technical support and discuss for hobby wing product
#46
Shahrin,
Ai ya, I test at TT most of the time mah! As for MNC round 3, unless you have a remote controller where its signal can work all the way from the other side of Malaysia. Then can join race la. Sorry bro, me oversea during the period. Have an appointment with Mickey Mouse and Donald Duck.
#47
dissapointed
helo to all..
im really a newbie n still n always b learning...
nway,im not here to condemn HW bt it really disappointed with the Ezrun esc because 2 esc has been fried...
Story is, i had purchase the Ezrun 9T/3.5A BL combo set as my 1st brushless motor to my 1st 1/10 buggy...all new...sadly it fried not more den a week old...so with a open mind and da need fr speed,i bought a Ezrun 60A n was den fitted wit a Ezrun 5.5T shortly which also fried in less den a week...im really disappointed as my set-up was da same as da combo set...using only Lipo 2s/7.4V batt n nvr played in any wet condition..
set-up fr da exc was 2,3,4,6,5,2,7,1,5,1....
only about 2month in dis hobby im already w/o a esc
any 2nd-hand esc fr sale by any chance
#48
Hi all,
Been testing Hobby Wing Xerun 120A at Titiwangsa. Layout ran kampung, reverse kampung and novarossi cup layout.
Ratio used is 6.9
Motor used : LRP X12 10.5, 4200 kv, tested using Team Power motor tester.
ESC Software 518
Drag brake : 0
My esc setting are
#4:3
#9:4
#12:4
#13:6
#14:4
#15:5
Air Temp : 34C
Track Temp : 55-58C
Motor Temp after 5 min 30 sec is 88C.
Hope this info helps! Will update more once I try out new esc setting or motor.
Bye
Ratio used is 6.9
ESC Software 518
Drag brake : 0
My esc setting are
#4:3
#9:4
#12:4
#13:6
#14:4
#15:5
Air Temp : 34C
Track Temp : 55-58C
Bye
#49
#50
#51
GFT,
I also like to know who is someone ..........haaa haaaaaa
#52
#53
CK LOO,
Thanks sifu leong for sharing your setup and tips .......when you free yam cha lar before you go Disney Land
#54
xerun 120A came with 2 caps and been loaded with stock motor software... do we need more caps for mod motor software, for example 4.5t...?
#55
as i know fren suggest me upgrade more cap to my 60a extreme esc,it will have smoother run and good in brake,why not give a try,im goin to upgrade too.
#56
for me the current brake is good enough although not as grip as pro-spec... to me stronger brake will faster the wear of parts... and the power also damn good enough... juz need to know wether need to add more caps or not for mod motor... is it true more caps will give better brake? (never heard this before...)
#57
Is the Justock Club Spec ESC available locally? Might want to give it a try for the upcoming MNC. Anyone? Kindly PM me. Thanks!
#59
#60
