ORCA-RIDE BL Championship 2013
ORCA-RIDE BRUSHLESS CHAMPIONSHIP 2013
Dates:
APRIL 7th 2013 Titiwangsa
MAY 26th 2013 RC Planet SS19
AUGUST 18th 2013 Kota Raja
Classes: 1/10th Touring Car Class
Entry Fees:*
RM50.00 for Open Class (13.5T Turbo-Timing/Boosted )
RM50.00 for Intermediate Class (13.5T No-Boost)
RM70.00 for Novice Class (17.5 (Zero Timing)
RM40.00 for FF Class (13.5T No Boost)
RM40.00 for F1 Class (17.5T No Boost)
**Organiser reserve the right to cancel any class with less than 10 confirmed drivers.
R & R
ONLY 4 Wheel Drive CHASSIS ARE ALLOWED IN TOURING CAR CLASSES
ONLY WINGS WILL BE CHECKED DURING THE RACE
Open Class (13.5T Turbo-Timing/BOOSTED)*
1. Open motor, any brand of brushless 13.5T motor with IFMAR / ROAR / EFRA approval is allowed
2. In order to be eligible to race in this class, racers are required to use AT LEAST ONE of the following items from ORCA, preferbly all, in every run : -
a)ORCA electronics speed controller
b)ORCA batteries
c)ORCA motor
3. Total Minimum Weight allowed 1380g (Including transponder or personal transponder)
4.*Tires: RIDE Part No. 26010-S Tires ONLY (Pic of Tire as per below). 2 sets of Tires maximum would be allowed for 13.5T Turbo Timing class.
5. Any brand of battery type & capacity is permitted
- Limited to only 6 cells Ni-Cd/Ni-MH or 2 cell Lipo*
6. Any Brand of Brushless ESC are permitted, however NO REVERSE function is allowed during the RACE
7. Maximum no. of participant: 30
Open Class (13.5TNo-Boost)
2. In order to be eligible to race in the race, racers are required to use AT LEAST ONE of the following items from ORCA, preferbly all, in every run : -
b)ORCA batteries
c)ORCA motor
4.Tires: RIDE Part No. 26010-S Tires ONLY (Pic of Tire as per below). 2 sets of Tires maximum would be allowed for 13.5T Turbo Timing class.
6. . ESC must be on zero timing at all times during the race. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
- However NO REVERSE function is allowed during the RACE
Novice Class (17.5T Zero-timing/Blinky Class) HANDOUT MOTOR
1. Motor will be HAND OUT on RACE DAY ONLY, PHYSICAL TIMING ON THE MOTOR IS NOT ALLOWED.
2. In order to be eligible to race in Novice class, racers are required to use at least one of the following items from ORCA, preferbly all, in every run : -
b)ORCA batteries
4.Tires: RIDE Part No. 26010-S Tires ONLY (Pic of Tire As Per Below). 1 set of Tires maximum would be allowed for 17.5T Zero Timing class.
6. ESC must be on zero timing at all times during the race. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
7. Motor will be Handed out to racers on Race Day only
8. Motor's Physical Timing CANNOT BE ADJUSTED
9. MINIMUM & MAXIMUM RATIO OF BETWEEN 5.0 AND 5.3 MUST BE ADHERED TO
10. Maximum no. of participant: 20
OTHER CLASSES
FF Class (13.5T No-Boost)
2. In order to be eligible to race in the race, ONLY FRONT WHEEL DRIVE, FRONT MOTOR MOUNTED CHASSIS ARE ALLOWED
3. No Touring Car or GT type body shell is allowed for this class
4. Total Minimum Weight allowed 1380g (Including transponder or personal transponder)
5.Tires: RIDE Part No. 26010-S Tires ONLY (Pic of Tire as per below). 2 sets of Tires maximum would be allowed for 13.5T Turbo Timing class.
