Xray T4 18
#196
Aluminum adjustable body post stop
Anyone know what is the advantage of
having aluminum body post stops?
#198
Whilst the new shocks on my car definitely have slightly stiffer adjusters than previous cars, I'm not having the issues you've mentioned.
Not trying to be patronising, but have you tightened up the shock cap fully? The last few generations of shock have a lip to take the guess work out of how much you're compressing the bladder. When bleeding/building them it needs to be tight.
I also don't put any oil on the big o-ring itself, but I do lightly smear some over the threaded part of the shock body.
put the older collars on the new shock bodies and there is no problem at all.
So I am using the older collars at the moment as I can get to 5mm ride height with no problem
#199
Hi Damian, yep always fully tighten the cap fully, never had the problem before, also strange the problem occurs on both new and old shock bodies,
Old collars on new ULP shocks, simply ok.
New collars on new ULP shocks,simply not ok.
#200
Because they clearenced the new collars to sit higher for the longer springs so you would still have adjustments with the short shocks. Maybe I’m wrong but from reading that would be a logical reason
#202
Collars
If the collars were clearanced to overlap the top cap and that is allowing the o ring to slide up and out of the machined groove causing a bind it does make it a factor . I’m sure Drew or Ea could clear it up easy
#203
The new shock collars probably have a correctly machined thread, otherwise they would be stiff being wound in both directions.
If you want to test, try removing the o-ring from the adjuster and then try the collar, if it moves up and down fine then that isn't the issue.
Perhaps the new collars allow too much movement in the o-ring which can allow it to become partly trapped.
I ran my car yesterday, and while I do have the issue where the adjuster is tighter when being wound down, it all still works fine and I haven't managed to accidentally un-thread the shock body whilst adjusting it.
#204
For now, i use my T4 17 collars.
#206
Having taken some old and new adjusters apart, the O-ring (despite having the same part number) is 1mm on the '18, they are 1.5mm on the previous cars.
The metal on the adjusters themselves has exactly the same dimensions, except for it's depth, 4mm on the '18, 4.75mm on previous cars.
The slot for the O-ring has also been reduced for the '18, but I think this is the important part, the diameter of the hole at the top of the adjuster is still the same, 13.95mm
I think the new slimmer O-ring is more easily able to get caught in the gap that exists between the main upper hole and the shock body, with the 1.5mm rings this is far more difficult.
It has to be said that although the first shock I tried to take apart tonight got very stiff, I still managed to remove the adjuster, the other three came apart easily.
Once I put all the adjusters back on they seem to have eased slightly, they are barely stiffer being wound downwards than they are being wound upwards.
If a running change needs to be made, I think it's the diameter of that top hole needs to be reduced to 13.5mm, should solve the trapped O-ring issue
#207
T4 18 Diff leak
Hello everyone,
I am having issues with the diff leaking through the casing using 8000k oil.
I secure the screws bit by bit and go across from one to another. I also don't over tighten. I changed the green gasket and still leaks through the casing. The O ring is not in the best shape since I opened it but I'm told it has no use anyway.
Any other ideas?
Any other ideas?
#208
Hello everyone,
Any other ideas?
Any other ideas?
Just make sure the gasket is wetted with oil, and that the case is locking together correctly (check the knob in the locator)
#210
Great thank you
