Electric Touring / On-Road RC
#301
Originally posted by Baluga
Sorry did not get to race with you guys kanina, naubos yung dala namin batts. Kailangan ko din ng 220v outlet for soldering kasi kailangan pang itulak yung kotse ko para tumakbo.
this wed ulit, holiday naman, ps1 ulit
#302
Originally posted by marvi
sorry din sabi ko 11am, pero 12:30 na nakarating
#303
AYE!!!
the rc frequency is only temporary until at least majority of the guys have posted.
some threads can merge withother threads and for the weather update, why not some guys make it as their signature?
Non-RCstuff can be merge with RC Stuff onlyif being traded or swapped with an RC stuff.
#304
Re: Re: Re: Re: Grrrr!!!
Originally posted by Tommi Makkinen
ay. baka di lulusot yan kay rnold. sya yung big boss ng Tamiya series....
#305
ay!! este aye pala!!!!
keep it simple!!
keep it simple!!
#306
415
Labas na ba and Tamiya 415 dyan sa pinas ??
#310
Re: 2004 Tamiya Philippine Cup Rules Ver. 1.3
Revised as of Feb. 24, 2004
TAMIYA Philippine-CUP 2004
RACE REGULATIONS
General
1.Cars must be built with original Tamiya parts, strictly following the instructions provided with those parts.
2.All parts must be used as supplied in the package and/or cut as outlined. Changes, which modify the original appearance of the car, are not allowed. In the classes of GT-1, Stock Touring, TL-01 Spec, and M-Chassis, tires/wheels must stay within the width of the body of the car.
3.Crystal of radios must be changeable. A third crystal should be prepared.
4.Motors must be Tamiya brand. Refer to each category regulations regarding information about motors etc.
5.No tire performance enhancing materials are allowed.
6.Each qualifying race will be of 5 minutes duration plus the time to complete the last lap.
7.Only modifications outlined in the regulations are allowed.
8.Any other issues not clarified in the regulations shall be handled at the discretion of the race organizer.
Special Note: Regarding 49*** series parts, only the color version of SP/OP parts which are listed in the parts list are allowed.
CAR REGULATIONS of 4WD GT
1.Only the following chassis are permitted to be used in this class:
TA03F, TA03F Pro, TA03RS, TA03R, TA03FS, TA-04 PRO, TA04, TA04S, TA04SS, TA04R, TA04RR, TA04-TRF, TL01, TT-01, TB01, TB-02
2.Only Tamiya Made batteries of up to 3300mAh capacity can be used. Battery wires can be modified at the bottom of connector to accept other types of speed controller connectors. Wire length must exceed 3cm.
3.Only the following motors are permitted to be used in this class:
540 Motor
Sport-Tuned Motor,
Super Stock Type-R Motor,
Super Stock Type-S Motor (#49247)
Super Stock Type-T Motor,
Super Stock Type-RR (#49260)
Super Stock Type-RR/Gun Metal (#49288)
Dyna-Run Racing Stock
Dyna Run Super Touring
Super Modified Motor 11T
4.Motor brushes must be from Tamiya. Modifications such as slotting, serrating, etc. are prohibited.
5.Cars do not have to be equipped with cockpit detail or a driver figure.
6.Any attempt to modify or to influence the ability of the motor is not allowed. However, wires of speed controller can be soldered to motor.
7.Minimum permissible weight of car when ready to run is 1,500g.
8.Any parts from TRF414X, TRF414, TRF414M, TRF414M2, & TB-Evolution series are not permitted except those which are commonly used for TA-04 type kits and TB-02 chassis.
9.Clearance under main chassis parts must exceed 5mm before the race.
CAR REGULATIONS of FORMULA-1
1.Only the F201 Chassis is allowed in this class.
2.Only Tamiya Made batteries of up to 3300 mAh capacity can be used. Battery wires can be modified at the bottom of connector to accept other types of speed controller connectors. Wire length must exceed 3cm.
3.Only the following motors with up to 23T are permitted to be used in this class:
Sport-Tuned Motor
5.Any attempt to modify or to influence the ability of the motor is not allowed. However, wires of speed controller can be soldered to motor.
