Team Associated F1
#631
Well I finally got a track day with her.... Only a couple 1/10ths off the fast guys for the first time out. Pretty much a box stock configuration too. Still working on getting the timing on the motor set then its just about driving. Was surprised how well it handled even compared to my 1/12th scale. Should be a fun class to run. The new CRC Black carpet at TQ-Racing is so good and consistent. Cant wait to go out for a race day.
Wires came out pretty good might take another stab at it later
#632
I would suggest you make the negative wire short enough to not be able to reach the battery positive.
#634
Always look before you plug !
#635
Is there a trick to mounting the wheel decals?
#637
use a lighter and gently heat the decals
#640
Race day #9. New layout. Tried running counterclockwise
Round 2.
https://youtu.be/q2j3jnuWIbs
R3. Pinion change
https://youtu.be/ORE4ZoOKc8w
R4
https://youtu.be/u_DdSRR5HoY
Round 2.
R3. Pinion change
R4
#641
#644
I would like to switch the servo mounts from fixed to floating. The manual does not describe how to do this. Do i just have to remove the screw that connects the fixed mount to the chassis plate?