6. Any brand of battery type & capacity is permitted
7. ESC must be on zero timing at all times during the race. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
8. Maximum no. of participant: 30
RACE FORMAT FOR CLASSES ABOVE:
PRE-QUALIFYING: 3min Run (Best Single Lap to be Use for Qualifying Placement)
QUALIFYING : 3 Heats (Best 1 of 3) 5 min each
FINALS : (5min each)
- A Main: 3 rounds
- B Main: 1 rounds
- C Main: 1 rounds
TIRES FOR ALL CLASSES ABOVE ARE AS BELOW:
F1 Class (17.5T No-Boost)
1. ONLY Formula 1 Body Shell are allowed. No Cutom home made wings allowed.
2. Chassis must be Formula One type eq: TAMIYA F104, HPI F TEN .etc
- Two (2) wheel drives (rear only) is allowed.
- Solid axle drive system. Full independent rear suspension system not allowed.
- Option parts that made for that model can be used.
3. Open motor, any brand of brushless 17.5T motor with IFMAR / ROAR / EFRA approval is allowed
4. ESC must be on zero timing at all times during the race. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
6. Only the following tires are allowed for F1 Class
7. Only 1 set of tire per race.
8. Minimum Weight: 1100g with transponder
9. Personal Transponder is needed. No transponder would be available for this class.
10. Race Format:
- 3 Rounds of Heats (5min)
- Best round to be used for Placement on the Grid in the Finals
- 2 Heats of 10min Final for ALL DRIVERS.
Final result based on best run. In the event of a tie on points, lap numbers, total time, fatest lap would be used as a tie break in the order listed.
APPROVED ESC LIST FOR ZERO TIMING:
BRAND * MODEL * SOFTWARE VERSION*
1) ORCA VX Ver. 2/2.2/3.0
2) ORCA VTC MK2 Ver. 2/2.2/3.0
3) ORCA VC4 Ver 2/2.2/3.0
5) ORCA Silver Drift Spec Ver 2.2/3.0
6) ORCA Spark Ver 2/3
7) ORCA 4X
8) ORCA 6X
9) CASTLE CREATIONS MAMBA MAX PRO 1.26 Must be indicated by Zero Timing indicator
10) KO PROPO VFS-1 BMC 1.5 Must be indicated by Zero Timing indicator
11) LOSI 1/10th Xcelorin Brushless ESC Must be indicated by Zero Timing indicator
12) LRP SXX STOCK SPEC Must be indicated by Zero Timing indicator
13) SPEED PASSION GT-LPF 2.0 ESC 508 Must be indicated by Zero Timing indicator
14) SPEED PASSION GT-PRO 2.0 ESC 508 Must be indicated by Zero Timing indicator
15) NOVAK GTB Spektrum
16) NOVAK GTB
17) TEKIN RS Version 212 Must be indicated by Zero Timing indicator
18) TEKIN RS PRO Version 212 Must be indicated by Zero Timing indicator
19) Hobbywing XERUN Xtreme Stock 508
20) Hobbywing XERUN 60A/120A 508
21) GM Genius 120/150/75/90 V13.0
22) Hobbywing Justock Club Spec
23) Viper VTX10 ver A19
24) Team Powers XPS Pro v1.1
25) Dualsky XT550TF
26) Dualsky XT850TF
27) Dualsky XT870TF
28) Speedpassion Reventon S
29) Speedpassion Reventon R
30) Speedpassion Reventon Pro
31) Hobbywing Xerun V3.0 / V3.1
32) Speedpassion Cirtix Stock Club Race
Zero Timing Indicator is a blinking light that will blink when the ESC is set to have 0 Deg Timing and Turbo Function Turned off.
For ESCs which are not listed above, please contact Hobby Haven to get more information.
MORE THAN RM3000 WORTH OF LUCKY DRAW PRIZES TO BE GIVEN OUT AT THE YEAR END !!!
Dates:
Entry Fees:*
R & R
b)ORCA batteries
c)ORCA motor
b)ORCA batteries
c)ORCA motor
b)ORCA batteries
OTHER CLASSES
- A Main: 3 rounds
- B Main: 1 rounds
- C Main: 1 rounds
10. Race Format:
7) ORCA 4X
8) ORCA 6X
16) NOVAK GTB
25) Dualsky XT550TF
26) Dualsky XT850TF
27) Dualsky XT870TF
The track layout for the race would be KLGP layout. We will post at a later date for the layout in diagram.
