ang track hindi pa nya na subukan!
I'll try to pass by on Saturday Geetoo.
Selling.....
Seling the following items...
Padala po sakin ito from U.S. years ago kaso we do not know how to use them kaya tinago nalang. The Storm Buggy needs some cleaning and minor repairs. It was only used for testing since we really do not know how to run it properly. The RS4 Kit box was opened just to check the contents. I am from Cainta - You can check out the items to offer your price.
Jigs - 0920-9185447
1/8 Storm Buggy RTR by GS Racing
http://www.horizonhobby.com/Products...ProdID=GSC2003
SOLD
HPI Racing RS4 Sport 2 Kit - Toyota Altezza Netz Castrol
http://www.hpiracing.com/kits/sport2/s2-m.htm
Brand New po yan box opened lang to check contents which are naka plastic pa. 4K. Cainta Area. SOLD
Thanks!
Jigs - 0920-9185447
SOLD
Thanks!
ITEM 1: FUTABA MC330CR ESC...USED
SOLD!!! Thanks sir walles (again) and rctech.
ITEM 2: HPI PRO-FOAMS...BNEW...IN BOX!!!
SOLD!!! Thanks sir neil (tukayo) and rctech.
Thanks for looking.
Thanks for looking.
BEST DEAL!
Novak GTB (Opened/no box but Never used!!!) + Novak 3.5r Brushless Motor (used but perfect running condish) .... P9,500 only.
Please PM or SMS at 0917.688.83.71
FOR SALE 3PK 40MHZ BLACK EDITION, PERFECT WORKING CONDITION, SMOOTH, PCM1024 RECEIVER, 3PKS STEERING WHEEL, FUTABA OR SPEED MIND TRANSMITTER BAG, MANUAL... 8.5K
FOR SALE 2 1024PCM RECEIVER, NO GLITCH, FRESH CONDITION...1.7K EACH SOLD!!!!
NO TRADE, NO PM
09063147021-KENET
NO TRADE, NO PM
09063147021-KENET
ITEMS UPDATE:
FOR SALE EMAXX AND TMAXX PARTS BANAWE STYLE! ALL PARTS ARE USED, BUT IN GOOD CONDITION.. KUNG DI MO TYPE WAG MO BILHIN.
EMAXX PARTS:
-EMAXX TRANSMISSION FULL ASSEMBLY, 1ST N 2ND GEAR SET, TOP SHAFT, GEAR COVER, BEARINGS, SPUR GEAR, TRANSMISSION BOX.. 4K SOLD!!!
-CHASSIS WITH BATTERY HOLDER..1.3K SOLD!!!
-FRNT N REAR SKID PLATE.. 400 SOLD!!!
-BODY POST.. 50 SOLD!!!
-FRONT N REAR BULKHEAD...600 SOLD!!!
-CENTER DRIVE SHAFT...400 SOLD!!!
-FRNT N REAR TURNBUCKLE...400 SOLD!!!
-8PCS HINGE PIN...300 SOLD!!!
-FRNT N REAR DIFFERENTIAL FULL ASSEMBLY... 1K EACH SOLD!!!
-4PCS LONG DRIVE SHAFT... 1K SOLD!!!
-CHASSIS BRACE, 2PCS...300 PENDING
-8PCS PILLOW BALLS...500 PENDING
-FRNT N REAR BUMPER...500 PENDING
-2PCS X BRACE FOR BULKHEAD...200 PENDING
-8PCS. UPPER N LOWER ARMS, WIDE VERSION...1K SOLD!!!!
-STEERING BELCRANK, INCLUDING POST... 300 SOLD!!!
-8PCS SHOCKS WITH RED SPRING... 1K RESERVE
-FRNT N REAR SHOCK TOWER...400 SOLD!!!!
