View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
REPRICED
BUYING: 2nd hand lng at yung tma yung prize..
NOVAK GTX
GUN TYPE REMOTE CONTROL
TAO5 rolling chassis
Selling:
CHASSIS:FULL CARBON FIBER HPI RS4 - P 2500
with suspension arms,HITECH servo,2 bushed up body(ferrari enzo&HONDA INTERGRA),BUMPER, WHEELS, FULL BALLBEARING..
BATTERY: INTELLEC 3600- P 1000
ESC: FUTABA MC330CR(GOOD CONDITION,NO HIDDEN DEFECTS)- P 1700 REPRICED!! TIL SUNDAY
CONTROLER: STICK TYPE NO DEFECTS RECEIVER NOT INCLUDED! - P1000
REMOTE BATTERIES: CD-R KING 2400MAMPS 8PCS - P 450
ALL FOR 6K
OTHER ITEMS:
NOKIA NGAGE- P4500(NEG)
WITH CHARGER AND 512MB MEMORY
KUNG GUS2 nyo magpaputi!!! glutataion na INJECTION - P 1500
KAMI NG MAGINJECT...
TXT ME 09052447310 LOOK FOR JUSTINE.
MEETING PLACe:
SM CENTERPOINT,ARANETA AVE,GATEWAY
NOVAK GTX
Selling:
ALL FOR 6K
OTHER ITEMS:
MEETING PLACe:
MOST PRICES DROPPED !
FOR SALE. CASH ONLY.
MOST PRICES DROPPED TO
BELOW ACQUISITION COST.
1) B/N RTR 1/8TH HOTBODIES LIGHTNING STADIUM TRUCK.
27MHZ, .26 ENGINE, ROTOSTART SYSTEM , IGNITER, FUEL
BOTTLE. BOX/ MANUAL.COMPLETE.-----------------------------P17,950.
LINK-
http://hotbodiesonline.net/kit.php?p...b55006&lang=en
1.1) TRUCK WITH ENGINE/ROTOSTART SYSTEM ONLY. NO
ELECTRONICS, NO FUEL BOTTLE/IGNITER/ETC.------------------P15,880.
2) B/N IN BOX 1/10TH HPI MT2 18SS KIT. UNASSEMBLED,
.18(3.0) ENGINE, CVDS, HARDENED METAL GEARS, CLEAR
BODY. --------------------------------------------------------P15,250.
3) B/N BUSHNELL SPEEDGUN. MEASURES RC CAR/TRUCK
SPEED. NO MORE GUESSWORK/ EMPTY BOASTS. 10-200
MPH, ACCURACY OF +/- 1 MPH OR +/- 2 KPH FROM 27
METERS, MPH OR KPH. OPERATES UP TO 20 HOURS ON 2
"C"BATTERIES. CAN ALSO BE USED TO MEASURE FULL
SCALE CAR SPEEDS OF 10-200 MPH. GET IT HERE NOW.----------P4,950.
4) B/N IN BOX 3 1/18TH RTR TEAMLOSI MINI-T, ALREADY
HOPPED UP WITH GPM BLUE ALLOY SHOCKS/SPRINGS &
TL BEARINGS, SILVER GRAY BODY, 26.995 MHZ AM. --------------P4,650.
LINK-
http://www.losi.com/Products/Feature...rodId=LOSB0200
5) B/N AIRTRONICS HIGH TORQUE BALL BEARING METAL
GEAR 94162Z SERVO. 154 OZ-IN., .15 SEC. @ 6V----------------P2,450.
LINK-
http://www3.towerhobbies.com/cgi-bin...&I=LXJYT8&P=SM
6) B/N GRAUPNER V12/R CAR BRUSHED ESC W/REVERSE,
>8 TURN MOTOR LIMIT. MADE IN GERMANY.----------------------P2,650.
7) B/N CASTLECREATIONS MAMBAMAX ESC/ GREAT PLANES
2600KV BL MOTOR / 20T 5MM BORE PINION COMBO ON 14.4V
FOR 60 KPH E-SAVAGE. WHEELIES ON COMMAND EVEN WHILE
AT SPEEDS OF 32KPH OR DIAL OUT MOST OF THE WHEELIES
VIA USB CASTLELINK PROGRAM.--------------------------------P10,980.
8) B/N NOVAK HV-MAXX 4.5 BRUSHLESS MOTOR SYSTEM,
UPGRADED VERSION, DROP-IN FOR E-MAXX, W/SOME MODS
FOR E-SAVAGE. NICKEL PLATED ROTOR, RIBBED ENDBELL,
ORIGINAL ESC COOLING FAN.----------------------------- -----P13,200.
