MAKING HOLES FOR THE BODY
#16
A dap of "white out" on the top of the body posts will help if the body is painted dark.
#17
Holes...
Make sure you use a body reamer!!! It's worth it, I swear! I tried to cut holes in my first body, then got a reamer for my 2nd, and it was a world of difference. I bought the Factory Team one, which is nice, but I kind of wish I had waited and bought the Hudy one. (big $$$ though)
#18
Originally Posted by v0rtex
Definantly do it before you paint, but if you forget line the body up on the posts and shine a torch below the car, you'll see where the posts contact the body and hence where to make the hole in the body.
Vortex, I hope your in England! Around here a torch has flames shooting from it.
#22
Here's a trick I learned from making blow gun darts during my ninja days.
Take a thumb tac to the top of your body posts push it down the center slightly. Cut the tips off 4 tacks, hold them over a flame for a bit (with pliers of course) and push them into the tops of the posts. Home made Trinity markers. If you forget to mark your holes before painting again, just drop some new pins in the posts. You can even do this before painting because the indents are more accurate than a bunch of fat Sharpie markings.
#23
#24
+2 !!!
#26
awesome...keep them coming!...kitty
#27
Before i paint the body i place it over the car and mark where the posts are on the outside of the shell with a marker. Wait for the paint to dry. Then when you peal off the protecive plastic on the outside the markings come with it.
