VBC D10
#286
Steering Hubs
Hi! I just started racing again after 10years and purchased a vbc d10. On practice i broke a steering hub(cross threaded on the screw). I replaced it with a new one a d did a race but it still stripped even though i didn't hit alot of things so I replaced it again and still did the same this time without hitting anything. It's only on the right steering hub that i am having issues with. Has anyone experienced this?
#287
You'll want to make sure that lower 4MM screw comes through the steering hub as far as possible without hitting the double universal axle.
#288
You'll want to use a longer 4mm screw through the Caster Block into the Steering block. Also be VERY careful not to over tighten the screw initially. With these high carbon plastics, once the thread breaks it's over.
#289
Replied to your PM sir. But yes, a longer screw will improve the durability greatly. I run on carpet, and the barriers don't move. Since changing that out, hits that would pull the screw out before now bounce the car off with no damage.
It's helped a lot to say the least.
Oh, and if you're running on carpet, I can help with setups. We're really dialing in the setups for black CRC Fastrack 2 carpet
#293
This car does not seem to have a lot of success... Are people still racing with?
#294
#295
Nothing special, it is hard to find some setup sheets for this car. We are racing here special conditions, sugar on track but no tyre prep, only Sweep 32. Any asphalt setup you could share?
I've seen huge differences between asphalt setups, especially around roll centers... And are you guys running diff/spool high or low? What does it change?
#296
#297
So what is going on with VBC. It has been very quiet, usually they are talking about their new car but I have not heard anything. I really like all of their cars and just hope this is the beginning of the end.
#298
There was some discussion about running the split mount in the f/r position.......after a lot of testing, I went back to the one piece mount. The split mounts made the car very inconsistent. On our test track this car had a couple issues which made it tough to tune for. Car has a big oversteer on exit and a push on power. The first thing that helped the car was going to a softer gear diff, 3-5k oil. On asphalt it would probably need something in the 1k range. The rest of my setup has some crazy things on it, but finally got a car I can drive again.
#299
Who else has tried putting d09 front suspension parts on their d10? How is the handling? I have a few spares from my d09 so gonna replace it(bought a d09 with spares)
Have no luck with the steering hubs on the d10. Tight carpet track. Very little hit and it breaks. I didn't overtighten it too.
#300
I've run it with the full D09 geometry. Interesting, the steering reaction is totally different. Mostly efficient on asphalt, no experience on carpet...
