MO3-M Gear Ratio
#16
MTX3-B,
When you use the speed gear set, you have to use other pinions to get the mesh, otherwise it doesn't work. Pinion size for 33T spur is 20, 22 or 24 and for 35T spur is 18, 20 or 22.
This will alter the FDR to as low as 4.24 or there abouts, when using the 33/24 combination.
You will know if someone has this gear set fitted, their mini will be way faster.
Apologies for bursting your bubble and your XL sheet data, but nice work anyway.
Regards,
Calvin.
Regards,
Calvin.
Thanks for pointing that out.
i havent tried fitting any of those speed gears into my M05 and obviously i havent read the 3Racing manual.
Amended the xls to incorporate the relevant changes.
#17
MTX3-B,
That's OK, I just wanted to help out. We have had a couple of guy's try them and yes you will know if they are using a larger pinion because of the speed. But you can fit a 20 Tooth pinion and run it in a different hole, so for Teching at race days, you need to be observant.
The chart looks better, I have even taken a copy. Have a great day.
Regards,
Calvin.
Regards,
Calvin.
#18
MTX3-B,
Regards,
Calvin.
Regards,
Calvin.
Many thanks for the very informative info.
