Like Tree262Likes
Xray T4 18
    Hide Wikipost
Old 07-17-2018, 03:49 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Xray T4 18
Last edit by: R Dodge
Welcome to the XRAY T4'18 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time. Feel free to add anything you feel is useful to the community!
New for 2018:
Similar to 2017, the T4'18 kit comes available in the U.S. with either a Graphite chassis (Part no. XRA300024), or Aluminum Flex chassis (Part no. XRA300024A) along with all of the great features introduced last year. We recommend the Graphite chassis for starting on asphalt, and the Aluminum Flex for starting on carpet. The big changes for 2018 are much lower center of gravity, courtesy of the Ultra Low Profile (ULP) shocks/towers and narrower weight distribution by shifting the motor in towards the center-line of the car. In moving the motor closer to the center, the topdeck and layshaft bulkheads have been re-designed. Also new this year, the motor mount includes more holes which extend further toward the rear of the car to improve traction. With the new shorter shocks, the 2018 will use the same springs as previous T4 models.
What's NEW at T4 2018? Convert your '17 to '18 specs with these parts:
- NEW chassis plate (3 options to chose from, Graphite, Aluminum, Alum. Flex)
- NEW topdeck
- NEW ULP shocks (4mm shorter than 2017)
- NEW ULP shock towers (4mm shorter than 2017)
- NEW Motor mount (1mm narrower than 2017)
- NEW Motor mount plate
- NEW layshaft bulkheads
- NEW 51mm ECS ES driveshafts
301145 T4'18 CHASSIS 2.2MM GRAPHITE
301199 T4'18 UPPER DECK 2.0MM GRAPHITE
302084 ULP SHOCK TOWER FRONT 3.0MM GRAPHITE
303001-O T4'18 ALU LAYSHAFT BULKHEAD RIGHT - ORANGE
303002-O T4'18 ALU MOTOR MOUNT - ORANGE
303003-O T4'18 ALU MOTOR MOUNT PLATE - ORANGE
303085 ULP SHOCK TOWER REAR 3.0MM GRAPHITE
305221 ECS (ES) DRIVE SHAFT 51MM FOR 2MM PIN - HUDY SPRING STEEL(tm) (1)
305334 ECS ES (EXTRA STRONG) DRIVE SHAFT 51MM - HUDY SPRING STEEL(tm) - SET
308043-O ULP ALU SHOCK ADJUSTABLE NUT - ORANGE (2)
308308-O ULP ALU SHOCK ABSORBER-SET - ORANGE (2)
308324 ULP ALU SHOCK BODY (2)
308334 ULP COMPOSITE SHOCK PARTS
308354-O ULP ALU SHOCK CAP-NUT WITH VENT HOLE - ORANGE (2)
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Mastering the Sanwa M12S: Utilizing Exponential and RMode
How to mount weight on your chassis Part2
Mastering the Sanwa M12S: Utilizing TH-Hold
ULP Shock:
Building the new ULP Shock w/ Zero Rebound by Dominic Quek
Team driver Tim Wahl posted some very useful build tips for the T4'16 on Facebook as he worked through building a new kit. These tips will still apply on the current model.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
Center Brace:
The manual indicates using a 2mm shim under the center brace when attaching to the chassis plate. The gap is actually 3mm, so a 3mm shim should be used here.
Tuning Note:
On Carpet we have found that adding screws or doubling up the graphite brace will make the car react quicker to steering input, & change direction faster. Raising the graphite brace off of the aluminum bulkheads by placing a shim under it on the front and rear holes will reduce response. Using the tie-rod will reduce initial response to input, but will generate more in-corner traction or 'side-bite'. Using no brace will generate even more of this 'side-bite' but all of this is at the expense of corner speed. Best to use the tie-rod or no brace only in low-traction conditions. Additionally, the center brace increases forward traction, so removing it will potentially increase wheel-spin out of low speed corners.
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
ARS Tuning courtesy of Ed (TryHard):
If you set the ARS up with no shims under either inside or outside ball positions, it actually adds toe-in under compression, at around 1° at 5.2mm ride height (how much it adds depends how much the car compresses, obviously )
Adding shims reduces the amount added (1mm under one of the links gives about 0.5°), until the link has 2mm worth of shims (1mm either side, or 2mm on one side) makes the ARS neutral. Adding more shims then turns it into reducing toe in under compression.