6.Cars must be equipped with a driver figure.
7.Minimum permissible weight of car when ready to run is 1,400g.
8.Clearance under main chassis parts must exceed 3 mm before the race.
CAR REGULATIONS of Stock Touring Class
1.Only the TL-01 and TT-01 chassis are permitted to be used in this class.
2.Only a 3 step mechanical speed controller is permitted to be used in this class.
3.Drivers are limited to Tamiya-Made batteries of up to 3300mAh capacity only. No modifications to the battery wires or connectors are allowed.
4.Standard Johnson 2-vent RS-540 Motors must be used. Drivers must use the motors as provided including wires. Any attempt to modify or to influence the ability of the motor is not allowed.
5.Cars do not have to be equipped with cockpit detail and/or a driver figure.
6.Minimum permissible weight of car when ready to run is 1500 g.
7.Clearance under main chassis parts must exceed 5mm before the race.
8.The ff. Bodyshells CANNOT be used:
Honda NSX JGTC
Nissan Skyline JGTC
Nissan R390
Toyota Supra
Mercedes Benz CLK-GTR
Ferrari 360 Modena
Chevrolet Corvette
HKS Altezza
9.Racers must use only DTM series bodies, other touring car bodies, or rally car bodies. The use of the Lightweight Rear Wing Set is prohibited.
10.Tamiya Hop-ups for the TL-01, TL-01LA, and TT-01 are allowed
Special Note: We will issue ASAP the gearing limits for stock touring class. TL-01 chassis will still be limited up to 19T pinion with TL-01 Speed tuned gear set. TT-01 gearing shall be updated at a later date.
CAR REGULATIONS of M-Chassis Class
1.Any Tamiya M-chassis car (M01, M02, M02-L, M03, M0-3L, M04L, M-04m) is allowed in the Philippine eliminations. But the M0-3, M-03L, M0-4L and M04m will be the only chassis allowed for the 2004 Tamiya Asia Cup.
2.Tamiya Hop-Ups allowed, no chassis lightening allowed.
3.A proper m-chassis body must be used with its proper chassis. I.E. (FWD front wheel drive body must be used with front-drive chassis. RWD rear wheel drive body must be used with rear wheel chassis)
4.Cars may run any Tamiya tires designed to fit the "M" chassis. The tires and wheels must conform to the scale look of the body. Running 26mm sedan wheels and tires on a Mini Cooper body would be an example of what wouldn't be allowed. The Porsche Boxster, Porsche 911, Mercedes SLK, BMW M Roadster and Honda S2000 may only use wheels and tires that are of the 26mm type. 24mm wheels and tires are not legal for the 2004 season. Using the smaller wheels on a M-04 or long wheeled base M-02L is not legal unless the body type warrants it.
5.Porsche Boxster, Porsche 911, Mercedes SLK, BMW M Roadster and Honda S2000 may not run extra wide or offset wheels.
6.Only the following motors with up to 23T are permitted to be used in this class:
Sport-Tuned Motor
7.Only Tamiya Made batteries of up to 3300 mAh capacity can be used. Battery wires can be modified at the bottom of connector to accept other types of speed controller connectors. Wire length must exceed 3cm.
8.Due to the recent amount of disparity among the different mini chassis types, the following gearing rule will be in effect for the 2004 season. Because the M-04 uses the bigger sedan tires and offers an overall gearing advantage compared to the older smaller tired minis, the M-04 will be restricted to the 17-tooth pinion as of the 2004 season.
The following is the maximum size gears that are allowed for each mini chassis type:
M0-4 with Sedan type tire: max pinion 17 tooth
M-04m (Alfa body only) with 60D tires: max pinion 19 tooth
M0-3 with 60D tires: max pinion 20 tooth
M0-1/2 with 60D tires: max pinion 20 tooth
M0-1/2 with 26MM sedan tires: max pinion 18 tooth
Running a M0-3 with sedan tires is not legal for 2004.
note: The TL-01 Spec class is intended for Novice drivers. Participants wishing to enter a spec type class that is of intermediate to expert ability should opt to enter the Stock Touring Class. It will be at the discretion of the Organizers to weed out drivers who are attempting to enter this class, that are of better ability, to bump them up to a different category.