Sorry for the inconvenience.
13.5T Boosted:
1) Michael Lo / VBC Wildfire / 2.4 / PT****** / Team VBC ORCA
2) Jacky Siow / Xray T4 / 2.4 / PT****** / Team Xray ORCA
3) Azri Amri / VBC Wildfire / 2.4 / PT****** / Team VBC ORCA
4) Siow WoonFong / Sakura XI / 2.4 / PT****** / Team Sakura ORCA
5) Wong KokWai / VBC Wildfire / 2.4 / PT****** / Team VBC
6) Max Teo / VBC Wildfire / 2.4 / PT****** / Team Cheras
7) Lim EuKeong / VBC Wildfire / 2.4 / PT****** / Team Cheras
8) Leonard Pong / VBC Wildfire / 2.4 / PT****** / Team VBC
9) Leonard Ong / VBC Wildfire / 2.4 / PT****** / Team VBC
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
17.5T No-Boost Handout (30 racers Max):
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
1) Michael Lo / VBC FF12 / 2.4 / PT****** / Team VBC ORCA
2) Leonard Pong / VBC FF12 / 2.4 / PT****** / Team VBC
3)
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
3)
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
13.5T Boosted:
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
3) Dino / TOP Sabre / 2.4 / PT****** /
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
13.5T Boosted:
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
1) Harith Hadzir / Mi4CX / 2.4 / PT xxxxxx / Selangor
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10
Elwyn,
I still have 2 sets o Ride 26010 from the Ride Cup in January. Can those be used or do I need the S variant? Also, can the TOP Sabre FD be used since it is a FF car but the motor sits behind the front axle?
Race Organizers,
Can the RIDE H1 Formula 1 tires be used? as most of the local F1 racers are still using them.
Hi Elwyn,
I have only two battery, an orca lipo battery and non orca lipo battery, can i use that non-orca battery after my orca battery was used?
Regards,
Mike
Regards,
Mike
After take into consideration that some racers still having the RIDE 26010 tires, thus, racer organizer will allow RIDE 26010 to be used ONLY in Round 1. But it is not allowed to use in Round 2 & 3.
About Top Sabre FD, yes, it can be used as it is a FF chassis.
Cheers
Elwyn
Yes, the RIDE Slick F1 Tires (Type H1 compound) is allowed to use. But only in round 1. The R1 tires must be used from round 2 onwards.
Elwyn
According to the R & R, the racers must have AT LEAST ONE ORCA products in every run. Inspection will be carried out after each run.
Thus, unless you have others ORCA product(s), otherwise, the non-Orca battery should not be used in your run after ORCA battery was used.
Elwyn
Hi Mike
Elwyn
Elwyn
I would like to race for 17.5t category, would the handout motor (assuming the handout motor is an orca) + orca battery is enough to be eligible?
in case how much is the hand-out motor?
Cheers,
Mike
13.5T Boosted:
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
1) SKng/F103/2.4/PT******
2)
3)
4)
5)
6)
7)
8)
9)
10
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
2)
3)
4)
5)
6)
7)
8)
9)
10
Yes, you are eligible.
Motor will be Handed out to racers on Race Day only, and need to be returned to the organiser after race completed.
Since the motor is a loan unit, you are not required to pay extra for the motor.
Also, please take note that :
1)Motor's Physical Timing CANNOT BE ADJUSTED
2)MINIMUM & MAXIMUM RATIO OF BETWEEN 5.0 AND 5.3 MUST BE ADHERED TO
Regards,
Elwyn Lee
13.5T Boosted:
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
2)
3)
4)
5)
6)
7)
8)
9)
10)
10)
13.5T No-Boost:
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
2)
3)
4)
5)
6)
7)
8)
9)
10)
FF 13.5T No-Boost:
4)
5)
6)
7)
8)
9)
10)
F1 17.5T No-Boost:
2)
3)
4)
5)
6)
7)
8)
9)
10)
