Xpress Execute XQ1 TC >
Like Tree187Likes
Old 06-04-2020, 03:20 PM
  #391
Airwave's Avatar
Originally Posted by gigaplex
I still haven't got to the bottom of why, but my XQ1 mid has torque steer issues, and my XQ10 does not. If you just asked me, I'd say go for the XQ10 without hesitation, but it's possible I've got a defective part somewhere. My XQ1 doesn't have the issue when using the rear motor configuration. You could also just stick with the rear config if it's working fine for you.
As for what's actually different between the two cars? The main differences are the lower profile shocks, split bulkheads, new steering rack geometry, and the pulley/symmetric top deck layout.
Torque steer? With what kind of motor?
Airwave is offline
Old 06-04-2020, 05:29 PM
  #392
gigaplex's Avatar
Originally Posted by s14_tat
Based on what I am reading, it really isn't a game changer right? I mean my issue is still consistency.. I am in the 80's percentage wise. So this is supposed to make it easier to drive right?
I found the rear motor car is easier to drive consistently and the mid motor is easier to get a hot lap. If consistency is your problem, stick with rear until your consistency is 95+.
s14_tat likes this.
gigaplex is offline
Old 06-04-2020, 05:31 PM
  #393
gigaplex's Avatar
Any motor. It's worse with a 13.5 but it does it with a 21.5 too. It pulls one way when accelerating, the opposite way under brakes. I've checked tweak, droop, weight distribution, bent or binding parts, still haven't got to the bottom of it.
gigaplex is offline
Old 06-05-2020, 06:50 PM
  #394
Airwave's Avatar
Don't understand how a transversal motor would generate this kind of effect, the rotor should act more like a gyroscope and prevent the car to turn...
Airwave is offline
Old 06-05-2020, 08:59 PM
  #395
gigaplex's Avatar
I'm not suggesting it's caused by the torque effects of the motor, I was just describing the symptoms. It could be the asymmetric top deck flexing in weird ways. Even my old TC3 doesn't suffer this problem.
One point of interest was that when I asked the Xpress team why the mid spool moved the belt to the centre, their response was that it eliminates torque steer.
gigaplex is offline
Old 06-06-2020, 08:11 AM
  #396
lolz, it created the very problem they were trying to solve that wasn't even there to begin with.
s14_tat is offline
Old 06-06-2020, 08:51 AM
  #397
Airwave's Avatar
.What?
Airwave is offline
Old 07-04-2021, 08:58 AM
  #398
r_lud is offline
Old 07-04-2021, 08:59 AM
  #399
Liking the new low center of gravity look fod the xq10 by x-square canít wait to try it. It will fit the xq1 but you will need newer shorter shocks
r_lud is offline
