View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
yep, that's the reason it's open again.
update lang po..
FOR SALE:
APEX CHARGER V2.0 INFINITY
Features:
comes with own Power Supply
Advanced peak detector automatic cut-off circuit with MOSFET and linear current charges battery to 100% without overcharging.
Selectable 0DV and -DV cutoff technology for NICAD and NIMH battery respectively.
8-bit 12MHz CPU with 32k ROM, 2k RAM, 4 channel 16 bit ADC, and 2 channel 10-bit DAC current control output.
Output current automatic dec. if overload.
Built-in watch-dog timer.
Reverse polarity protected.
Recharges 1 - 10 cells 100mAh - ¥mAh. Output current can be changed from 0.1A to 6.5A ( 0.1A step) and discharging current is 0.1A to 3A (0.1A step) with automatic discharger cut off voltage setup.
16 character dot-matrix LCD, display with output V, output A, mAh, time, average V, Wh, peak V, set charger A, set discharger A, input V and mode.
Precision level reaches to 2 unit places and 3 decimal places. e.g. 11.934V.
Built-in cooling fan.
Specification:
Input Voltage: DC 11V to 15V, 12V lead-acid battery or APEX V12 220V AC S.P.S
Current drain: max approx 10A
Normal battery voltage: 1.2V to 12.0V (1 to 10 NICD / NIMH cells)
Charge current: 0.1A to 6.5A up to 15V, 0.1A to 4.0A over 15V
Automatic charge termination: Delta Peak process
Trickle charge current: approx. 80mA
Discharge current: 0.1A to 3.0A
Discharge termination: automatic, at approx. 0.8V / cell
Max. discharge power: approx. 25W
Protective functions: Polarity protection at inpur and output, short-circuit
protection on output, overheating protection, low voltage protection.
Fuse: 7.5A car fuse
Dimensions: approx. 100*140*52mm
**** SUPER RUSH... SELLING FOR 2.5k(FIRM) ***** (NO PM / TRADE /SWAP).. SERIOUS BUYERS ONLY. THANX PO MGA BRADIR
0920 - 823 - 2443.. TEXT NA!
***RESERVED TILL SATURDAY!!!***
FOR SALE:
Features:
Specification:
Fuse: 7.5A car fuse
DF02 Rolling Chassis
For Sale
specifications:
1. Brand new bathtub frame/chassis
2. Full Ball Bearings
3. GPM Aluminum C-Hub
4. GPM Aluminum Turnbuckle set
5. Aluminum Propeller shaft
6. Aluminum Steering Set
7. Tobee Strengthening gear box joint
8. Customized Aluminum Front Shock Towers
9. Stainless steel suspension shaft
10. Speed Tuned Gear Set
11. Aluminum Motor mount
12. Aluminum Wheel Adapter
Freebies:
I will include all spare parts that i have with this chasis. a lot of spare parts add a few more and you can make another kit.
- 3 pcs stock front towers
- 3 pcs stock rear towers
- 2 pcs battery holders
- 1 pc front arm
- 1 pc rear arm
- stock plastic battery mount
- stock steering sets
- 1 set of stock damper springs
- 1 pc drive shaft cover
- 1 pc stock propeller shaft
- 1 used chassis
- used outdrives
selling for 4K. fixed
pickup at Sonic Boom Track this weekend june 16, 2007
call/text
09283054476
specifications:
Freebies:
- 1 pc front arm
- 1 pc rear arm
- 1 used chassis
- used outdrives
call/text
09283054476
Location: 205 2/F Place One Bldg. Katipunan Ave., Q.C. Tel: 949-2129
Trader Rating: 4 (83%+)
On Stock!!
