Engine leaking
#31
Thanks "newbies TeeKuang" aka sifus and all gurus for answering my "real" newbie question. Really apprecite it. So, the conclusion saliva is the most effective method to know the engine temp and cheap is it? Will try to search on the net how this salive work. Thanks again
#32
teekuang ur just tooo humble liaw..
but really thx for ur tips..
here one more thing i ask.. my gasket just kon liaw~~ so i cut a leader beg to fix the gasket ~~ izzit can use ??
and u know ahh ~~ got 2 skrew to skrew my mainford but some time because of vibrating it would come out.. so i use treak lock... can it really lock it from come out ?? or any better way ?
#33
#34
one more thing, for new gasket, start the engine let it warm up play for few laps after that, you should re check/tighten the screw after engine cools down. because the gasket will settle down. after that, enjoy your RC!
#35
i wanted to try this but scared of something bad is going to happen. any one can confirm if its safe for the crank case?
#36
Ohh thx alot TeeKuang ~~
i got wat u mean liaw gonna buy today... ^^
erm one more thing ahh ~~ izzit very high RPM and the second gear change very very fast in highway does this cause the plug faliue easy ??
i planning to get a new stater box soon ~ any review on Thunder tiger starter box ? tat small small type de.. izzit enoug power to roll my flywheel ?? because my compression is damn kau kau ~~ even sometime only the battery week ahh it also can't start... <::::::: my old starter box..
#37
#38
yeap ~~ coz normally my plug will die.. after 5-6tank run... izzit normal ??
because i using GO plug.. <:::: taiwan plug.... #5 for 25% nitro fuel.. izzit match ??? but last time i use #8 OS plug b4 also... untill one gallon fuel also plug look spaking new... i got another extra #6 LRP plug also... it also can't last long like the OS plug... sooo izzit possible OS plug are more long lasting than other plug ?? hopefully that u knw wat i mean...
sorry my poor english but hope u understand..
^^ i have also already install the spring washer... hope that skrew will not felt out...
