View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
PORTER 4 SALE
PILATUS HIMALAYA PORTER PLUS ANOTHER KIT (BALSA)
WITH PLANS....PLUS BNEW FP.15 OS ENGINE
GET ALL FOR 5,000
09178224217 / 09228224217
[IMG][/IMG]
[IMG][/IMG]
GET ALL FOR 5,000
[IMG][/IMG]
[IMG][/IMG]
PORTER
SIRS,
PLEASE CHECK MY POST SA FOR SALE THREAD.
PILATUS PORTER WITH EXTRA KIT AND PLANS PLUS BNEW OS FP.15 ENGINE.
5,000 NALANG PO. BAKA MAY INTERESADO SA INYO NG BAGONG PROJECT. THANKS.
FS Batteries
For Sale IB batteries:
1. Loose cell, assembled side by side, used less than 10 times,@p1300
IB3600 mAH, charge at 4300mAH, runtime under 22.5A discharge 600+sec
IB3600 mAH, charge at 4320mAH, runtime under 22.5A discharge 608+sec
DATA GAINED USING TURBO35GFX, CHARGED AT 5A, DISC [email protected]
2. SMC IB3800mAH, matched, assembled side by side, brand new, p2500
spec:1.173V, IR2.2, 1.506PV, 407secs at 35A
All with bullet connector.
Interested party kindly call or text me at 09162537217 thanks for looking.
FS Items
1. Brand new Futaba 9254 digital high speed servo for heli`s tail @p5k
2. Brand new Trinity tire warmer (purple) @ p2k
3. Brand new Aplus li-poly 11.1volt, 2250maH, 16C 2pcs available @p4k each
4. Brand new Landing skid for TREX (unbreakable nylon), black, p400
5. Brand new JR micro servo for micro heli, analog, p1.5k
For your inquiry kindly text or call me at 09162537217 thanks
Model Avionics Optical Helicopter Tachometer (2800rpm)
For Sale:
Don't bust your chops nor your fingers from trying to measure your heli's headspeed using an airplane tach.. Measure your headspeed from a safe distance with this very useful tachometer. Specially for Nitro heli's where headspeed is critical to having a great performing machine. This unit can measure up to 2800rpm. It is very capable of measuring even higher headspeed for electric helis (Trex, zoom, Ark450). This light and compact unit runs on a 9 volt battery conveniently stowed in its back compartment.
BNEW unit for only P4.5k
09178150520
09178150520
GP Cessna & Kyosho Soarus
Brand New Great Planes Cessna - P11500
SPECIFICATIONS
Wingspan: 65.5 in (1665 mm)
Wing Area: 589 sq in (38 dm2)
Weight: 6 lb (2.7 kg)
Wing Loading: 23.5 oz/sq ft (71 g/dm2)
Fuselage Length:48 in (1219 mm)
Engine Required: 2-stroke .40-.51 cu in (6.5-8.5 cc) or 4-stroke .52 cu in (8.5 cc)
Radio Required:4-5 channel with 5 servos
Brand New O.S. .46 AX ABL with Muffler - P6500
Brand New Slimline Pitts Muffler O.S. .40-.46 SF/FX/AX - P2000
OS Engine and Pitts Muffler was intentionally for the Cessna Skylane for best fit and a scale look.
New Kyosho Soarus with extra fuselage - P5500
I have a bunch of props as well.. will post them soon.
Titan
09178150520
SPECIFICATIONS
Titan
09178150520
looking for
MR4TC BD Main Chassis Plate
BD-002G (2.5mm) or BD-002HG (3.0mm)
kahit used, wag lang laspag, baluktot, biyak o frayed.
0920.9245081
0920.9245081
for sale!!!!
AE TC4 rolling chassis 5K
Includes
Used body shell for bashing
Used slick tires
Used tamiya 11 turn super modified motor
Used trinity D5 motor
Used set of aluminum pinion gears
Kit manual
Futaba S303 std servo
1 set 3300 nmh sidexside deans connector.
Includes
Used slick tires
Kit manual
Junbantay sponsor mo nalang lahat!
seriously, doesnt matter naman, wag mo lang kami paasahin! hehehe!
edited
FOR SALE ULIT
These items are AGAIN ON SALE... Package 2500php (negotiable) for the two items.
OPEN FOR SWAPS: Any Futaba TX, RX (with xtals) and 2 servos or servo&esc combinations.
Call/Text at 09209234283
Reason for selling: Just got my NEW CHARGER from abroad and don't have any more use to these items... Used it only thrice since i bought it last Monday (10/23/06)
GWS MC2002 Link
Originally Posted by VOLUTE94
for sale
1. GWS mc 2002 Charger
-step up/down converter
- 4 to 12 cells of 50mah - 3000mah
nicad or nimh (rapid charge)
-automatic delta peak cutoff
-output port polarity & short protection
- charge current 0.25 - 6amp continuous
2. Power Supply/Converter
-3amps (capacity)
-input 110/220ac
-output 12volts DC
-3amps (capacity)
-input 110/220ac
-output 12volts DC
LF: TLO1 spares
looking for TLO1 spares, namely:
tierod, servo savers for futaba, servo holders and tie rod bolts
yung mga nasa pics ang kailangan ko.
PM na lang for offers.. thanks.
Originally Posted by nikkiesteban
posting for a friend
v1s w/ .12cvr
-2 speed
-tuned pipe
-4k
0927-919-9496
v1s w/ .12cvr
-2 speed
-tuned pipe
-4k
0927-919-9496
Originally Posted by backslash
bro im still thinking kung sa stock touring or 23T kung 23T kasi i need to buy a 23T motor or pag maaga nagkabigayan ng bonus bili ako TT01 para sa stock touring ako sasali hehehehehe when i test ur kit last sat napansin ko halos walang gaano pagkakaiba ang stock touring at 23T base on the track layout heehehe basta bahala na si or pag meron ulit naligaw na m chassis sa for sale thread