Whilst that might sound a bit backwards, it's actually not quite as simple as it sounds. By having the links to add toe, you gain forward traction. Also consider as the car rolls, the inside wheel is in negative compression, and the outside in compression. So the inside is toe-ing out, and the outside toe-ing in, so the whole rear is then 'steering' in the direction of the turn. Obviously the inside wheel has a lot less influence than the outside as it's far less loaded, but the effect is still there.
Optional & Tuning Parts to consider:
XRA301146 T4'18 ALU CHASSIS 2.0MM - SWISS 7075 T6 **For very high traction** (Approx. 108g)
XRA301147 T4'18 ALU FLEX CHASSIS 2.0MM - SWISS 7075 T6 **For high traction** (Approx. 93g)
XRA301169 T4'18 UPPER DECK 1.6MM GRAPHITE
XRA302254 Composite Steering Block - Graphite
XRA302334 Aluminum C-Hub Block - Caster
0° - Orange **Only for ARS**
XRA302383 Composite C-Hub Right – 4
° - Graphite (ECS) **Not recommended for high traction**
XRA302384 Composite C-Hub Left – 4
XRA302711 Brass Front Lower 1-Piece Suspension Holder - Front - FF
XRA302803 1.3mm Front Anti-Roll Bar
XRA303360 Composite Upright 0° Outboard Toe-In - Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel **Highly recommend**
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA305352 Aluminum Wheel Hub - Offset
“+0.75mm” - Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308029 ULP ALU PROGRESSIVE SHOCK SYSTEM - SET (2) **Only for asphalt**
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Recent Setups:
7-Oct - Alexander Hagberg - IIC - High Traction Carpet - Mod Q2, P2
7-Oct - Craig Xavier - IIC - High Traction Carpet - SuperStock Q5, P5
Print Wikipost
Old 04-23-2018, 03:57 PM
  #676
Skiddins's Avatar
Originally Posted by Darrylt3to4e
Does anyone have any insight on if the 2019 car will be a T4, or a redesigned T5?
T4 - is sort of used as an acronym for Touring Car 4WD if I recall. So it will remain T4
NT1 is Nitro Touring 1/10 scale if I recall.
Etc
Skiddins is offline
Old 04-23-2018, 04:23 PM
  #677
mracer1's Avatar
Skiddins.... on my 18 t4 CF, I've got some high speed understeer (USGT) grey carpet, mostly stock suspension except for X-ray front progressive springs 2.3-2.6, 2.5 in rear, added a another 1/2 mil shim for ackerrman, would like the front tires to bite a bit harder? Have a frt. gear diff w/diff putty, 5K rear, stock sways, almost all screws down the centre (sans one), no CF centre brace... any thoughts? Bigger front sway, lay down front shocks another hole?
LMK
Cheers
Mike ;>)
mracer1 is offline
Old 04-23-2018, 04:43 PM
  #678
Trader Rating: 15 (100%+)
LMK
Cheers
Mike ;>)
Laying down front shocks will certainly help. Larger sway will not. You need to let us know what configuration your front suspension pills are oriented so we can determine your current roll center. if stock dead center, id drop them .5 at a time till you get your desired front traction. possibly even narrow the front track too. 2.6 in the rear would help too.
mracer1 likes this.
trigger is offline
Old 04-23-2018, 04:59 PM
  #679
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
How much are you guys cutting off the end of the shock shaft to get the "ideal" shock length?
Dan is offline
Old 04-23-2018, 06:08 PM
  #680
Etc
So, the Xray T3 was a Touring Car 3WD?
Slo_E4 and gigaplex like this.
mariob62 is offline
Old 04-23-2018, 06:21 PM
  #681
mracer1's Avatar
OK, front stock pills, will try .5 for this friday nite club race, also I think I only have one hole left to lay down the front shocks... Thanks Mike ;>)
mracer1 is offline
Old 04-23-2018, 08:41 PM
  #682
Riketsu's Avatar
Trader Rating: 34 (100%+)
The nomenclature and marketing strategy changed down the road. Hence why after XB9, they went back to XB8.
Many times, many factory racers have explained here and other threads that they won’t be in the near future a T5 due to their marketing strategy. They prefer to update the year and make small adjustments to an already working base.
It is was has been working for Xray and will continue the path until they find it no longer works for them.
