Problems with my 1/10 "ride"
#61
Originally Posted by wandzul
yes linkage problem sbb dah altered.. and then the engine stalled bcos when braking, the air intake hole (tatau apename) was fully closed/too rich sampai engine stall, ye tak? so bukan ke tugas idle screw utk menahan lubang air intake tu drpd tertutup? so mcm mane? kindly pls explain..
tq
tq
becareful if you wana get the bicycle fingers,it may cause you fail to losck wit your 1.5mm stopper,unless you use bigger or look for smaller diam fingers..
#62
Originally Posted by MAVICXXX
linkage setting is 1 more important to justify braking power and throtle travel.which 1 should you check 1st?trotle or brake?if me..i will go on trotle 1st,release the brake stopper or loose it,the justify the trotle body linkage,set the spring stopper to set the trotle body travel,then set the fron linkage stopper,then you can set your brake linkage.
#63
Originally Posted by rizal_eg9
terima kasih cikgu.....
#64
aku nkg cari mp3 jalak lenteng pasni..
#65
aku rasa baik ko pergi tengok jangan pandang belakang......
#67
bang bang, sifu sifu~
thanks a lot... my braking linkage"makan" again~
here is my latest pic...(tapi ,yang tu besi bulat tu lama kelamaan akan terkeluar ke?)
#68
#69
Originally Posted by TeeKuang
I think better put some thread lock, so that it will stay on it's place.
sifu-sifu pls correct me if i'm wrong..
tq
#70
maybe thread lock boleh pakai.. boleh jugak kalau mau buat satu notch kat stick tu.. grind sikit jek bagi ade longkang sikit so stopper tu akan lebih kukuh kat situ..
tq
tq
after finish lrp race , will asking advice set my digi ser properly then only some thread loc ...
the next things , just fuel , foam , belt n pulley ...
#71
no thread lock 1st... u can see my servo still not change yet...
what is your problem now???linkage or brake fading???
#73
Originally Posted by pullstart
personal problem sifu rizal bloeh tolong saya solve tak??
#74
tan,
1st brake tak makan... friend kata tukar disk brake will ok... i rasa masih ada setting ke apa ke boleh buat selain $$$
2nd , abang MAVICXXX tengok gambar saya tu linkage terlebih fuel , buat cantik aja~
so cam tu la...
#75
tak laa, small problem aja...
so cam tu la...
so cam tu la...
First check the brake pad.....ensure it u pad still glued to the metal calliper...
second.....check itu pad punye play......ade 2 screws yang ikat itu pad....adjust the screw so that you have a correct fitting....tight but no drag.......
lepas tu baru masuk bab linkage ....ok tan.....next time if you catch us at the track.....just come by and say hi........kitorang punye muka aje kerek tapi hati baik.........
