Team Associated F1
#781
Have you tried more caster? Also a bit of negative steering exp on the radio would help
#782
Hi guys,
I have a big problem where the car feels nice everywhere except high speed corners. Especially sweepers where if i use even slightly too much steering lock, the car snap oversteers.It has a bouncing/juddering sensation as it does it.
I've tried softer and harder springs all round, thicker damping front and side, more front droop, less front droop, different camber.
Im totally lost as to how to fix this. Does anyone have any experience of fixing this problem?
This is on ETS carpet and Volante tyres, so maybe a little less grip than many of you experence where the black crc carpet is used?
Thanks for any help!
#784
Hey all, I just picked up a RC10F6 and I’m pumped, but coming from the off road world I’m stumped on what spare parts to keep in my box.
There are few things I despise more than a race day cut short by me not having a $5 spare part. What do you always keep on hand? I’ve heard front wings, but what else?
#785
#786
https://rover.ebay.com/rover/0/0/0?m...2F382032036314
Think I broke 8-10 over 14 race days. Front wing was second with 3. I’m on the 4th wing but haven’t run it since end of September, and still got 14 weeks or so till race again.
I’m going to try the XRay pod links this year. Measure out the same. Another driver suggested trying them. He did break any, but is a much better driver then I am.
#787
#788
Get the Montech 17 front wing instead. It is the same shape and size as the Associated part and has 2 and 3 flap wing elements to adjust front downforce. Get the new front wing shims to lift the front wing, the new reinforced front upper deck post set, the adjustable caster plate and the axial front lower arm mounts. Pick up a couple different front spring sizes, rear tweak spring sizes. The alloy camber inserts are a good addition too. The plastic ones can strip. A-main has all the parts, but you might want to go to RC10.com and check out the part numbers along with checking the manual for options.
#789
Using 2 tyraps and a o-ring. One of the tyraps is used to ty the o-ring to the sidebar, the other one act as a hook for the o-ring. Works perfect
#791
Im looking for the softest set of premounted tires. What should I get?
#792
Gentlemen-Recently while at the track, overheard many racers talking about locking their diffs by either cranking the adjustment screw tight or using pegs in the spur gear instead of balls. I have been racing onroad before diffs were available like pre ASC 12E and, for the life of me, cannot fathom how you could get a car to turn without the rotation of the rearend around the corner. Am I missing something? Of course, as I stated before, almost all my carpet racing was done on foams, as opposed to CRC rubber. THX
#793
Will the Exotek front upper suspension system work with the forward servo mount system on the F6? THX
#794
Thanks,
#795
Part #: 8637 - New Top deck plate
Part #: 8643 - Suspension Brace
Part #: 8664 - Upper deck posts (Top Plate Standoffs)
Part #: 8679 - Front wing shims (must have picked up one of the last sets)
Part #: 8638 - Lower arms (not in stock last time I ordered)