Riketsu is offline
Old 04-23-2018, 09:51 PM
  #683
The comment was tongue in cheek.​​​ The other poster said T4 meant that it was a 4WD. The T4 designation has nothing to do with the number of wheels driven.
mariob62 is offline
Old 04-23-2018, 10:08 PM
  #684
mschumi101's Avatar
Trader Rating: 30 (100%+)
Well additionally in the past the model jumps were for large design changes. The original T4 was a very drastic departure from the T3, and so forth. While the T4'13 shares almost nothing with the new T4'18, it's more just a compounding of smaller changes and tweaks over the years, rather than one massive redesign. The car could currently be a T5, but there wasn't a very definite moment it departed from T4. Two largest changes to the T4 platform to me would be the suspension mounts between 13-14 and the ULP shocks on the 18. But I'm fine with keeping it as a T4 '20xx
Darrylt3to4e likes this.
mschumi101 is offline
Old 04-24-2018, 01:27 AM
  #685
Skiddins's Avatar
LMK
Cheers
Mike ;>)
As mentioned above by Trigger.
Also, what upper link shims are you running?
I would also remove some of the center line screws (motor mount plate I assume) and possibly just use the screw with nut.
Harder rear springs
I've never run USGT as such, so I don't know if there's anything specific for those tyres etc.
mracer1 likes this.
Skiddins is offline
Old 04-24-2018, 04:37 AM
  #686
Default New rear suspension arm holders
Has anyone tried the Xray new rear lower suspension arm holders (#303722, 303716, 303717)? Are they performing as advertised?
XrayAllDay1 is offline
Old 04-24-2018, 06:11 AM
  #687
Still quite a few months away, but what sort of changes - if any - would people like to see to the ‘19?
been a little while since any shots of actual race cars (as opposed to specific photo cars) with the shell off have been on social media or the like too - which *may* mean prototype stuff is being run.
For me;
- Still want the steering fixed. Hate the slop. Want to try the Lunsford screws hagberg has been using. But that won’t help the slop in the bridge
- Get rid of the floating steering from the kit. Having the floating “ears” on the servo plate just makes access harder. Not hard to fix with a dremel though!
- Need tape free battery mounts - or at the very least 7075it style where you don’t need to wrap tape under the chassis. So many people are making their own and numerous kits have this (good) feature standard. Time for Xray to get on board.
- adjustable body posts to the front. Hell, I’d be happy with different lower plastic bumper mounts or optional offset posts. Need a way to move our bodies forward/backward rather than owning multiples of the same body mounted differently. The rear posts are easy to move - just space them out. The front needs a little innovative thinking. Just as Mugen have with eccentric posts.
And.....
- Want to see a black racers edition. Celebrate 10yrs for Hagberg on the team! Chuck in his favourite options. To offset some of the extra cost of the black anodising and options, don’t worry about including any springs, sway bars, spur gear, oils/greases or any ARS plastics. Everyone serious has their own anyway. Could also do away with the factory screws to be honest. Never use them either!
an area I think could perhaps be looked at is the C hub - is the path VBC/Mugen have gone the way to go? Or is the chub still the superior solution?
cplus is offline
Old 04-24-2018, 07:39 AM
  #688
tbrymer's Avatar
For me;
And.....
I'd like to see a better designed center pully system. The current one tends to get slop quickly. Also, front spool outdrives as steel for kit would be better than the current ones. Shorten the shock shafts on the new socks so they don't bottom out.
tbrymer is offline
Old 04-24-2018, 09:09 AM
  #689
This is what I was talking about.
Long story short, my T4 2018 has a lot of hop ups. and I am thinking of building another one. But don't want to replace the hop ups if the car is changing drastically, (like when the T1FK became the T2, or T2 became the t3 or t3 became t4. I am talking about things like ceramic bearing kits. I will make due with what I have if it is changing. If ti is staying similar like it has for a few years now I will get new option parts for the 18. (which I would not expect to change if the car is staying a T4.) I guess I should have used the term "major changes" instead of T5
Darrylt3to4e is offline
Old 04-24-2018, 10:26 AM
  #690
Korey Harbke's Avatar
1.0-1.5mm is a good amount to trim off the shaft. Try an exposed shock shaft length of 8.5mm.
-Korey
Korey Harbke is offline
