View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
BUY 1 TAKE 1 Monster Truck
TIRWUUMMM!!!
RC STUFF !
FOR SALE. CASH ONLY.
MOST PRICES DROPPED TO
BELOW ACQUISITION COST.
1) B/N 1/8TH HOTBODIES LIGHTNING STADIUM TRUCK
ROLLING CHASSIS, .26 ENGINE W/ ROTOSTART BACK-
PLATE, BODY, BOX & MANUAL. NO ELECTRONICS &
OTHER ACCESSORIES.-----------------------------------------P15,250.
CHECK THIS LINK FOR MORE INFORMATION -
http://www.hotbodiesonline.com/kit.p...b55006&lang=en
2) B/N IN BOX RTR HPI E-SAVAGE W/ GT TRUCK BODY.
CHARGER, BATTERIES, MANUAL, ETC. COMPLETE.------------P15,850.
CHECK THIS LINK FOR MORE INFORMATION-
http://hpiracing.com/kitinfo/507/
3) B/N IN BOX 1/10TH HPI MT2 18SS KIT. UNASSEM-
BLED, .18(3.0) ENGINE, CVDS, HARDENED METAL
GEARS, CLEAR BODY. -------------------------------------------P14,850
4) B/N CASTLECREATIONS MAMBAMAX ESC/ FEIGAO
8L 3072KV BL MOTOR / 20T 32P 5MM BORE PINION
COMBO ON 14.4V FOR 68 KPH E-SAVAGE. WHEELIES
ON COMMAND EVEN WHILE AT SPEEDS
OF 32KPH OR DIAL OUT MOST OF THE WHEELIES
VIA USB CASTLELINK PROGRAM.-------------------------------P12,780.
5) B/N NOVAK HV-MAXX 4.5 BRUSHLESS MOTOR SYSTEM
W/ 12T 32P PINION. UPGRADED VERSION, DROP-IN FOR
E-MAXX, W/SOME MODS FOR E-SAVAGE. NICKEL PLATED
ROTOR, RIBBED ENDBELL, ORIGINAL ESC COOLING FAN.-----P12,750.
http://teamnovak.com/products/brushl...tem/index.html
6) B/N HONG NOR X.12 ENGINE & ASSEMBLY UP TO 13T
CLUTCHBELL, POWER-SIDE AND UP TO TUNED PIPE
MOUNT, EXHAUST-SIDE. MANIFOLD, POLISHED TUNED
PIPE, FUEL TANK, ETC. INCLUDED. ENGINE MOUNT NOT
INCLUDED. ALL ORIGINAL TAKE-OFF FROM HN RTR CRT.5-----P7,850.
7) B/N AIRTRONICS HIGH TORQUE BALL BEARING METAL
GEAR 94162Z SERVO. 154 OZ-IN., .15 SEC. @ 6V--------------P2,250.
8) B/N IN BOX GM RACING V12/R CAR BRUSHED ESC
W/REVERSE, >8 TURN MOTOR LIMIT. MADE IN GERMANY.-----P2,430.
ALL NEW STUFF, NOTHING TO DOUBT.
NO RESERVATIONS. FIRST COME FIRST SERVE.
PRICES SUBJECT TO CHANGE WITHOUT NOTICE.
PICK UP ONLY 10 A.M.-4P.M. WEEKDAYS, EDSA-
GREENHILLS AREA. NO PRIVATE MESSAGES PLEASE.
KINDLY INCLUDE FULL NAME OR RCTECH USERNAME
WHEN TEXTING TO DON @ +63915-4524488. THANKS
TO RCTECH.NET, MODERATORS & TO ALL FOR BROWSING.
Services Offered
Edward's Custom Crawlers
Accepts Custom Jobs for aluminum chassis and parts for most RCs.
T5 or T6 Aluminum available
We specialize in crawler conversion, from simple crawlers to realistic crawlers. Accepts orders for RC parts..if we can't order it, we'll try to make it..
If you have out of production kits that hasn't been run because of lack of available parts, we'll try to make one for you..
(we don't make gears and other rotating parts..except dogbone extensions)
So far..we made:
Wheely King Crawlers
TLT Crawlers
Juggernaut Crawler
and Savage Parts can be viewed here...http://edward531.proboards58.com/index.cgi
Sirs,
To all those who PM me or those who has customs jobs pending with ECC, don't worry if I can't reply right a way in the coming days, Final Exam ko po kasi, so I have to maximize all my time between the projects and review..work as usual po, yun lang limit muna time ko sa pag access ng messages. Lastly, my phone suffered a recent mishap so some numbers were erased, but my number is still the same, I may ask some of you who recently dealt with me to confirm your ID, please don't be offended if I asked your name ha... Thanks for understanding.
So far..we made:
TLT Crawlers
Juggernaut Crawler
Sirs,
FOR SALE
B/N YOKOMO ZR-01 DRIFT TIRES.....1K
APEX INFINITY CHARGER/DISCHARGER COMES W/ OWN POWER SUPPLY, BOX AND MANUAL.....3K
(search the product in yahoo for the specs )
TEKIN G112-C FORWARD/BRAKE NO MOTOR LIMIT ESC WITH TAMIYA 23 TZ MOTOR.....3K
looking for!!!
