Xpress Execute XQ1 TC >
Like Tree187Likes
Old 07-24-2018, 11:49 AM
  #181
(0000000000)'s Avatar
How many teeth are on the diff of the XQ1?
(0000000000) is offline
Old 07-24-2018, 12:15 PM
  #182
Airwave's Avatar
Originally Posted by Jonnydb
no, above C-hub, continue working with RC, antidive could help also
latest thing I've tested is to remove 0.5mm in below the upper front arm. Removing 1mm make the car too unstable.
Antidive could be a good thing also, thanks.
Airwave is offline
Old 07-24-2018, 03:07 PM
  #183
Jonnydb's Avatar
which setup are using? can you post?
Jonnydb is offline
Old 07-27-2018, 07:59 PM
  #184
Bartolo Racing's Avatar
Trader Rating: 18 (100%+)
2ND XPRESS ORDER ARRIVED
Bartolo Racing is offline
Old 07-28-2018, 04:33 AM
  #185
Trader Rating: 37 (100%+)
Default Camber link mounts
Can someone tell me if the camber links mounts are all the same thickness . They appear to be the same thickness. I watched a video on assembly and the guys states to install the thicker ones in front but I haven't seen a difference in thickness
fermanracer is offline
Old 07-28-2018, 04:47 AM
  #186
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
no calipers at your disposal ?
Marcos.J is offline
Old 07-28-2018, 12:40 PM
  #187
can someone please answer who has actually built the car. lol
Marcos.J likes this.
Old 07-28-2018, 01:39 PM
  #188
gigaplex's Avatar
What would you trust more? Some anonymous online post or your own tools?
Marcos.J and Bartolo Racing like this.
gigaplex is offline
Old 07-28-2018, 02:02 PM
  #189
i dont have calipers, so i have to go by eye, the stock kit looks like all are the same thickness. was just asking if anyone who has the car experienced this issues.
Old 07-28-2018, 02:13 PM
  #190
Super Moderator
Marcos.J's Avatar
lmao true
Robert you can use my digital calipers at the track in the morning
Marcos.J is offline
Old 07-28-2018, 05:08 PM
  #191
gigaplex's Avatar
If you're talking about these parts, yes they should be different.
Bartolo Racing likes this.
gigaplex is offline
Old 07-28-2018, 08:52 PM
  #192
thank you for the clarification.
Old 07-30-2018, 09:23 AM
  #193
Airwave's Avatar
They are different, but the thickness is the same. The position of the hole is different, I think to have shorter links in the back.
Airwave is offline
Old 07-31-2018, 05:25 PM
  #194
Default Set up
I just got my Xpress xq1 thanks to Bartolo Racing rc. I'm looking for a set up for black carpet running the 21.5 stock sedan class height traction. Thank you
harry1632 is offline
Old 07-31-2018, 05:56 PM
  #195
Default Set up
rc xpress likes this.
