HK Talk Version 1.1
Old 11-12-2001, 10:42 PM
  #2071
Manticore's Avatar
Thumbs down
Originally posted by dtm
No the servo is so quick it moves before you move your fingers!!
that's the problem with KO servos !!
Manticore is offline
Old 11-12-2001, 10:43 PM
  #2072
Manticore's Avatar
Thats when you go from a 2.6mm screw to a 3mm screw for Futabas, or a 12mm length screw to a 15mm length screw for KOs. So far no real complaints for EP. I find that the metal gears in my 9402 has quite a lot of backlash also.........
And don't forget most metal gear servos have one plastic gear in the system as a weak link!!! So if it breaks....it breaks.... regardless of metal or plastic!
the way to secure the output port of the servo gear is to use longer servo horn screws. I used to tap the original wood screw hold to 3mm for stronger connection
Old 11-12-2001, 10:55 PM
  #2073
Regional Moderator
disaster999's Avatar
Originally posted by Diva
How frequent do you put on and take off your horn? Frankly, I seldom do that. Even if your gears went worn, there are replacement parts out there. You can't expect everything went perfect without wearing in R/C. To me, I've tried 9402, 2000, 2015, 2143, 2144, etc., 2015 is always my pick for EP.
but doont you think that 0.05sec is a bit OVERKILL for the ep car??
disaster999 is offline
Old 11-12-2001, 10:56 PM
  #2074
Manticore's Avatar
well, do you need 0.05 second to turn your steering in a corner?? be realistic !! all of those spec is just selling point.
Old 11-12-2001, 11:00 PM
  #2075
dtm
dtm's Avatar
Probably.... but isn't a lot of RC stuff an overkill anyway!! Its still nice to have!!
dtm is offline
Old 11-12-2001, 11:06 PM
  #2076
Regional Moderator
hahah...thats right...those hardcore racing products for just for shows...hahah....
Old 11-12-2001, 11:20 PM
  #2077
Manticore's Avatar
well, 30 % of those are eye candies............
Old 11-12-2001, 11:42 PM
  #2078
ernestf's Avatar
Fai, i have bought the alloy batt hold down bar, 2.1mm upper deck and alloy shocks body (from square) to make my LE kit over $2,000. I think I will only get the alloy spur adapter then. Thanks for your advise ! Are u running the stock springs or what ?
ernestf is offline
Old 11-12-2001, 11:44 PM
  #2079
another HK pro3 owner... thats great ernestf
ME-student is offline
Old 11-12-2001, 11:54 PM
  #2080
ROBORAT's Avatar
does anyone know if there are other shops besides control centre and perfect grage that sells aftermarket pro3 parts like those by Square? does Jet Hobby have them? would you know if they have a website?
ROBORAT is offline
Old 11-12-2001, 11:56 PM
  #2081
ROBORAT's Avatar
what does the LE Pro3 come with??? does anyone care to share the specs?
ROBORAT is offline
Old 11-13-2001, 12:54 AM
  #2082
dtm
dtm's Avatar
Ernestf... are you going to make up 2 cars with your Pro 3 LE kit?!
dtm is offline
Old 11-13-2001, 12:56 AM
  #2083
dtm
dtm's Avatar
Theres actually not that many of them..... still too many Yok and TC3 owners!!!!
dtm is offline
Old 11-13-2001, 01:03 AM
  #2084
dtm: i know.. Pro3 is a good car, but needs tons of options.. i guess thats why nobody buy them. lot of HK guys own TC3? ididnt know that war..!
Old 11-13-2001, 01:39 AM
  #2085
ernestf's Avatar
me-student : i am one of those TC3 and Yoko owner too
ernestf is offline