TMAXX PARTS:
-TRANSMISSION FULL ASSEMBLY, REVERSE MODULE, 1ST N 2ND SPEED GEAR, BEARINGS ETC... 4K
-FRNT N REAR ALUM SKID PLATE...400
-ENGINE MOUNT...200
-.18 SIRIO ENGINE, VERY GOOD CONDITION...2.5K
-EZ START MOTOR ASSEMBLY...500
-T6 CHASSIS...500
-ORIGINAL BANANA PIPE...500
-BRAKE SET...400
-2PCS. CROWN GEAR N PINION... 500 EACH SET
-ORIGINAL WHEELS N TIRES, 85% CONDITION...900
FOR SALE 3 BRAND NEW IMAX B6 CHARGER WITH METAL CASING... 3.7K EACH
FIRST COME, FIRST SERVE NO RESERVATION...SOLD!!!!
FOR SALE VANTAGE PIPE FOR REVO, SLIGHTLY USED, FRESH CONDITION...
2.5K OR TRADE RC STUFF
NO TRADE, NO PM
09063147021-KENET
EMAXX PARTS:
TMAXX PARTS:
-ENGINE MOUNT...200
-T6 CHASSIS...500
-BRAKE SET...400
NO TRADE, NO PM
09063147021-KENET
Trinity Tire Warmers 800
Much More Tire Warmers with Temp Control 1.8k SOLD
Bnew Much More Motor and Armature Box 800
Carlsen Tuning Smart Temp vs-3480 1.2k SOLD
3 Racing Purple Motor Heat Sink
with Much More 5v Fan 400
Aluminum Dampers 800 SOLD
TA05 parts spool, alum diff joint,knuckle arms,wheel axle, aluminum swing shafts(blue) battery heat sink(blue) motor heat sink(blue), etc.all for 2.5k
FIXED PRICES
09062865524
please include your rctech handle
pickup at makro cubao or shell mindanao ave.
LOOKING FOR
HB CYCLONE S
or swap with
GPX4 pro kit (1/10 nitro on road)
no engine and electronics
0916-620-1901
HB CYCLONE S
or swap with
0916-620-1901
for sale....
b/new mugen mbx5t body shell never been cut with sticker -1.2k sold to sir raymond tnx!
b/new ofna side guard gray with fuel plate(hyper 7) 500 nlng
b/new ofna engine mount (hyper 7, ST) with chassis mount- 700 nlng
b/new 3pcs upper and 1 pc lower suspension arm for tamiya TNX 5.2-250 each
b/new Matrix Pro Lathe Motor 55T single (integy tech.,inc)-1.2k
txt or call or pm (09185306462) jason
I will take orders starting Feb 18 up to March 15 2008
cheap price good quality giant rc airplane,boat,nitro engine,gasoline engine
All of our products comply with international quality standards
P = 1,600.00
Manual http://www.hobbywing.com/upload/manu...V%20ubec_e.pdf
1 Specification
1.1 Output Voltage: 5V or 6V (Changeable with an output-voltage select switch )
1.2 Continuous output current: 5 Amps
1.3 Burst output current: 7.5 Amps
1.4 Input: 8V-42V (3-10 cells lithium battery pack)
1.5 Quiescent current: 20mA
1.6 Size: 48mm*27mm*9mm (length*width*height)
1.7 Weight: 37g
P = 6,500.00
1.1 Output: Continuous current 120A, burst current 720A.
1.2 Input: 4-12 cells NiMh/NiCd or 2-4 cells LiPo. Note1
1.3 BEC Output: 6V/2A.
1.4 Resistance: 0.0003 Ohm.
1.5 Motor Supported: Sensored brushless / Sensorless Brushless / Brushed
1.6 Suitable Brushless Motor: 2.5T and >2.5T Note2
1.5 Suitable Car: 1/8, 1/10, 1/12 on-road or off-road cars / trucks for competition race.
1.6 Size: 44mm(L) * 31mm(W) * 22mm(H).
1.7 Weight: 39g(Without wires)
Note1:
For brushless motor, the ESC supports up to 12 cell NiMh/NiCd (or 4 cell Lipo) input; While for brushed motor, the ESC only supports up to 6 cell NiMh/NiCd (or 2 cell Lipo) input.
