View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
hi guys...
madalas ba kayo sa PS1? pwede makinood and possibly maki praktis? baguhan lang ako dito eh.
hi nyagi, please join us. 4 groups are playing at the PS1 every saturday: the grippers, drifters, monster truckers, and micro truckers. punta ka lang, dami naglalaro dun from morning till afternoon. see you there.
thanks oldskul!!!
will try to drop by to get tips muna. kulang pa ko ng charger, battery at xtal eh. what time ba usually nag start and till what time?
tanong din pala.. pwede ba ang tamiya charger sa mga GP chargers?
thanks!
thanks!
nyagi: usually may naglalaro na by 9am then pack up na kami by 4-5pm. did you mean "tamiya charger sa GP batteries"? It depends. if you have a tamiya charger for nicads only then you should have GP nicad batteries. but if you have GP Nimh batteries you should look for a better nimh charger. or it could go the other way; keep your tamiya charger and buy a tamiya nicad batteries like the 1700sp and the 2400sp nicad batteries. these batteries are durable and would better suit your needs as a beginner.
looking for!!!
4pcs. heavy duty universals for minizilla.....
txt me 09209622503
txt me 09209622503
Looking for: slightly used FUTABA 9351 high torque servo.
text me your offers at 09175345846.
FOR SALE: CORALLY RDX - EDIT: SOLD
- carbon fiber upper and lower deck, shock towers, front bumper brace, rear body post mounts, battery holder
- aluminum bulkheads, steering arms, rear knuckles, center pulleys/spur gear mount, rear CVD bones, threaded shocks, turnbuckles, clamping hex adapters, servo holders, front one-way and rear ball diff, c-hubs
- slightly used, nothing to replace, just add your electronics & rims/tires
FOR SALE!!!!!!!!!
FOR SALE!!!!!!!!!
NOVAROSSI L5 .12
-CRANKSHAFT WITH RTV
-BRAND NEW OUTER BEARING (THE SMALLER ONE NEAR THE FLYWHEEL)
-BRAND NEW CONNECTING ROD
-CLEANED AFTER EVERY LARO(NOT EVERY RACE)
7K!!!!!!!!
TEXT 09193793627
NOVAROSSI L5 .12
7K!!!!!!!!
TEXT 09193793627
Sale Sale Sale
For Sale MI2 Schumacher
-Rolling chassis
-Slightly Scratched Under Chassis
-Very Fresh
-Race Ready
-Tons of parts available at Xtreme Hobbies
-Comes with Some extra parts-Spool Gear,Knuckle Arms Left & Right,Belt,
Spur gear At marami pa !!!
-Full Ball Bearings
-With Tires & medium inserts For practice
-Body For Bashing & Racing Will do
-Torx Driver (tool)
-Box
-Manual
4k only Reserved
For Sale Brand New Yokomo Cgm Parts
MR-4TC SD
-Arms For Front or Rear SD-008
Php 280.00
-Front Gears For 1way SD-503
Php 200.00
-Rear Diff Gears SD-643
Php 200.00
-Carbide Ball Diffs. ZD-505T Can Be used for MR-4,RC-10TC3 Size 3/32
Php 580.00
-2 Hub Carriers SD-415
Php 325.00 Each
Get It All For 1.8K only Fix
HPI Threaded Shocks w/ Tuned Springs
-With Yellow Tamiya Race Tuned Springs
-Just Had it Re-Build
-Silicon Shock Oil 30 Weight
-No Leak
1.3k only Reserved
TLP Power Supply
-13.8V w/ over voltage protection
-15 Amps take current
-short circuit protector
-over heat protector
-with FAN
2.5k neg.
Txt Or Call 0906-3608404
-Rolling chassis
-Very Fresh
-Race Ready
-Full Ball Bearings
-Torx Driver (tool)
-Box
-Manual
4k only Reserved
MR-4TC SD
Php 280.00
Php 200.00
Php 200.00
Php 580.00
Php 325.00 Each
-No Leak
1.3k only Reserved
TLP Power Supply
-with FAN
2.5k neg.
F/S Thunder Tiger Raptor 90 v2
For Sale 90-class 3D Helicopter
Break-in Condition
Thunder Tiger Raptor 60 v2
11T Pinion Gear/Heavy Duty Clutch 90 Conversion
OS .91 C-Spec Pump version w/Bellwood Dual Glow Plug Head
C. Youngblood Muscle Pipe II
Carbon Graphite Baseplate
Futaba GY401 HH Gyro/S9254 Tail Servo
JR D559 Digital Servos/JR SPCM R900S Receiver
Throttle Jockey Pro Governor
Metal Tail Pitch Slider
Carbon Rear-mounted Servo Tray
Metal Washout Assembly
Header Tank
Requires main rotor blades
BEST BUY!!!!
Selling for – P70,000
Contact Joey – [email protected]
Break-in Condition
Header Tank
BEST BUY!!!!
NEW ARRIVALS!!!
TEAM NOVAK
HV MAXX BRUSHLESS SYSTEM - new version
GTB BRUSHLESS SYSTEM 4.5, 5.5, 6.5 and 7.5!!
CLEAR FANS FOR MOTORS/ESCS
BACK IN STOCK:
GTX
MEGA CAPACITORS
SUPER SCHOTTKY
and lots more!!!
come and visit us!!
TEAM NOVAK
BACK IN STOCK:
GTX
MEGA CAPACITORS
SUPER SCHOTTKY
and lots more!!!
come and visit us!!
For Sale Tamiya TG10 Mk1
Tamiya TG10 Mk1
With O.S. .12CVR, good comp,non pull start, barrel carb, slight mod to liner to free up rpms. Engine last started Early June before i ran out of Gas
Aftermarket 2-piece Large Blue Cylinder Head with Head Button (a la nova rossi)
adjustable universal engine mounts by GPM
Heavy Silicon oil on both front and rear diffs
no scratches on chassis
stock exhaust
2-speed
Rolling chassis only, no electronics
Subaru Impreza Bodyshell
Just needs a new fuel tank
Box, manual, some spares
Car is in running condition
Buyer assumes responsibility for tuning and etc.
NO hidden defects,just really needs a new tank
4.5k only Rush sale
09175200427
I can email pics if needed
Please, serious buyers only
Reason for selling: i have too many nitro cars and no time to maintain them, concentrating on new Business
stock exhaust
2-speed
4.5k only Rush sale
09175200427
FOR SALE OR SWAP:
G4EVO- 2 Gal. used with lots of K-Factory hop-ups. Comes with one-way and spool
RB 5 PORT RODY Version also 2 gal used.-SOLD
RB Turbo Manifold and PIPE No dents!
Universal Light Weight Starter box
Corally RDX latest version. FRESH! -SOLD
KO VFS1 ESC Carbon fiber casing -SOLD
Will give free motor when you get kit and ESC
WRX Sanwa servos 2 PCS -SOLD
9252 Futaba Servo - SOLD
9251 Hi speed Hi torque Futaba servo
Corally motor and battery case
Checkpoint Brushes
Text 0917-8255005 or PM me
Checkpoint Brushes
Looking for TT01 hopups:
TRF Threaded Shocks with YELLOW springs
Aluminum Steering Set
PM na lang po
PM na lang po
SALE
ALEX STINGER KIT w/ spare parts 6k fixed
HARA TWISTER 2 4K
Looking 4
any of this kit TRF415,MS,MSX
HRS 27mhz rx
must be in gud condition
reasonable price
sms 09275659650
HARA TWISTER 2 4K
Looking 4
HRS 27mhz rx
reasonable price
sms 09275659650