I will take orders starting Feb 18 up to March 5 2008
cheap price good quality giant rc airplane,boat,nitro engine,gasoline engine
NOTE :: To our valued costumer the first Batch order will be arriving on march 3 sorry for the Delay Pasensya na po nauna yung mga airplane next week pa yung lipo and charger sorry for the mistake thanks rctech
All of our products comply with international quality standards
Check our accesories and engine parts for DL50
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=54
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=67
Arriving SOON
Imax B5 charger 3,200
Imax B6 charger 3,900
IMAX B8 charger 6,300
Tower pro Servo mg995 950.00
Tower pro Servo mg945 950.00
11.1V 2200mah 20C Li-Polymer Battery 1.750
11.1V 1600mah 8C Gun-TypTransmitterLipo 1,600
11.1V 1500mah 15C Li-Polymer 1,600
7.4V 2200mah 20C Li-Polymer Battery 1,550
7.4V 3500mah 25C battery 2,800.00
NEW
Wing Span: 69.2in/1760mm P 13,600 /w asp 4 stroke120
P = 20,500
Wing Area: 960sq in/62sq dm
Flying Weight: 10.0lbs/4570g (Fiberglass)
Fuselage Length: 66.2in/1684mm
Engine Required: 2C 0.90 cu in ; 4C 1.20 cu in
Radio Required: 4 Channels, 5 Servos
Wing Span: 66in/1670mm
Wing Area: 490sq in/32sq dm
Flying Weight: 7.0lbs/3200g (Fiberglass)
Fuselage Length: 49in/1250mm
Engine Required: 2C 0.52 cu in ; 4C 0.70 cu in
You can visit our website
www.cyclonetoy.com www.cheapricequalityrc.zoomshare.com
30% YAK 54 50 CC 85" WING SPAN P 22,500 / combo DL 50cc = P35,500 in stock
Carbon fiber tube
fiber glass cowl
with 22x 10 wood prop
U-BEC = P 600.00 in stock
> Input voltage: 11.1V/18V
> Output: 5.0V/6.0V
> Current capability: 3A
> Size(mm): 20X30X7
Rx-Regulator - P 600.00 in stock
> Use only2-cell(7.4V)
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
spark plug dl 50 = 460 each 4 pcs in stock
Call or text.cell no. 09158884491 / 045 8660458 look for alvin
Email: [email protected][
Arriving SOON
NEW
P = 20,500
Carbon fiber tube
fiber glass cowl
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
Flying boat for sale
FOR SALE
B/N FLYING BOAT 100% READY TO FLY
Brushless motor w/ esc, 11.1v lipo batt, wall charger, extra parts...
P8,000 free shipping fixed price
2 units available
1 unit reserved
1 unit left
txt or kol 09152011654
pic and vid
http://www.youtube.com/watch?v=JImhA...eature=related
2 units available
1 unit reserved
1 unit left
pic and vid
novak GTB w/ lipo cut off 5k fixed
much more tire warmers with temp sensor 2k fixed
09062865524
09062865524
TIP : there's no need to repost your items if it can be found in the previous two pages. Mahihirapan lang ang buyers sa paghahanap pag nag-uunahan tayong makapag-post agad kada page.
Di pa naman natabunan yung post mo sa First page di ba? paki-edit na lang muna yun at dun mo idagdag mga new items mo. Ginagawa na ng iba yun.
Novak T4 ESC P1,000
09209323803
09209323803
@vroomvroom
Makes it easier for you and me to find stuff bro. lets all go with the flow!
Lesser redundant pages makes for a cleaner thread!
FOR SALE
MUGEN SEIKI RTR 1/8 BUGGY-10k fixed na po! with some freebies
Includes the following:
- 0.21Vspec OS engine (honestly this is not a race worthy engine, good for bashing only, no glow plug)
- KO Propo Ex-11 Presto FM transmitter (with crystal 40mhz)
- Novak 3 channels receiver (with crystal)
- Aluminum front and rear shock tower
- Carbon fiber servo tray
- B/N Air filter
- 2 pcs. standard servo (steering & throttle)
- 2 pcs. bashed body cover
- 1 pc. rx battery (hump type)
- 4 pcs. tire with dish type rim
- "Dynamite" tuned pipe and manifold
- Starter box with free 12V lead acid battery
The freebies:
- 4 pcs. spare tire with dish type rim
- 1 pc. vintage AIRTRONICS 27mhz FM transmitter w/ module (no antenna, no crystal)
- 1 pc. tire wrench
NOTE : this is a 2nd hand off-road kit, expect for some scratches. No chicka text please
For faster transaction call/text 09174912255 (Richard)
Meeting place @ McDonald's - Macapagal (weekends) or nearby Pasay, Parañaque, Makati area (by appointment)
Thanks for viewing, thanks RCtech!
- B/N Air filter
The freebies:
- 1 pc. tire wrench
ctx d2
boys selling my ctx-d2 discharger very good condition, comes with b0x and manual for your convience. 5k only. let me know 0920-949-8888
Updated!
Thanks for looking.
Thanks for looking.
for sale 1/10 hobao gpx pro with nova engine
for sale
gpx4 pro with novarossi L5 good working condition - 8.5k
with extra parts good
alabang area
09175328473
alabang area
09175328473
