About HobbyWing
About HobbyWing
Model :XERUN-120A-SD (V2.1) Brushless ESC for 1/10 Car (Competitive Race)
1 Specification
1.1 Output: Continuous current 120A, burst current 760A.
1.2 Input: 4-9 cells NiMH/NiCd or 2-3 cells LiPo. Note1
1.3 BEC Output: 5.75V@3A linear mode built-in BEC.
1.4 Resistance: 0.0003 Ohm.
1.5 Motor Supported: Sensored brushless / Sensorless Brushless.
1.6 Suitable Brushless Motor:
With 2 cells Lipo or 4-6 cells NiMH, 1/10 on-road: >=3.5T, 1/10 off-road: >=5.5T
With 3 cells Lipo or 7-9 cells NiMH, 1/10 on-road: >=5.5T, 1/10 off-road: >=8.5T
1.7 Suitable Car:
1/10, 1/12 on-road or off-road cars / trucks for competition race.
1/10, 1/8 rock crawler.
1.8 Size: 43mm(L) * 36mm(W) * 33mm(H).
1.9 Weight: 105g
Note1:
For 4-6 cells NiMH or 2 cells Lipo: You need not change the cooling fan coming with the ESC;
For 7-9 cells NiMH or 3 cells Lipo: You must change the standard cooling fan because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+6V)
2 Features
2.1 Compatible with all sonsorless brushless motors and most of sensored brushless motors such as LRP, Novak, Orion, Feigao, etc.
2.2 Seamlessly change to sensorless working mode when the sensor cable is broken.
2.3 Lithium battery and NiMH battery supported.
2.4 Excellent start-up, acceleration and linearity features.
2.5 Firmware can be upgraded through an USB adapter on the Advanced Professional LCD Program Box (Optional equipment).
2.6 User programmable. Easily programmed with only one button on the ESC and compatible with the Digital LEDs Program Card and the Advanced Professional LCD Program Box.
cheap and competitive !
For prostock racing 10.5T/11.5T use 508stock software. This software with turbo function .
A Lot of stories in here :
http://www.rctech.net/forum/electric...-software.html
Top notch stuff at a very competitive price...
Absolutely would recommend this to anyone!
Programmable...
Updatable...
No need to send back to manufacturer for reprograamming...
Runs cool...
Good support on settings and troubleshooting in RC Tech Main Forum
Programmable...
Updatable...
Runs cool...
would this esc keep up with the like of GM's and TEKIN????
Yes why not?
goto this link and read from first to last page then you can make conclusion.
For me already make the conclusion.
1 Specification
1.7 Suitable Car:
1.9 Weight: 105g
Note1:
2 Features
Who is the distributor for Malaysia????
radical
aihhh u also wana play ep kah..........sure boh fren ....haha welcome ep world pls contact alex ng for further infor
Cheerrsssssssss
Cheerrsssssssss
This Advanced Program Box is used to set the programmable parameters of brushless ESC, it has a 16*2 characters LCD (Liquid Crystal Display) to get a friendly user interface, so you can set the programmable parameters very easily. It is pocket-sized, so you can bring it to the racing or flying field conveniently.
This program card is suitable for the following ESCs:
1. XERUN Series Car ESC (Version 2.0)
2. EZRUN Series Car ESC (Version 2.0)
3. PLATINUM Series Helicopter/Aircraft ESC
1 Working Mode
1.1 Working as an individual device to set the ESC, the value of each parameter is displayed on its own LCD.
1.2 Working as an USB adapter to link the ESC with a PC, and the user can update the firmware of the ESC or set the ESC by the special application software on PC.
2 Specifications
2.1 Size: 90mm (L) * 51mm (W) * 17mm (H)
2.2 Weight: 84g.
2.3 Input Voltage: 4.8-6V (If the ESC hasn’t a built-in BEC, you must use an additional battery pack to supply the program box)
3 Programmable Items
A) The programmable items for the CAR ESC are:
3.1 Running Mode
3.2 Drag Brake Force
3.3 Low Voltage Cut-Off Threshold
3.4 Start Mode
3.5 Maximum Brake Force
3.6 Maximum Reverse Force
3.7 Initial Brake Force
3.8 Throttle Neutral Range
3.9 Timing
3.10 Over-Heat Protection
3.11 Motor Rotation
3.12 Lipo Cells
B) The programmable items for the AIRCRAFT AND HELICOPTER ESC are:
3.1 Brake Setting
3.2 Battery Type
3.3 Low Voltage Protection Mode (Cutoff Mode)
3.4 Low Voltage Protection Threshold (Cutoff Threshold)
3.5 Start Mode
3.6 Timing
3.7 Governor Mode
3.8 Motor Type
3.9 PWM Frequency
3.10 Built-In BEC Output
3.11 Motor Load
3.12 Lipo Cells
1 Specification
1.1 Capacity: 330uF*4.
1.2 Voltage: 16V.
1.3 Impedance: 0.002 ohm
1.4 Ripple Current Endurance: 24 Amp
1.5 Size: 42mm(L) * 10mm(W) * 15mm(H).
1.6 Suitable ESC: Xerun series Car ESC
2 Features
Super low impedance, low heat emition, the start can be more powerful.
Compared with the capacitors module of a world-famous car ESC
Impedance : 0.002 ohm
Ripple current endurance: 24 Amp
With its excellent "Ripple Current Endurance", the interference caused by the quick switch on/off of the MOSFETs is observably decreased, so the power supply system can be more pure, and the whole brushless system is more steady.
Small size and light weight to make the installation more convenient.
For those who use Hobby Wing esc if u want to improve ur acceleration and braking u may test the super capacitor
Hi guys new Application software already release. U can download at here
http://www.hobbywing.com/upload/soft....62_101106.rar