Savage X SS
HPI Nitro RS4 3 18SS Kit
E Savage Kit RTR
HPI Firestorm
HPI Baja 5b RTR
Hotbodies Cyclone D4 4WD Kit
HB Cyclone Moorespeed Kit
HB Cyclone Drift Kit
And lots more on our shelves....HPI & HB hop up & spare parts
Wheely Kit Conversion Kit for 4WD
Baja Paddle Tires
Baja LED Lishts Set
Moorespeed Motor Mount for Brushless System
Savage X SS
E Savage Kit RTR
HPI Firestorm
HPI Baja 5b RTR
Baja Paddle Tires
Baja LED Lishts Set
[QUOTE=sir miles;3376338]
Dynamite Alumn. tuned pipe very good condish no dent - 1600
Brand new Fuel tank - 500 na lang (650 ang tag ng Lils)
Brand new Kyosho clutch shoes - 500 (pwede sa TNX)
MIP on board temp gauge w/ lexan cover 1000
T/E Maxx alumn. front &rear bumpers w/ wheelie bar - 1000
CVEC dual chamber pipe for nitro touring - 2000
09178903878
UPDTE LANG
09178903878
UPDTE LANG
FOR SALE
Very good condish Nova 421B racing engine
very good compression
fresh in and out
With 3 pin flywheel and nut
6K neg
09178903878
fresh in and out
6K neg
09178903878
lf:
looking for the ff:
new or 2ndhand (for rc18t)
1. esc (can also be the stock one)
2. replacement shocks (aluminum or stock as long as it is not leaky)
3. steering assembly (aluminum)
3.
can contact me at 09209110396. thanks.
3.
LOOKING FOR :
TC3 Springs BLUE, Silver and GOLD
jason - 09175343649 or 09228952766
Hi Barbelista!
@Hanz kumusta takbo?
@Gnj ikaw din how was the run at JP?
@Bigz silent night ka ah?
FOR SALE
FOR SALE
Sanwa M8
w/ Manual
4.9K
PM or text 09273634443
Sanwa M8
w/ Manual
4.9K
For sale slightly used
Rayspeed Exceed discharger P2,500 only neg
input voltage= dc 12-14v
battery type= sub c ni-cd,ni-mh
cell= 1,3,4,6 cell
mode= equalizing(5a) conditioning (1a)
cut voltage= ni-mh .9v,ni-cd .1v
w/ box
Integy DCX 3000 Maintenace zapper P5,500 only neg
w/ box
Speed motor lab P3,000 only neg
input voltage=7.2v-13v(min 12amp)
output voltage=0v-4.5v for 7.2v input
0v-7.2v for 12v input
output current=10amp(+/- 10%)
w/ box
Txt me 0917-700-1610
items are in Davao
cell= 1,3,4,6 cell
w/ box
w/ box
w/ box
items are in Davao
For Sale! Slightly used(very fresh),
2 units
X-ray m-18
w/ aluminum(blue)motor mount
w/graupner speed big block motor
w/ aluminum(blue)front CVD
w/ futaba s3003 servo
w/ box,manual,and ferrari body
P5,500 each neg
1 unit HPI micro RS4
w/ aluminum(purple)universal shaft
w/ aluminum(purple)steering knuckles
w/ stock motor and body
w/ box and manual
P4,000 only neg
1 pc LRP Quantum(micro)competition 2 ESC
for 1/18th scale P4,000 only neg
txt lang po.0917-700-1610
Items are in Davao
2 units
X-ray m-18
P5,500 each neg
w/ box and manual
P4,000 only neg
Items are in Davao
tahimik?
bakit kaya nananahimik ang mga truckista? may binabalak ba? hmmmm.....lets see! parang nakakamoy ako ng endurance race eh! heheheheh!
HPI Purple Ribbed Pipe with Manifold and HPI Purple Coupling P2000
-very, very fresh
-no dent
-no scratches
-perfect for savage
Bnew O.S. .12 CVR P6500
Bnew O.S. .18 CVR P7500
09205365723
-very, very fresh
-no dent
-no scratches
-perfect for savage
09205365723