LINK-
http://teamnovak.com/products/brushl...tem/index.html
ALL NEW STUFF, NOTHING TO DOUBT.
NO RESERVATIONS. FIRST COME FIRST SERVE.
PRICES SUBJECT TO CHANGE WITHOUT NOTICE.
PICK UP ONLY 10 A.M.-4P.M. WEEKDAYS, EDSA-
GREENHILLS AREA. NO PRIVATE MESSAGES PLEASE.
KINDLY INCLUDE FULL NAME OR RCTECH USERNAME
WHEN TEXTING TO DON @ +63915-4524488.THANKS
TO RCTECH.NET, MODERATORS & TO ALL FOR BROWSING.
LINK-
LINK-
LINK-
LINK-
Phaltline Tires on Blast Wheels
For Sale
1. Phaltline Tires on Blast Wheel - 2500
- Painted it with Metallic Black (Used to be chrome)
- 95% Thread, used only twice in an on-road MT race.
- Used for display after the event.
Reason for selling: Lost interest to On-road MT set-up
2. Savage X SS/4.1/4.6 non-adjustable upper arms - 300
- complete set
- used only once
- excellent condition
Meeting Place preferably Mandaluyong Area during weekdays or QC Area during weekends.
Carlos N. Davis
09178570781
- complete set
- used only once
Carlos N. Davis
09178570781
NITRO
Looking for Nitro Kit 2nd hand yung mura lang and good condition...
thanks!
Pls pm or txt me..
09153240158
thanks!
Pls pm or txt me..
09153240158
For sale:
Novak Millenium charger with box and manual..3k neg. SOLD
MILLENNIUM SPECS & FEATURES
Complete Battery Management System
Microprocessor controlled for easy use
Compatible with the N-Power power supply
Battery conditioning (if needed)
Case Size: 4.00” x 4.38” x 2.33” (10.16 x 11.13 x 5.92 cm)
Weight: 14.32 ounces (406 grams)
Backlit display
Input Voltage (Power Source): 12-15 volts DC
Charging Capability: 4-8 cells (1.2 volts DC per cell)
Ni-Cd Linear Charge Rate: 0.5 – 7.0 amps (adjustable)
Trickle Charge Rate (after linear peak): 0.1 – 0.4 amp (adjustable)
Voltage Threshold/Delta Peak (Ni-Cd modes): 4 –20 mv/cell (adjustable)
Ni-Cd Reverse Pulse Charge Rate: 0.5 – 7.0 amps (adjustable)
Reverse Pulse Duration: 5-20 milliseconds
Ni-MH Charge Rate: 0.5-1.5 amps (adjustable)
Detailed charge history for comparing battery packs, and for tracking the performance of your packs
Fully protected against input/output reverse voltage and short-circuits, shorted batteries and thermal overload
Internal heat sink and fan for cool and reliable operation
Novak Spy esc....1.5K
Good as brand new
with box, original wires
perfect for micros.
or trade with TEU101bk esc and silvercan motor
or TEU101BKesc and used servo
looking for
universal drive shaft (CVD) for ta04/414
alloy hex adapter
crome wheels
09228685384 Racenut
Backlit display
Good as brand new
perfect for micros.
looking for
alloy hex adapter
crome wheels
09228685384 Racenut
In very good cond. tekin TSC G-12c esc no motor limit with box and manual
3k
Futaba MJ with tamiya reciever w/ fail safe, 2 servos in mint cond.
2.5k
bnew yokomo zr01 drift tires with ring
1.2k
bnew yokomo drift master rims
700 SOLD
hpi pro4 with bmw m3gt body (not bashed), hpi work miester rims with ABS tires,1 s3003 servo, upper and lower deck cbf, cbf center shaft, purple aluminum heat sink, cbf shock towers, threaded shocks, alum hex wheel hub, alum c-hub, with lots of spares,with 1 gp 3700 batt for bashing
7k neg
SOLD
Digital Apex infinity charger (nimh-nicd) 100-infinty mah 3amps dis. 6amp cha.
with power supply box and manual
3k
ALL REPRICED
09222823280 - choyie
3k
2.5k
1.2k
700 SOLD
7k neg
SOLD
3k
ALL REPRICED
for sale
FOR SALE:
FUTABA MAGNUM 3PK TRANSMITTER
Includes:
-PCM 1024 receiver
-crystals
-team speed mind bag
-box and manual
All for P12,000.00 (neg.)