CAR REGULATIONS of TL-01 Spec Class
1.TL01, TL-01 LA chassis kits only.
2.The Only Hop-Ups allowed are:
a. Tamiya plastic oil-filled shocks (50519, requires 2 sets)
b. Ball bearings
c. TL-01 Turnbuckle steering tie rod set (53300)
d. TL-01 long suspension arm set (53467) The sway bar set in this kit may not be used for Spec, but may be used for Stock Touring.
3.Only a 3 step mechanical speed controller is permitted to be used in this class.
4.Motor rules similar to Stock Touring class.
5.Battery rules similar to Stock Touring class.
6.Gear Ratio limits are identical to Stock touring class
7.You must run kit type tires (Racing Slicks {50454}, Racing Radials {50419}, Racing Semi Slick Tires {50810}
8.Any tire insert may be used.
Note: Updates and revisions shall still be forthcoming. But this is more or less the rules that we shall use for the 2004 season
RACE REGULATIONS
General
540 Motor
Sport-Tuned Motor,
Sport-Tuned Motor
Honda NSX JGTC
Nissan Skyline JGTC
Nissan R390
Toyota Supra
Ferrari 360 Modena
Chevrolet Corvette
HKS Altezza
Sport-Tuned Motor
b. Ball bearings
#312
Re: Re: 415
i believe lils here released 2 kits ng 415. pero apparently nabili agad coz di ko sya nakita agad e. wats up bro? wala pa in US?
Wala pa dito. Ewan ko kung bakit kami and pinakahuling makakakuha ang mga Japan R/C products. Parang mga late march or april pa ang release dito eh. HPI Pro4 nga 2 weeks ago lang lumabas eh. Lil's lang ba ang nagbebenta ng mga tamiya kits ??
#313
Re: Re: Re: Non-Pro Beginner
Originally posted by jojo
Sir Tambok thanks for the reply, Currently im using 20% nitro.
What brand of fuel you are using for your engines and how much nitro percentage?
#314
tamiya cup
t-mak, sir i have a tl-01 na kit but i've already changed the chasis into a lightweight one plus aluminum dampers na sya pwede pa ba sya isali sa tamiya cup o i have to changed it to its original chasis. i was supposed to race it in qc circle as a rally car but was not able to join any race there. thanks
#315
Newbie with TLO1
BLACKWRENCH; Bro, i have some advice for making your TLO1 a little more friendly on the Capitolyo track. First, if you are using a 240s Kyosho motor, please keep the timing at Zero (0)degrees, that will prevent overheating and premature battery dump as advancing timing also increases current consumption. Next, try using first the 21t pinion, this is the middle pinion and could balance the way your car accelerates and tops out on the straights. Third, bro, if your car flips, this means a suspension fix is in order, try to get oil shocks, unbelievably, Tamiya plastic CVA short shocks prove very reliable when assembled properly. Friction shocks just can't cut it if you use mod motors. Tires are a bit tricky with the TLO1, if your car is set up very low to the ground, by all means use type A slicks as they are very sticky. If you still want to use friction shocks, use type A's behind, stock slicks in front, this will cause your car to "push" a bit preventing
rollovers. Bro, i strongly suggest also using Deans plugs with your batts to esc connectors as i had a hard-headed friend who insisted on Tamiya plugs, we would subsequently spend half the afternoon trying to pry the fused ends of his plugs apart! Especially when using hot motors. I also run a TLO1 and it is a pretty good budget car, just needs some tweaking to get it set up right. Just my two cents worth. Hope this helps some. I've been doing RC cars for over twelve years now and i'm glad to be able to help in any way to you guys. Just keep on having fun!!! ... By the way, there's a group that plays in the Makati track at Park Square that runs only TLO1 cars, you might want to
check them out saturdays, they are all really cool guys and won't hesitate to help you out with your RC problems, me included.