For 4-6 Cell Ni-xx: You needn't change the fan coming with the ESC;
For 7-9 Cell Ni-xx: You must change the fan because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+6V);
For 10-12 Cell Ni-xx: You must choose a high voltage fan, and cut the output of the built-in BEC, then supply the receiver with an UBEC (An additional external DC-DC regulator);
Note2: The value of "T" number is tested under the following conditions:
a) The input is a 6 cells Ni-xx battery;
b) The ESC is equipped with a cooling fan.
5.5T/6.5T/8.5T 540 brushless motor is 3,700.00
11.5T/13.5T 540 brushless motor is 3,650.00
3.5T/4.5T 540 brushless motor 3,975.00
Check our accesories and engine parts for DL50
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=54
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=67
in stock
Imax B5 charger 3,200 in stock
Imax B6 charger 3,900 in stock
IMAX B8 charger 6,300 in stock
esky USB Simulator Cable P = 500.00
Tower pro Servo mg995 950.00
Tower pro Servo mg945 950.00
11.1V 1600mah 8C Gun-TypTransmitterLipo 1,600
11.1V 1500mah 15C Li-Polymer 1,600
7.4V 3500mah 25C battery 2,800.00
11.1V 2200mah 20C Li-Polymer Battery 1.750
7.4V 2200mah 20C Li-Polymer Battery 1,550
futaba 11.1 v 2000mah 12c transmitter battery 1,750.00
NEW
Wing Span: 69.2in/1760mm P 13,600 /w asp 4 stroke120
P = 20,500
Wing Area: 960sq in/62sq dm
Flying Weight: 10.0lbs/4570g (Fiberglass)
Fuselage Length: 66.2in/1684mm
Engine Required: 2C 0.90 cu in ; 4C 1.20 cu in
Radio Required: 4 Channels, 5 Servos
Wing Span: 66in/1670mm
Wing Area: 490sq in/32sq dm
Flying Weight: 7.0lbs/3200g (Fiberglass)
Fuselage Length: 49in/1250mm
Engine Required: 2C 0.52 cu in ; 4C 0.70 cu in
You can visit our website
www.cyclonetoy.com www.cheapricequalityrc.zoomshare.com
30% YAK 54 50 CC 85" WING SPAN P 22,500 / combo DL 50cc = P35,500 in stock
Carbon fiber tube
fiber glass cowl
with 22x 10 wood prop
U-BEC = P 600.00 in stock
> Input voltage: 11.1V/18V
> Output: 5.0V/6.0V
> Current capability: 3A
> Size(mm): 20X30X7
Rx-Regulator - P 600.00 in stock
> Use only2-cell(7.4V)
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
spark plug dl 50 = 460 each 4 pcs in stock
Call or text.cell no. 09158884491 / 045 8660458 look for alvin
Email: [email protected][
P = 1,600.00
1 Specification
1.7 Weight: 37g
P = 6,500.00
Note1:
in stock
NEW
P = 20,500
Carbon fiber tube
fiber glass cowl
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
BEST BUY:
futaba servo s3003 2 pieces 1 brand new and 1 used --- 850 neg
futaba transmitter bag used (red) ---- 650 neg
team atlas battery heatsink/jig with dual fan used --- 1.650k neg.
Novak GTX --- 4.5k neg.
Futaba 3pm fully synthesized 27 mhz with receiver --- 5k neg.
Futaba 203 HRS receiver 27 mhz --- 3k neg
Futaba digital servo s3151 --- 1.8k neg
futaba esc mc 330 used --- sold
Attachment 317534
call/txt 09064933924
for pick up in cavite area/free delivery on selected items
Attachment 317534
see you guys tomorrow! cant wait! been itching to race. kita kits mga bro. despite the circumstances, im sure we'll make this a memorable race with everyone there. see you all!
ceterfire: pinag iisipan ko pa kung mag double class ako .... binubuo ko pa isa kong kit. sana matapos mamayang gabi.
geetoo: what time will the track be open? need to try out my ride. mejo maninibago ako dito ... hehehe
RC STUFF.
FOR SALE.
