Serpent Project 4-X >
Serpent Project 4-X
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree273Likes
Serpent Project 4-X
Last edit by:
Print Wikipost
Old 09-12-2019 | 03:55 PM
  #886
KUI
First pass. Medusa kit mounted on the 4x aluminum chassis. Some hole modding was required. If this weight bias doesn't work I'll moved the esc behind the motor.
DavidNERODease and silden like this.
KUI is offline
Old 09-13-2019 | 07:55 AM
  #887
Originally Posted by Airwave
I have a Pro, and I can't remember how the vertical upper-decks were attached on my P4X... Is the VTD kit compatible with Pro version? Do you have picture?
I had the impression you can mount the VTD in the front because front is quite similar to Evo, but in the rear you will have problem with upper-links, as they are fixed to the upper-deck... :-(
Wouldn't be able to use the rear centre post for the vertical deck on the Evo with the Medius conversion but it looks like everything else would fit... my Evo was never stiff enough for my local track so I'm afraid to go for the Medius conversion without stiffer flex options.
DavidNERODease is offline
Old 09-13-2019 | 09:04 AM
  #888
Airwave's Avatar
Honestly, the car was faster with the magnesium chassis. I hope Arrowmax will soon issue a new Mg chassis for Medius... They are coming from the same manufacturer after all....
For me the flex is way excessive! I'll try tomorrow with some stands between the lower and upper decks.
DavidNERODease likes this.
Airwave is offline
Old 09-13-2019 | 11:25 AM
  #889
Marcos.J's Avatar
Super Moderator
i don't think the flex characteristics of this chassis will not be the same as an actual aluminum mid motor chassis but i don't design chassis
Marcos.J is offline
Old 09-13-2019 | 04:18 PM
  #890
KUI
We run on high bite CRC black carpet. Today's test was awesome. More corner speed and better rotation. Car was more consistent and easier to drive hard.
KUI is offline
Old 09-15-2019 | 07:10 AM
  #891
Airwave's Avatar
Ok Medius is gone, one crash and the upper-deck is broken. It would have been nice to have a hole in the front part to put a stand but that's not the case. Before that the car seems to have a better traction but the setup needs work to get the rear back on track. I'm not sure I will order a new upper-deck as it is not available for the moment... I think I'll be back to the Arrowspace chassis for the moment...
Airwave is offline
Old 09-16-2019 | 11:22 AM
  #892
ScottyTC4NZ's Avatar
Originally Posted by DavidNERODease
I'm very happy to see that these upgrade kits are going to exist
Will this fit one standard 4x with evo upgrades?
ScottyTC4NZ is offline
Old 09-16-2019 | 12:48 PM
  #893
I started with the Evo so I don't know but also the first batch of Pro upgrade kits sold out before I could get one. And now the mid pulley thing is here but only in wet noodle mode so far... so I'm waiting a bit to see what other options come out before investing more in my 4x.
silden likes this.
Old 09-18-2019 | 10:51 AM
  #894
danielc3009's Avatar
if you’ve got the evo bulkheads than I can’t see why it wouldn’t
danielc3009 is offline
Old 09-18-2019 | 01:00 PM
  #895
TurnNBurn's Avatar
I got into the 4X with the Pro version, but if I recall reading correctly about the Evo, they upgraded both the roll and heave dampers as well - so all in all, if you have acquired the complete set of parts necessary to make your 4X the equivalent of an Evo, then yes, this kit was designed as a complete “Pro” upgrade.
As it is, installation of the vertical chassis braces is still an option in lieu of the new one in the Pro’s setup sheet, but I have yet to come across anyone who has actually used them in their setup. Too much stiffness maybe?
TurnNBurn is offline
Old 09-23-2019 | 08:02 AM
  #896
I found this tidbit of info/claim of the benefit of magnesium from Team Brood:
"Most know that magnesium is lighter than a comparable aluminum part (35%), but magnesium also offers superior dent resistance for improved precision over time, and is able to be machined to incredibly strict tolerances for more accurate suspension settings. MOST importantly magnesium has the highest known damping capacity of any structural metal available! Magnesium will absorb 16 times more shock and vibration than aluminum, and 10 times that of any other metal."
Old 09-23-2019 | 08:26 AM
  #897
TurnNBurn's Avatar
I guess the other question is, is it worth the price? This chassis is easily a quarter of the kit’s price.
Old 09-24-2019 | 03:45 PM
  #898
Airwave's Avatar
Best chassis I bought until now...
Airwave is offline
Old 09-25-2019 | 08:00 AM
  #899
Funny, I wish magnesium was heavier though. I like the idea of improved shock and damping but it raises the CG of the car. You have to stick even more weight on top of the chassis. Airwave, which plate did you get (solid or flex) and how much does it weigh?
Old 09-25-2019 | 09:42 AM
  #900
TurnNBurn's Avatar
If only the chassis were thicker, then they could utilize weights like they do on the 750... but then the cost of that thicker magnesium chassis would be truly ridiculous. Anyway...
Since I’m just coming back into the hobby, I’m still trying to wrap my head around the concept of wanting flex in the chassis. Back in the late 80s and early 90s we all went from fiberglass to graphite because we wanted to stiffen the chassis as much as possible and make the suspension do all the work. The theory behind this of course is that flex can be inconsistent, and thus cause inconsistent behavior. What changed in the last 25 years?