All items are in good condition. Serious buyers only…
Call or text allan: 0918-6144983
Includes:
-PCM 1024 receiver
-crystals
-box and manual
sorry!
for sale 25size plane engine futaba s3001 servo
*25 thunder tiger engine for PHP2,000
*4 servo(3 futaba s3001 and 1 generic servo) for php1,500
or get all 3k
09287751101
or get all 3k
09287751101
cheap price good quality giant rc airplane,boat,nitro engine,gasoline engine
I will Take Orders for sure buyer only. ON feb 15 will be the deadline of all orders, thanks rctech
We have a new airplane and new low price adjustment !!
You can visit our website
www.cyclonetoy.com www.cheapricequalityrc.zoomshare.com
Imax B6 charger P 3,900.00 cheaprice order now!!!
Imax b5 charger P 3,200.00 cheaprice order now!!!
Imax B8 charger P 6,300.00 cheaprice order now!!!
LIPO Battery www.cyclonetoy.com
for inquire text the item num,
i will send you the price
cell num 09158884491
30% YAK 54 50 CC 85" WING SPAN P 22,500 / combo DL 50cc = P35,500 in stock
Carbon fiber tube made in USA plastic film
fiber glass cowl
with 22x 10 wood prop
30% EDGE 540 50 CC 85" WING SPAN P 20,500 / combo DL50cc = P=32,500 in stock carbon fiber boom
fiber glass cowl
with 22 x 10 propeller and aluminum
spinner 3.5 inches
New" peak 100cc = P26,500 out of stock
DL50 cc engine new edition P=15,200 in stock
7.4v lipo 12 c 2200mah P= 1,450 sold out
U-BEC = P 800.00 in stock
> Input voltage: 11.1V/18V
> Output: 5.0V/6.0V
> Current capability: 3A
> Size(mm): 20X30X7
Rx-Regulator -P 850.00 in stock
> Use only2-cell(7.4V)
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
Tower Pro MG945 digital Servo all metal gear P950.00 in stock
spark plug dl 50 = 460 each 4 pcs in stock
Hawk wood prop 14x8 = 700 3 pcs in stock
hawk wood prop 22x10 = 750 2 pcs in stock
spinner 3.5 inches aluminum P= 850.00 sold out
Futaba gy 501 gyro w/manual P= 4,500
Call or text.cell no. 09158884491 / 045 8660458 look for alvin
Email: [email protected][
"Home made CONYNE DELTA KITE P = 400.00 each
70 inches wing span
Light Weight Fabric Materials
Bamboo Frame
Include Lines,Tails,Case
Other Designs and Colors Available
Text or call 09196014133 look for Eric Basit
For sale
Futaba Transmitter 7CHP with 7ch rx = 8,500
shipping paid buy the buyer
Pic
http://www.rctech.net/forum/showthre...187458&page=83
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
fiber glass cowl
fiber glass cowl
spinner 3.5 inches
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
70 inches wing span
Bamboo Frame
For sale
Pic
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
FOR SALE ... edit ...
Still Looking for HPI E-Firestorm
-Needs to be as fresh as possible.
-No Defects.
-Preferably RTR.
-Reasonable Price.
-Seller should be able to bring the kit in Alabang(weekdays) or in Lil's Makati on Sundays.(Sa Batangas pa po ako manggagaling)
"I can offer as much as P7.5k-8k para sa super kinis, sariwa at rtr na kit."
PM or Tx me at 0922-811-6472 for your offers
-Pls. include your rctech username or real name when texting.
-No Defects.
-Preferably RTR.
-Reasonable Price.
Nandito lang ako Papsi.. ikaw naman miss mo na agad ako ha...
Hindi pa ako makapag register kasi hindi ko alam Frequency ko. baka mag personalized ako kung may available sa shop tapos baka mag spectrum na rin...
Gusto ko mag laro gamit Pro4 ko, kaya lang himay-himay pa. hindi pa yata nasoli yung nahiram na mga parts last year. eh mukhang wala na yata stock yung mga parts na hiniram sa shop nila Geetoo.
Pero definitely Lalaro ako.
If ever paki register nalang muna ako.
Yung Schedule ng alis nyo papuntang Cebu paki post na rin... update mo ako sa booking ng ticket ha.
Si Papa Caveman ba hindi na naglalaro? Sarado na yung Parlor nya?