CASH ONLY.
1) USED BUT SURELY NOT ABUSED HPI .25 EN-
GINE WITH STILL NEW ROTOSTART BACKPLATE.
ONLY RUN 2 TANKS FOR BREAK-IN, UNCOMPLE-
TED BREAK-IN. B/N 13 FIN GPM CYLINDER HEAD
IS NOT ON TO SHOW HOW LITTLE IF ANY WEAR
EXISTS. WILL INCLUDE ORIGINAL SAVAGE ENGINE
MOUNT.------------------------------------------------------------P5,850.
2) B/N BUSHNELL SPEEDGUN. MEASURES RC CAR/
TRUCK SPEED. NO MORE GUESSWORK/ EMPTY
BOASTS. 10-200MPH, ACCURACY OF +/- 1 MPH
OR +/- 2 KPH FROM 27 METERS, MPH OR KPH.
OPERATES UP TO 20 HOURS ON 2 "C" BATTERIES.
CAN ALSO BE USED TO MEASURE FULL SCALE
CAR SPEEDS OF 10-200 MPH. GET IT HERE NOW.---------------P4,850.
3) B/N 1/28TH KYOSHO MINI-Z MA-010 AWD RTR
READYSET WHITE NISSAN SKYLINE. 27 MHZ. -------------------P6,750.
CHECK THIS LINK FOR MORE INFORMATION-
http://kyoshoamerica.com/carsandtruc...cer/MA-010.asp
4) B/N JR RACING FM XS3 SYNTHESIZED (NO CRYS-
TALS NEEDED)3-CHANNEL, 6-MODEL MEMORY 40
MHZ, COMPUTER RACING SYSTEM. TX, RS 310
MINI-RX, 2 NES-577 SERVOS, BATTERY CASE &
WIRING HARNESS. COMPLETE.------------------------------------P7,650.
LOOKS JUST LIKE THE PICTURE IN THIS LINK-
http://www.horizonhobby.com/Products...odID=JRP317275
5) SLIGHTLY USED HPI TF-3/RF-3/27.195 MHZ
(TX/RX/X'TALS) RADIO SYSTEM WITH B/N IN
PLASTIC AIRTRONICS 94102Z, 50 OZ-IN.
TORQUE, PRECISION HEAVY DUTY STANDARD
SERVO.-------------------------------------------------------------P1,750.
6) B/N CASTLECREATIONS MAMBAMAX ESC/
CM36 6900KV BL MOTOR COMBO. PROGRAM-
MABLE VIA SUPPLIED USB LINK.---------------------------------P10,380.
7) TAKE-OFF ITEM: HPI SC-15 ESC W/REVERSE.
IMMEDIATELY TAKEN OFF FROM E-FIRESTORM.
15T 540 MOTOR LIMIT. TESTED ONLY. LOOKS
NEW. ALL ORIGINAL, NO MODS.----------------------------------P1,850.
8) AS NEW, TRINITY LIPO CHARGER/BALANCER.
CHARGES & BALANCES 2 & 3 CELL LIPO PACKS.
110-240V AC INPUT, 0.75A OUTPUT. TAKE-OFF
FROM TRINITY NOW RTR KIT.------------------------------------P1,550.
PRICES SUBJECT TO CHANGE WITHOUT
PRIOR NOTICE.
PICK UP ONLY 10 A.M.-4P.M. WEEKDAYS, EDSA-
GREENHILLS AREA. NO PRIVATE MESSAGES PLEASE.
KINDLY INCLUDE FULL NAME OR RCTECH USERNAME
WHEN TEXTING TO DON @ +63915-4524488. THANKS
TO RCTECH.NET, MODERATORS AND TO ALL FOR
BROWSING.
CASH ONLY.
PRIOR NOTICE.
BROWSING.
GY401 w/ servo
IM LOOKING FOR CHEAP SECOND HAND BUT IN GOOD CONDITION
GY401 W/ SERVO
PM OFFERS NLNG PO
GY401 W/ SERVO
PM OFFERS NLNG PO
