ORCA BL Championship
Dear Drivers,
We are pleased to announce the 1st round of ORCA BL Championship.
Date: 13th June 2010 (Sunday)
Venue: SS19 Planet Speedway
Class: (a) 1/10th Touring Car; (b) Mini 2WD; (c) Mini 4WD
Entry Fees: RM50 for Touring class; RM30 for Mini 2WD & 4WD
* (i) For Class (a), ORCA Brushless motor will be on "hand-out" basis;
(ii) For Class (b) and (c), motors will be opened to any brand of Brushless motors with the limit of 17.5T maximum. Any higher turn of BL motors are allowed.
(iii) for all classes, ESC will be controlled at 0 timing, 0 Turbo settings. List of approved ESC will be posted. (refer to the new ROAR rules on ESC)
Detailed R&R will be posted very soon.
There will be limited seats available due to the number of handout motors on hand. Only 30 seats are available for Touring cars.
Thanks for your kind attention. Please consider to join us for the event. Have a great day.
ORCA SSBL AND MINI CLASS Rules and regulation:
Venue - RCP SS19 Speedway, Subang Jaya
Date - Sunday, 13th June 2010
Race Format - 3 Heats and 1 Final
Rules and Regulation (Version 1.2)
* This Rules & Regulation is subject to change and will be updated from time to time. Refer to the latest version.
Open Class
1. Handout ORCA Q 17.5T motor
- Will be handed out on the race day and to be returned to the organiser after the race on the same day. Failure to do so will incur penalty charges.
2. Total Minimum Weight allowed – 1420g (Including transponder)
3. Any brand of tires are allowed. Must be rubber based. Both Slick and Grooved allowed.
- Only 1 set of tires per Round allowed
4. Any brand of battery type & capacity is permitted
- Limited to only 6 cells Ni-Cd/Ni-MH or 2 cell Lipo
5. Any Brand of Brushless ESC are permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator . (Pls refer to the bottom for the list of approved ESCs)
- However NO REVERSE function is allowed during RACE
6. Body Shell: any types of 1/10th Touring Body (190mm) are allowed.
7. Wheels and Tires: Open to all types of Wheels and Rubber Tires.
What's not allowed?
1) Motor cannot be disassembled or tampered in any manner
APPROVED ESC LIST FOR ZERO TIMING INDICATOR:
BRAND MODEL SOFTWARE
VERSION
1) CASTLE CREATIONS MAMBA MAX PRO 1.26 Must be indicated by Zero Timing indicator
2) KO PROPO VFS-1 BMC 1.5 Must be indicated by Zero Timing indicator
3) LOSI 1/10th Xcelorin Brushless ESC Must be indicated by Zero Timing indicator
4) LRP SXX STOCK SPEC Must be indicated by Zero Timing indicator
5) SPEED PASSION GT-LPF 2.0 ESC 508 Must be indicated by Zero Timing indicator
6) SPEED PASSION GT-PRO 2.0 ESC 508 Must be indicated by Zero Timing indicator
7) NOVAK GTB Spektrum
8) NOVAK GTB
9) TEKIN RS 208 Must be indicated by Zero Timing indicator
10) TEKIN RS PRO 208 Must be indicated by Zero Timing indicator
11) ORCA VRITRA TC PRO SPEC Must be indicated by Zero Timing indicator
12) ORCA VRITRA VC4 PRO Must be indicated by Zero Timing indicator
13) ORCA Q 4X
14) ORCA Q 6X
*Zero Timing Indicator is a blinking light that will blink when the ESC is set to have 0Deg Timing and Turbo Function Turned off.
For ESCs which are not listed above, please contact Hobby Haven to get more information.
MINI 2WD / 4WD Class
1. ONLY 17.5T Brushless Motor will be allowed
(Any brand is allowed)
2. Total Minimum Weight allowed – 1220g Mini 2WD (Including transponder); 1320g Mini 4WD (Including transponder)
- Only 1 set of tires per Race allowed
5. Any Brand of Brushless ESC is permitted, provided it has the ROAR initiated Blinking Zero Timing Indicator as there will be no timing advance allowed on the ESC. (Pls refer to the bottom for the list of approved ESCs, if your ESC is not listed, please contact Hobby Haven for further clarification)
6. Only High Roof body shell is allowed (2WD). For 4WD class, any Sedan type body shell is allowed.
7. Wheel and Tires: Open to all types of wheel and RUBBER tires.
8. Only 1/10 Mini chassis is permitted, irregardless of brand.
9. Maximum Ratio Allowed for Mini 2WD Class is 5.20.
Open Class
What's not allowed?
VERSION
8) NOVAK GTB
13) ORCA Q 4X
14) ORCA Q 6X
Participants List:
Touring Car
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
SS19 track traction "yilek" lor.
old-man,
How fast do you think a 17.5T BL motor with no timing can go? Ok, its faster than a 48T brushed motor, but not too fast that it can break traction at SS19.
Furthermore, you know we are living in this day and age where we have chemicals to spray on the track surface. And rest assured Mr Suah will make sure he sprays it twice just for you.
Happy RCing.
p.s. We have ran the 48T at 3.1 ratio, yes its not that fast, but I am quite the 17.5T BL are not that much faster even if you are running it at about 4.0 ratio and we can hear our tires screeching around corners, ala TITC, remember?
Happy RCing.
Participants List:
Touring Car
1. Max Teo/416X/2.4/PT ******
2. Keong/416X/27Mhz/PT ******
3. Joe Cheah/Mi4/2.4/PT ******
4. Thomas Teo/416WE/2.4/PT ******
5. Michael Lo/Mi4/2.4/PT 9631631
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
1. Michael Lo/A210SS/2.4/PT 9631631
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
old-man,
Happy RCing.
Happy RCing.
articipants List:
Touring Car
6. Amir/BD5/2.4/ No PT
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
6. Norazam / 416x/ 2.4 / PT 7628137
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
2. Norazam / Square / 2.4 / PT 6000513
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
7. Halim Hafni / 416X / 2.4 / PT 7588705
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
7. Norazam / 416x/ 2.4 / PT 7628137
8. Halim Hafni / 416X / 2.4 / PT 7588705
9. Shahrin / 416X / 2.4 / PT 2857931
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
10. Phang / T3 / 2.4 / No PT
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
11. Shem/Sakura Zero/2.4/PT 7376694
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
1. Daryl Ngai/X-Evo/2.4/PT TBA
2. Anthony Wee/X-Evo/TBA/PT TBA
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
3. Anthony Wee/Fujin 211GO/TBA/PT TB
4. Daryl Ngai/Fujin 211GO/2.4/TBA
5. Shem/Fujin 211go/2.4/PT 5834084
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Waaa Shem!!!
Sakura Zero wooooo!!
Very fast car!!
Very fast car!!
Participants List:
Touring Car
12. Jackie Siow/T3/2.4/PT ******
13. Siow WoonFoong/T3/2.4/PT *******
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Touring Car
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Participants List:
Touring Car
14. Elwyn Lee/ Yokomo BD5 / 40.835
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
Touring Car
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
Mini 2WD
3. John Toh/M05/2.4
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Mini 4WD
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
