Platinum Lipo
#767
Originally Posted by Cotti
Hi Folks I just recieved my new LiPo pack and on the first charge it took 1744mah is this normal?
This shows that your lipo was appropriately prepared before it left the factory.
#768
Yes thats the answer I was hoping to get I do find it strange tho that they charge before shipping but maybe they need a charge soon after manufature? Can anyone clarify this?
#769
They claim that LiPo has virtually no self discharge means you can store them for a couple of days fully charged then use them on the track without "repeaking". With NiMH it makes sense to store them charged because they lose charging over the time but it is not an issue with LiPo right? Then why you have to store them charged?
An other question: is it OK to store them fully charged?
#770
Regional Moderator
First let me say that I can attest to the "virtually no self discharge" part of the LiPo thing. I let mine sitting for 3 weeks and it dropped a total of something like 83mah!
But as for why they say don't store them discharged, I can only assume that if you drain them completely, it may only take that small amout of "self discharge" to ruin them.
Personally I don't understand why this subject keeps coming up. Since the cells have no memory, why would anyone want to store their LiPo completely drained anyway???
#772
I've read that the balancing is either not necessary on LiPos or only VERY rarely. I undersatnd also that it is used to bring both cells to the same voltage by charging them both to the same capacity. I checked the voltage on both cells in a buddies pack and they varied by .04 volts. Now I know this small difference certainly doesn't require attention now, but at what point should we be concerned and balance the battery. .1 volt difference? Just wunderin'
#773
Originally Posted by syndr0me
Come on Orion... release that new battery already and deliver me from this life of NiMh hell.
The capacity is less than the Platinum, but the IR is even lower for more power. Run time should be equivalent to what a 5000 mAh NiMH pack would deliver.
#774
Originally Posted by Rick Hohwart
I will be testing the new pack at Tamiya's facility this weekend. So if anyone is there fell free to check it out.
#775
Originally Posted by Mr. McGoo
any "spy" shots of casing available, or will it be similar to the platinum
It weighs less than a 4-cell NiMh pack.
#776
It is different. If you look at it from the end, its profile is the same as that of a stick pack - rounded edges. But it incorporates ridges that will lock it into a slotted chassis while still allowing its use in off-road "channel" battery locations. It is very unique with a carbon look case.
thanks,
marc
#777
sweet....that is what i was hoping for....what type of time frame are you looking at for making them readily available....
thanks,
marc
thanks,
marc
#779
Yea, no doubt Rick, incredible job at the worlds.
The new pack sounds like what we (the touring car crowd) were hoping for. If that sucker will sit down in normal battery slots, it's going to be a dream come true. I'm holding out a small hope that it'll have multiple power connectors so I can connect to it on the corners like a normal side-by-side pack, but I won't get greedy. :-)
#780
Originally Posted by linger
Hey Rick - great job at the worlds. You just convinced me that I'm not too old anymore.
Let me guess. You new pack is 2s4p - it will be rated at 3.64 Ah, and if you were brilliant, you can make a saddle pack configuration with the "new" pack. So, am I close?
You are close but with this one (hint) you will not be able to make a saddle pack.
