View Poll Results: JPRaceway : On-road or Off-road?
On-Road
![](https://www.rctech.net/forum/images/polls/bar2-l.gif)
![](https://www.rctech.net/forum/images/polls/bar2.gif)
![](https://www.rctech.net/forum/images/polls/bar2-r.gif)
![](https://www.rctech.net/forum/clear.gif)
60
69.77%
Off-Road
![](https://www.rctech.net/forum/images/polls/bar3-l.gif)
![](https://www.rctech.net/forum/images/polls/bar3.gif)
![](https://www.rctech.net/forum/images/polls/bar3-r.gif)
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
For sale
2.5kneg
Gravel Hound df02 excellent condish with some extra parts
2 sets of bodies painted
1 set of 1/8 onroad tires mounted
lightweight regulated mini powersupply- found
2.5kneg
![flying G.E.O. is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Looking for HPI Rally or Super Nitro shocks set, Aluminum or plastic
![wheelspinner is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Originally Posted by Edgardo Jr
WOW! SI Mark naka PRO4 pa rin?!
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
![MFLORES is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
hey guys,
Just wanted to know if there is a local source here in the philipines for zenoah 62pu parts? Specifically the cylinder. I have a couple of 62pu motors which are used for a different application other than r/c airplanes, and would like to source spares that i can cut for my hks. I have all the other stuff like spare pistons and stuff.
Here is what mine looks like after the modifications. Im sure this motor on a airplane will be faaaaast.
![GopedAsia is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Looking for aluminum threaded dampers for tamiya TT-01 chasis and .12 secondhand engine ung good compression pa at mura lang.
Txt 0917-2538541 or PM
![Stpaul is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Originally Posted by MFLORES
I just sold the PRO4 today! ![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
Cyclone kid ka na rin ba?
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
![Nicadrauspro4 is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
hehehehhe! wala ako kinalaman sa pagdating ng bagyo!
See you guys round 8 Thursday November 2, as announced by Geetoo. (better than 31
Nako Cyclone boy na din si Mflores!!!!
![weird](https://www.rctech.net/forum/classic_images/smilies/weird.gif)
![m i g v e a is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Hello to RC flyers I have a brand new in box Vintage K&B model engine no.8380 which can be used for airplane or car with the factory muffler size .21 wrapped in the original foam with the original diagrams! If interested please contact me at 0927-996-9175 Alexander
![porsche boy is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Mflores: Wag hihingi ng setup kay Migs sigurado handling nyan understeer na oversteer yan.
Migs: You didnt offer eggs today. Instead you did it the other way around daw sabi ni Mark. Peace!
Nicadraus: Forever pro4 din ako...I built a Cyclone just to promote it. The way it looks I love both kits.
Bantay: Wala pa nag confirm for Cebu maaga pa masyado para dun but definitely I go every year walang paltos! we have to worry about the Thailand trip muna before anything else.
BDC: Diba okay din yun? F1 style so you must have a plan for qualifying. Either 1-4 batts change siguro.
![Ha!](https://www.rctech.net/forum/classic_images/smilies/ha.gif)
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
![Geetoo is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Check out his Pro4
Used during a Holoween Race at Cleveland, Ohio
Talo Pro4 mo Bantay
Talo Pro4 mo Bantay
![](http://i27.photobucket.com/albums/c187/Geetoo/Pro4X.jpg)
Originally Posted by Geetoo
Check out his Pro4
Talo Pro4 mo Bantay
Talo Pro4 mo Bantay
Kaya lang from the picture, dami pa sya kulang... Ako naka Twister ESC, Slim Upper deck, Carbon Shaft, Delrin Outdrives saka All alluminum in other parts.
WAAAA! courtesy ni Botchok po yun... Sya nag turo sakin pagandahin Pro4 ko. kailangan gwapo Auto ... di bale nang pangit Driving... Gulatan naman sa Tracks eh... HEHEHEHE.
Share ko muna yung trip ko sa ngayon.
![junbantay is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
Hobao GPX4 = 7k
almost brand new condition w aluminum engine support(yung sa side) and aluminum wheel hex. Plus newly replaced light weight chassis 4mm slightly used. The kit is almost brand new condition except for the spur gear and some minor scratches...
pls text 09209180395
![jonp is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
These items are AGAIN ON SALE... Package 2500php for the two items.
Call/Text at 09209234283
Reason for selling: Just got my NEW CHARGER from abroad and don't have any more use to these items... Used it only thrice since i bought it last Monday (10/23/06)
Originally Posted by VOLUTE94
for sale
1. GWS mc 2002 Charger
-step up/down converter
- 4 to 12 cells of 50mah - 3000mah
nicad or nimh (rapid charge)
-automatic delta peak cutoff
-output port polarity & short protection
- charge current 0.25 - 6amp continuous
2.2k
2. Power Supply/Converter
-3amps (capacity)
-input 110/220ac
-output 12volts DC
500 only
2.2k
-3amps (capacity)
-input 110/220ac
-output 12volts DC
500 only
![petee is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
M looking for a 2 CH transmitter stick or pistol type am lang.
Unit must interface with futaba RX
Also 75mhz fm RX that will interface with a futaba transmitter(tX)
Mura lang ha. Wala budget
Seller must be willing to ship to cebu. I will pay for shipping
09177178268
09177178268
![funprise is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Trader Rating: 20 (100%+)
Originally Posted by eacy2c
I'm selling the following items:
GT7 - 3.5K
GP3300 - Php 500/each (4 packs good numbers/side by side config)
Futaba 9402 - 2.0K SOLD
Pics to be posted
GT7 - 3.5K
Pics to be posted
![leevanm is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
