Tamiya M-07 Concept
#1201
I'm looking for a carpet tire for racing that's an alternative to the Ride TCS tires. I've used Sweeps and Solaris in the past but the tire diameter is smaller which puts me at a speed disadvantage. They are 56mm vs Tamiya's 60mm. I can't find diameter specs on Rush or Volante.
Does anyone know what the tire diameter is for these? Or can recommend a 60mm tire?
#1203
So I have an M07R with every available hop up and tuning option from Tamiya.
We have just got a new club track nearby (carpark, brand new freshly laid smooth asphalt. Is a small windy technical circuit) that I plan to race at. UK based so track temperatures will usually be cooler (maybe 18-22°C)
I will be running a lipo battery with a 17.5 brushless motor. All components and hop ups are to be Tamiya.
My question is what would be a good base setup to start with?
Regarding tires and inserts, would it be best to have softer compound on the front or rear?
Tire inserts medium all round or soft?
Springs softer in the front or rear?
Anything you could advise on would be a great help, just looking for a good starting point and will tweak and adjust as required..
Many thanks!
Many thanks!
#1204
Kit settings are perfect to start with.
Tyres, harder on the front, normally the softest you can find on the rear, the Sweep EXP mini tyres have been quite popular in the UK outdoors AFAIK, you can also go with the Tamiya tyres (M-Grips or S-Grips, M's are harder and can go on the front).
To be honest there are so many options with tyres it can get very complicated, especially if you allow people to build sets with their own inserts. Fixed gearing is a minefield if you are allowing different tyre diameters. Same with the motor choice if you are going to use 17.5s. I'd run the cars with a sealed brushed motor personally, and a limited tyre list, pre-mounts from the same manufacturer.
#1205
I drive front and rear s grip with front glued side wall, m grip I don`t use any more. Tire Inserts depends on heat and track (soft, medium and hard), at special rear wheels you can use often or put them in the front after one race weeked... In front and rear I drive as soft as possible as hard as necessary, so you would need all options on springs but out of box the springs are ok. IMO Body is important, I use Mazda2 and Swift mostly, MX5 and oders dont work as good for me... I think the higher Bodys regenerate more rolling in the chassis and because of the glued sidewalls there ist no problem of liftings wheels or fliping...
#1206
I find shorty pack centralizes the weight laterally which reduces roll as well as being lighter. Regular packs work well too but I don't find the regular to be advantageous over shorties
#1207
Rush are 56mm and have a big air gap. They work well and have good tire life, Even though they are shorter than the tamiya 60mm, the tamiya tires are squared off and have a higher sidewall, which might be why they don't necessarily handle better. The rush and sweeps handle better and have longer life than tamiya tires in my experience (on any surface).
#1208
in there somehow, just to keep up the speed..
#1209
Where I race we're only allowed a 20T pinion. I've tested the ride inch ups vs the smaller tyres. Lap times were no faster with the 60D, they had a bit more speed at the end of the straight but weren't as quick in the corners. Your motor and track will affect which is faster but don't immediately assume bigger is better.
#1210
Bought it just over 2 years ago. Figured it was finally time.
#1211
#1212
Think I like it
#1213
This thread has been pretty active lately. I'll have to dust off my 07 and refresh it. 2019 tcs at Jackson NJ was the last run.
#1214
Pity it's hard to find decent mini bodies though .
#1215
